Outside Storgage Compartment Latch locks
10-31-2007, 16:29
We have a '83 FC35SB that 3 of the 5 locking cargo compartment latch
locks have given up the ghost, literally. I have done several searches but have not located an answer of where to locate these little items, not to mention how to replace the locks. Unless, it cannot be done with out compleatly replacing the entire latch mechanism. The latch housing / flange on our's are original and were riveted in. Any suggestions would be greatly appreciated. |
10-31-2007, 16:49
So....did you try looking in the Parts Database for "Outside
Compartment Door Latches" for a link to Austin Hardware? Also, please sign your posts. Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Scott" > > We have a '83 FC35SB that 3 of the 5 locking cargo compartment latch > locks have given up the ghost, literally. I have done several searches > but have not located an answer of where to locate these little items, > not to mention how to replace the locks. Unless, it cannot be done > with out compleatly replacing the entire latch mechanism. The latch > housing / flange on our's are original and were riveted in. > > Any suggestions would be greatly appreciated. > |
10-31-2007, 16:57
Oops... No I did not look under "Outside". I did look through the
data base for "Compartment" "Door" and "Latches" but... There it is none the less. Thanks so much. Sorry about the failure to sign. My Noobie light is flashing? Scott Waldy '83 FC35SB Boise, Idaho --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > So....did you try looking in the Parts Database for "Outside > Compartment Door Latches" for a link to Austin Hardware? > > Also, please sign your posts. > > Thanks, > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "Scott" wrote: > > > > We have a '83 FC35SB that 3 of the 5 locking cargo compartment latch > > locks have given up the ghost, literally. I have done several searches > > but have not located an answer of where to locate these little items, > > not to mention how to replace the locks. Unless, it cannot be done > > with out compleatly replacing the entire latch mechanism. The latch > > housing / flange on our's are original and were riveted in. > > > > Any suggestions would be greatly appreciated. > > > |
10-31-2007, 17:01
I believe you might have some luck in McMaster-Carr. Here's a link
http://www.mcmaster.com/ On 31/10/2007, Scott > > We have a '83 FC35SB that 3 of the 5 locking cargo compartment latch > locks have given up the ghost, literally. I have done several searches > but have not located an answer of where to locate these little items, > not to mention how to replace the locks. Unless, it cannot be done > with out compleatly replacing the entire latch mechanism. The latch > housing / flange on our's are original and were riveted in. > > Any suggestions would be greatly appreciated. > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
11-01-2007, 01:32
Try here orrorr.com
Bill 88 FC Michigan at RATS --- In WanderlodgeForum@yahoogroups.com, "Scott" > > We have a '83 FC35SB that 3 of the 5 locking cargo compartment latch > locks have given up the ghost, literally. I have done several searches > but have not located an answer of where to locate these little items, > not to mention how to replace the locks. Unless, it cannot be done > with out compleatly replacing the entire latch mechanism. The latch > housing / flange on our's are original and were riveted in. > > Any suggestions would be greatly appreciated. > |
