Racor Filter
07-09-2005, 11:13
Racor Filter
don, i have seen a couple of Racor's that were mounted pretty low on the
frame. it could have happened. Mine is up almost 18 inches above the tank and
couldn't siphon. ERnie in montana- maybe bringing the coach up here where it's
cool next month
07-09-2005, 11:48
Racor Filter
In a message dated 7/9/2005 11:14:07 P.M. Eastern Daylight Time,
erniecarpet@... writes:
it's
cool next month
Hay Ernie I would mind being in Montana myself. Tomorrow I think I will try
it with taking the top off of the Racor & see if that doesn't brake the
siphon. I had never tried to drain it before Just a little to get any
settlement
out of it. Tom I know the key wasn't on in the rear because it will start from
up front& it won't if the key is on in the rear.
Don
89 SP 36'
Butler, PA
07-09-2005, 15:25
Racor Filter
If you got more then a coffee can out of your racor, then you were
syphoning it out of the tank. No matter how hard you try you cant get a
gallon of diesel from a quart jar . And for the syphon to work the
racor does not have to be below the tank. If the lines are already filled
and I assume they were, you could probably have taken fuel out of the
bottom of the racor until you ran the tank dry. I have a strong feeling
that you had the key on maybe from the rear?
tom
1982 FC35
Vernon Center,NY
At 10:43 PM 7/9/2005 -0400, you wrote:
>Hi All I have a dumb question about the racor filter. A year and a half
>ago I had a shop take my filter apart & clean it. The other day I was
>going to
>clean it myself & I started draining the fuel out of the bottom of the
>filter. I got about 4 gallons out of it & it was still draining. I was
>wandering if
>it was siphoning out of the fuel tank??? Is that a possibility?
> Don
> 89 SP 36'
> Butler, PA
>Yahoo! Groups Links
07-10-2005, 12:20
Racor Filter
About four days ago I did the same thing. If you take the cap of the top of
the racor, it will no longer siphon from the tank.
dandarst86fc35rbhuntleyil.
>From: dspithaler@...
>Subject: Re: [WanderlodgeForum] Racor Filter
>Date: Sat, 9 Jul 2005 23:09:57 EDT
>In a message dated 7/9/2005 10:55:29 P.M. Eastern Daylight Time,
>don, thats strange. When I cleaned my racor I was able to just use a
>coffee
>can to catch my diesel. was your key on? ernie- 83pt 40 in montana
>No the key wasn't on but I hadn't unscrewed the top yet do you think it
>could siphon out of the tank?
> Don
> 89 SP 36'
> Butler, PA
