Loose wheel SP36?
04-06-2006, 03:20
Loose wheel SP36?
I took the bird out for a test drive after replacing the thermostat
and ran over a rather large pothole at which time I heard (and felt) a rattling from the right front wheel which felt similar to an episode I experienced with an old truck I had which turned out to be worn kingpins. Questions are: does this coach have kingpins and if so how big a job is it to replace them? Chuck Harrison 90 SP36 Akron, Ohio |
04-06-2006, 12:42
Loose wheel SP36?
> > I took the bird out for a test drive after replacing the thermostat > and ran over a rather large pothole at which time I heard (and felt) > a rattling from the right front wheel which felt similar to an episode > I experienced with an old truck I had which turned out to be worn > kingpins. Questions are: does this coach have kingpins and if so > how big a job is it to replace them? > > Chuck Harrison > 90 SP36 > Akron, Ohio > Chuck, Yes, your SP has king pins. I have not done a replacement of them on my SP, but if it is anything like the other work I have done, (brakes tires, valve adjust, fan clutch, radiator) it is not any different than on a car, tractor, etc. Just much bigger, heavier, etc. You will of course need the proper size reamer, etc. I am sure the parts are available from Blue Bird, however, they are probably available from bus - heavy truck parts suppliers also. Jim Brookshire 89 SP-36 Saluda, NC |
04-06-2006, 12:42
Loose wheel SP36?
