					Batteries follow up
					11-14-2009, 15:37
				 Post: #1 | |||
| Batteries follow up
					Hi all FYI after all the info recieved from the forum I cleaned all the battery post , filled each cell turned everything off including the switch under the dash board . I moved the bus a little to recieve more direct sun for the solar panel . Left the bus with 12.3v on the panel. Came back two days later 12.5v on the panel.I think I'm good to go . Will see when I get back in Dec. Mario 1985FC35 on the way to Marthas Vineyard | |||
					11-14-2009, 15:45
				 Post: #2 | |||
| Batteries follow up Mario Have a safe trip and enjoy the East Coast. We hope you can come to Q this January.We are looking forward to visiting again. Fred & Jeanne Hulse & Girls Morristown Arizona 1997 Wanderlodge WLWB41 | |||
					11-15-2009, 02:01
				 Post: #3 | |||
| Batteries follow up
					12-03-2009, 18:42
				 Post: #4 | |||
| Batteries follow up
					Hi All Back from cloudy rainy North East to a sunny SOCAL . A last follow up on the batteries . Found the batteries at 13 volts . Very happy . Mario 1985FC35 --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > Hi all > FYI after all the info recieved from the forum I cleaned all the battery post , filled each cell turned everything off including the switch under the dash board . I moved the bus a little to recieve more direct sun for the solar panel . Left the bus with 12.3v on the panel. > Came back two days later 12.5v on the panel.I think I'm good to go . > Will see when I get back in Dec. > Mario 1985FC35 on the way to Marthas Vineyard > | |||
					12-03-2009, 20:30
				 Post: #5 | |||
| Batteries follow up
					Mario- glad that you are home safe. Hope to see you at Q. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > Hi All > Back from cloudy rainy North East to a sunny SOCAL . > A last follow up on the batteries . Found the batteries at 13 volts . > Very happy . > Mario 1985FC35 > > --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > > > Hi all > > FYI after all the info recieved from the forum I cleaned all the battery post , filled each cell turned everything off including the switch under the dash board . I moved the bus a little to recieve more direct sun for the solar panel . Left the bus with 12.3v on the panel. > > Came back two days later 12.5v on the panel.I think I'm good to go . > > Will see when I get back in Dec. > > Mario 1985FC35 on the way to Marthas Vineyard > > > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
