1987 PT40 Grease and Zerk Fittings
05-21-2007, 07:32
Hi all,
Do I need to use a special lube for my brake Zerk fittings? I could not locate the "Stopmaster" NLG1 grade #1 type. These are self adjusting type brakes. Also, what is the recommended lube for the other bus Zerk fitting? Or does it matter so long as it is grade NLG1 grade #2? Nappa has like ten types of this stuff and they recommended simply using the plane lithium type. Thanks for the help, Don Duncan 1987 PT40 Beaverton, Oregon |
05-21-2007, 09:42
just use the same good grease You use on the rest of the coach
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "worktohobby" > > Hi all, > > Do I need to use a special lube for my brake Zerk fittings? I could not > locate the "Stopmaster" NLG1 grade #1 type. These are self adjusting > type brakes. > > Also, what is the recommended lube for the other bus Zerk fitting? Or > does it matter so long as it is grade NLG1 grade #2? Nappa has like ten > types of this stuff and they recommended simply using the plane lithium > type. > > Thanks for the help, > > Don Duncan > 1987 PT40 > Beaverton, Oregon > |
