Looking to purchase used 1992 WB40
03-15-2007, 18:28
Post: #31
Now that you ask, I do not know when they added that feature, but
that is how mine works. Anybody know for sure? Tom McCarthy Poway, CA 95 PT42 --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > Tom: Wow, that's great information. I've never heard that before. > Where did you get it? I do know that last year I was in Idaho and > needed extra traction to get up a slick pass. I dumped the tag, the > gage went to zero and I proceeded up the hill about thirty mph, never > did the tag pressure gage read more than zero. I wonder if my system > is not working properly. Thanks, Bob 93pt-40,Illinois > > > > > If you forget to air the tag and go over 15 mph, it will > > automatically switch to air up. Another safety precaustion built > in > > for you. > > > > Tom McCarthy > > Poway, CA > > 95 PT42 > > > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > wrote: > > > > > > On Mar 11, 2007, at 10:18 PM, mbrund wrote: > > > <snip> > > > > > > > > When I test drove it, I pressured the tags. The tag pressure > > gauge > > > > was reading 75 PSI, not sure if this is high or not. > > > > > > 75 PSI is about right. Never drive _at speed_ without tag air as > > it > > > over-stresses the rear axle/suspension/tires. (Under 5 mph is > OK.) > > > The suspension dump is rather quiet, I only know it's happening > > > 'cause the steering wheel will turn a little bit as the coach > > sinks > > > down. > > > > > > > The dash is a little overwelming at first, > > > > > > Indeed it is... but it's what's not in the manual that > will "get" > > > you. For example, when I couldn't get the _heat_ to work in my > > coach, > > > someone suggested turning _on_ the AC switch on the dashboard. > I'd > > > never have guessed that one. > > > > > > > > > Pete Masterson > > > aeonix1@ > > > '95 Blue Bird Wanderlodge WBDA 42' > > > El Sobrante, CA > > > > > > |
