Connecting An Inveter to The House/Starting Bank
03-20-2006, 08:03
I am installing an Inverter and want to connect it directly to the
House/Starting Bank in my 78FC33. The bank is configured in the original Series/Paralle configuration. Where do I connect the Positive and Negative leads of the inverter to the bank? I am not sure which terminals to use. Thanks in advance to those who have been here and done this. --James 78FC33SB LasVegas NV |
03-20-2006, 15:01
James,
FWIW, Check out the files section over on the FC_Wanderlaodge Yahoo website. I believe you'll find some help there, T.J.Hannik detailed his inverter installation on an early FC. Jim Owens 77 FC33SB (Gas) Lale of the Ozarks, MO --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > I am installing an Inverter and want to connect it directly to the > House/Starting Bank in my 78FC33. The bank is configured in the > original Series/Paralle configuration. > > Where do I connect the Positive and Negative leads of the inverter to > the bank? I am not sure which terminals to use. > > Thanks in advance to those who have been here and done this. > > > > --James > > 78FC33SB > > LasVegas NV > |
03-20-2006, 15:09
James,
http://tinyurl.com/zgfns or the long version http://f3.grp.yahoofs.com/v1/MGwfRGGxgRB...lBb58_3cCp RNPk7v-g9A15qAc1EFZUWPTP7UJEJvcAmrn9dxt1st9HMXYjtpJNis8lg/Inverter% 20Install --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > I am installing an Inverter and want to connect it directly to the > House/Starting Bank in my 78FC33. The bank is configured in the > original Series/Paralle configuration. > > Where do I connect the Positive and Negative leads of the inverter to > the bank? I am not sure which terminals to use. > > Thanks in advance to those who have been here and done this. > > > > --James > > 78FC33SB > > LasVegas NV > |
03-21-2006, 07:17
Thanks, Jim. I appreciate the info, have a great day.
-James 78FC33SB LasVegas NV -- In WanderlodgeForum@yahoogroups.com, "Jim Owens" wrote: > > James, > > http://tinyurl.com/zgfns > > or the long version > > http://f3.grp.yahoofs.com/v1/MGwfRGGxgRB...JlBb58_3cC p > RNPk7v-g9A15qAc1EFZUWPTP7UJEJvcAmrn9dxt1st9HMXYjtpJNis8lg/Inverter% > 20Install > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > > > I am installing an Inverter and want to connect it directly to the > > House/Starting Bank in my 78FC33. The bank is configured in the > > original Series/Paralle configuration. > > > > Where do I connect the Positive and Negative leads of the inverter > to > > the bank? I am not sure which terminals to use. > > > > Thanks in advance to those who have been here and done this. > > > > > > > > --James > > > > 78FC33SB > > > > LasVegas NV > > > |
03-21-2006, 08:11
Jim, that was a lot of info, and mighty good stuff, with the
exception that it does not tell me which terminals of the 4 batteries to wire the converter to. I am doing a very simple installation. I only want to convert electricity in ONE dedicated circuit, to run an entertainment center, nothing more. This circuit will consist of an extension cord that will run from the converter to the entertainment center. What I need to figure out, is which terminals of the four positive and negative posts are best to hook the inverter up to. My bank is the original configuration with (4) 6 volt batteries that serve as both the house and starting bank. Anyone? -James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Thanks, Jim. I appreciate the info, have a great day. > > -James > 78FC33SB > LasVegas NV > > > -- In WanderlodgeForum@yahoogroups.com, "Jim Owens" > wrote: > > > > James, > > > > http://tinyurl.com/zgfns > > > > or the long version > > > > > http://f3.grp.yahoofs.com/v1/MGwfRGGxgRB...JlBb58_3cC > p > > RNPk7v- g9A15qAc1EFZUWPTP7UJEJvcAmrn9dxt1st9HMXYjtpJNis8lg/Inverter% > > 20Install > > > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > > > > > > > I am installing an Inverter and want to connect it directly to > the > > > House/Starting Bank in my 78FC33. The bank is configured in the > > > original Series/Paralle configuration. > > > > > > Where do I connect the Positive and Negative leads of the > inverter > > to > > > the bank? I am not sure which terminals to use. > > > > > > Thanks in advance to those who have been here and done this. > > > > > > > > > > > > --James > > > > > > 78FC33SB > > > > > > LasVegas NV > > > > > > |
