the ever controversial "DASH AIR"
08-08-2005, 15:35
I'm trying to fix the troublesome dash air. Does anyone know if BB
still carries replacement parts for the roof condensor, or maybe a better cheaper source. I need one fan motor and two fan blades (what were they thinking using plastic fan blades). Has anyone replaced them with metal blades? Any part numbers would be a great help. Thanks Bruce Campbell Clearwater, FL 83'FCSB "Blue Skies" |
08-08-2005, 20:24
Bruce, have you taken apart and cleaned your fan motor? Ernie-83pt40 in
Montana- no dash air [Non-text portions of this message have been removed] |
08-09-2005, 08:27
Bruce- there maybe some crud on the winding. take some fine sandpaper and
make it shine- should work fine. ernie [Non-text portions of this message have been removed] |
08-09-2005, 09:59
I pulled it last night, haven't tried to clean it yet. Just got home
from work. The shaft spins freely, but won't turn when power up, and makes squealing noise. I will take it apart to see how it looks. Thanks Bruce Campbell Clearwater, FL 83'FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > Bruce, have you taken apart and cleaned your fan motor? Ernie-83pt40 in > Montana- no dash air > > > [Non-text portions of this message have been removed] |
08-09-2005, 15:16
Anyone know how to test for the type of refrigerant currently in the
system? (R12 or R134)? --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > I'm trying to fix the troublesome dash air. Does anyone know if BB > still carries replacement parts for the roof condensor, or maybe a > better cheaper source. I need one fan motor and two fan blades (what > were they thinking using plastic fan blades). Has anyone replaced them > with metal blades? Any part numbers would be a great help. > > Thanks > Bruce Campbell > Clearwater, FL > 83'FCSB > "Blue Skies" |
08-09-2005, 23:34
I think The filler valves are diffrent sizes, an r12 guage won't fit
on an r134 filler valve. I could be wrong, maybe some can validate this. Thanks Bruce Campbell Clearwater, FL 83'FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > Anyone know how to test for the type of refrigerant currently in the > system? (R12 or R134)? > > > --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > > > > > I'm trying to fix the troublesome dash air. Does anyone know if > BB > > still carries replacement parts for the roof condensor, or maybe a > > better cheaper source. I need one fan motor and two fan blades > (what > > were they thinking using plastic fan blades). Has anyone replaced > them > > with metal blades? Any part numbers would be a great help. > > > > Thanks > > Bruce Campbell > > Clearwater, FL > > 83'FCSB > > "Blue Skies" |
08-10-2005, 00:48
From: fl_bluebird_1983 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 10, 2005 6:34 AM Subject: [WanderlodgeForum] Re: the ever controversial "DASH A Bruce they do use a differnt fitting for the r134 service valve. Bob Loomas 85 PT 36 ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
08-10-2005, 03:37
Not an easy task to identify the type of
refrigerant/oil is in your system. If you think someone may have converted to something else, (and there are lots of options out there, not just 134a), you probably have to go to an A/C shop, and pay them to test it. The equipment costs $700-$1000. Scott Peatross '87PT40 --- ttikalsky --------------------------------- Anyone know how to test for the type of refrigerant currently in the system? (R12 or R134)? --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > I'm trying to fix the troublesome dash air. Does anyone know if BB > still carries replacement parts for the roof condensor, or maybe a > better cheaper source. I need one fan motor and two fan blades (what > were they thinking using plastic fan blades). Has anyone replaced them > with metal blades? Any part numbers would be a great help. > > Thanks > Bruce Campbell > Clearwater, FL > 83'FCSB > "Blue Skies" SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- |
08-11-2005, 12:51
Bruce,
I have found you can take the motors and blade to a good appliance parts dealer and they can usually match things pretty close. --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > I'm trying to fix the troublesome dash air. Does anyone know if BB > still carries replacement parts for the roof condensor, or maybe a > better cheaper source. I need one fan motor and two fan blades (what > were they thinking using plastic fan blades). Has anyone replaced them > with metal blades? Any part numbers would be a great help. > > Thanks > Bruce Campbell > Clearwater, FL > 83'FCSB > "Blue Skies" |
