8v92 will not crank update-bad starter???
04-20-2008, 07:39
My day of troubleshooting tells me that I have a bad starter. When the
starter is engaged by the key, the solenoids click and the starter itself makes a loud click but does not turn. The same starter click happens when jumping across the solenoid. I can turn the crankshaft with a wrench, so it's not locked up (thank God). The starter has not exactly been what I would call 'strong' for the year I have owned the coach anyway, and it looks plenty old, so I am thinking it just gave up the ghost. Agree/disagree? Scott Forman 86 PT38 Memphis |
04-20-2008, 08:51
Scott: Try clamping a heavy jumper cable from the starter housing to
a good battery ground...easy to do and is an additional way to rule out have a bad ground. Dick Gideon 1989 35FC Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > My day of troubleshooting tells me that I have a bad starter. When the > starter is engaged by the key, the solenoids click and the starter > itself makes a loud click but does not turn. The same starter click > happens when jumping across the solenoid. I can turn the crankshaft > with a wrench, so it's not locked up (thank God). The starter has not > exactly been what I would call 'strong' for the year I have owned the > coach anyway, and it looks plenty old, so I am thinking it just gave up > the ghost. > > Agree/disagree? > > Scott Forman > 86 PT38 > Memphis > |
