Golf cart battery conversion
06-29-2010, 02:27
Has anyone done a conversion from the 8 12 volt house batteries to 6 or 8 6 volt
golf cart batteries on an early 90's Bird? I have adequate pullout tray space for all but height as the 6 volt are 11" tall and won't quite fit. Any suggestions on making it work? Thanks, Alvie Miller 93 WLWB Arthur IL |
06-29-2010, 02:34
My Golf Car batteries in my Allegro Bus are 10" tall including the caps. They are Interstate Powerfast from Sam's Club. $68 each.
Jerry & Coleen 2005 Allegro Bus 2005 Jeep Rubicon Whitney, Texas On Jun 29, 2010, at 9:27 AM, whynotam wrote:
06-29-2010, 09:48
I had that job done on my 94 by Triangle RV of Sydney BC. They moved the 2800Watt Inverter up and lowered the lower tray. This made room for the taller 6 Volt Golf Carts. They lowered the bottom tray by adding two inch square tubing on each side of the tray. If you don't wish to construct such an assembly you could buy my old one. I contacted Randy Dupree to see if he'd sell it. It's for sale and you can contact him at 352 538-3435.
On 29 June 2010 07:27, whynotam <"aamiller@chiohd.com"> wrote:
-- Rob, Sue and Joey Robinson |
06-29-2010, 11:07
Alvie, Randy had done the same on his '93,now mine, to accommodate sixbig L-16s. If you want a pic, email me at "davisgr2@yahoo.com" and I will reply with one.
Rick Davis
1993 WBSA (for sale)
Loudon, TN
From: Rob Robinson To: WanderlodgeForum@yahoogroups.com Sent: Tue, June 29, 2010 5:48:15 PM Subject: Re: [WanderlodgeForum] Golf cart battery conversion I had that job done on my 94 by Triangle RV of Sydney BC. They moved the 2800Watt Inverter up and lowered the lower tray. This made room for the taller 6 Volt Golf Carts. They lowered the bottom tray by adding two inch square tubing on each side of the tray. If you don't wish to construct such an assembly you could buy my old one. I contacted Randy Dupree to see if he'd sell it. It's for sale and you can contact him at 352 538-3435. On 29 June 2010 07:27, whynotam <"aamiller@chiohd.com"> wrote:
06-30-2010, 01:19
Thanks to all for the replies! I'll give Randy a call as well as check out the
Interstate 10" tall batteries. Alvie Miller 93 WLWB Arthur IL --- In WanderlodgeForum@yahoogroups.com, Rick Davis > > Alvie, Randy had done the same on his '93,ÃÂ now mine, to accommodate sixÃÂ big L-16s.ÃÂ If you want a pic, email me at davisgr2@... and I will reply with one. > Rick Davis > 1993 WBSA (for sale) > Loudon, TN > > > > > ________________________________ > From: Rob Robinson > To: WanderlodgeForum@yahoogroups.com > Sent: Tue, June 29, 2010 5:48:15 PM > Subject: Re: [WanderlodgeForum] Golf cart battery conversion > > ÃÂ > I had that job done on my 94 by Triangle RV of Sydney BC. They moved the 2800Watt Inverter up and lowered the lower tray. This made room for the taller 6 Volt Golf Carts. They lowered the bottom tray by adding two inch square tubing on each side of the tray. If you don't wish to construct such an assembly you could buy my old one. I contacted Randy Dupree to see if he'd sell it. It's for sale and you can contact him at 352 538-3435. > > > On 29 June 2010 07:27, whynotam > > ÃÂ > >Has anyone done a conversion from the 8 12 volt house batteries to 6 or 8 6 volt golf cart batteries on an early 90's Bird? I have adequate pullout tray space for all but height as the 6 volt are 11" tall and won't quite fit. Any suggestions on making it work? > > > >Thanks, > >Alvie Miller > >93 WLWB > >Arthur IL > > > > > > > -- > Rob, Sue and Joey Robinson > |
