Need repair recommendation - So Cal / AZ
11-26-2009, 07:11
I'm currently just off Hwy 395 about 60 miles east of Bakersfield eventually
headed for Yuma. Somehow (no other scratches or scrapes) I managed to tear part of the original black water valve off. The valve needs to be replaced and is was originally apparently glued on. A previous owner had the pipe coming out of the tank wrapped in something so without a sawzall, I can't even see what I'm up against. I had the local (very small) RV place look at it and he thought there was a good chance the tank was going to have to be pulled and replaced. He recommended Stiers in Bakersfield but Bakersfield is a little out of the way. Any comments on Stiers or another suggestion would be appreciated. The most direct route to Yuma takes me through the far eastern suburbs of Los Angeles (riverside and Palm Springs). Regards, GPSGary 1984FC35SB |
11-26-2009, 07:24
Gary
If you can get down to Victorville,you will find help there.
May be someone in the general area will add more info.
Fred Hulse
11-26-2009, 07:31
11-26-2009, 07:33
--- In WanderlodgeForum@yahoogroups.com, "hippieforever3"
> > I'm currently just off Hwy 395 about 60 miles east of Bakersfield eventually headed for Yuma. > > Somehow (no other scratches or scrapes) I managed to tear part of the original black water valve off. The valve needs to be replaced and is was originally apparently glued on. > > A previous owner had the pipe coming out of the tank wrapped in something so without a sawzall, I can't even see what I'm up against. I had the local (very small) RV place look at it and he thought there was a good chance the tank was going to have to be pulled and replaced. > > He recommended Stiers in Bakersfield but Bakersfield is a little out of the way. > > Any comments on Stiers or another suggestion would be appreciated. The most direct route to Yuma takes me through the far eastern suburbs of Los Angeles (riverside and Palm Springs). > > Regards, > GPSGary > 1984FC35SB I guess by the way it sounds you snaped oft the valve oft of the discharge pipe, right? If you still have some pipe left than you can get a plastic nipple (Large coupling and slip it over the broken part of the pipe. Then like I did I just got another gate vlv and installed it. So where is the pipe snapped oft at? jon > |
11-26-2009, 11:00
Ernie, Gary,
Temecula Valley RV is just south of Riverside on I-15. That's where the new owners took our LXi for service. I think they've been well satisfied. Here's the phone number and link: Phone: (951) 894-2347 http://www.temeculavalleyrv.com/dealerfiles/ Happy Thanksgiving, all. Brad "bbartonwx@hotmail.com" To: WanderlodgeForum@yahoogroups.com From: ernietex@... Date: Thu, 26 Nov 2009 11:31:25 -0800 Subject: Re: [WanderlodgeForum] Need repair recommendation - So Cal / AZ
Bing brings you maps, menus, and reviews organized in one place. Try it now. |
11-26-2009, 11:16
11-26-2009, 16:07
on domestic household plumbing repairs they make fittings that will weld/glue to
the id of old/installed fittings for repairs sake. It may be a good idea to seek the advice of a residential plumber for a repair. the repair fittings are not available at home depot and may not have ever been used by a rv tec for them to consider the advantage of their use Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "hippieforever3" > > I'm currently just off Hwy 395 about 60 miles east of Bakersfield eventually headed for Yuma. > > Somehow (no other scratches or scrapes) I managed to tear part of the original black water valve off. The valve needs to be replaced and is was originally apparently glued on. > > A previous owner had the pipe coming out of the tank wrapped in something so without a sawzall, I can't even see what I'm up against. I had the local (very small) RV place look at it and he thought there was a good chance the tank was going to have to be pulled and replaced. > > He recommended Stiers in Bakersfield but Bakersfield is a little out of the way. > > Any comments on Stiers or another suggestion would be appreciated. The most direct route to Yuma takes me through the far eastern suburbs of Los Angeles (riverside and Palm Springs). > > Regards, > GPSGary > 1984FC35SB > |
