voltage and amp meter
06-11-2006, 14:32
when the engine is running neither my engine volmeter or amp meter
show a charge or movement. I know the system works because my battries stay charged up.I would like to have them working. Any thoughts?? re brake 1983 FC-35 SB |
06-11-2006, 15:38
BE SURE there is good ground at meters. Is voltage/amps present at the
guages (wires at the guages)? If so, I'd think the guages are bad. If no voltage/amps then go back to the source, the alternator/regulator and check there, maybe the wires are loose. Hope this helps. Others will join in and add to this. Good luck. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. putneyflash wrote: > when the engine is running neither my engine volmeter or amp meter > show a charge or movement. I know the system works because my battries > stay charged up.I would like to have them working. Any thoughts?? > re brake 1983 FC-35 SB > > |
06-12-2006, 14:02
Thanks for the response that gives me a place to start
re -------------- Original message from Curt Sprenger -------------- BE SURE there is good ground at meters. Is voltage/amps present at the guages (wires at the guages)? If so, I'd think the guages are bad. If no voltage/amps then go back to the source, the alternator/regulator and check there, maybe the wires are loose. Hope this helps. Others will join in and add to this. Good luck. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. putneyflash wrote: > when the engine is running neither my engine volmeter or amp meter > show a charge or movement. I know the system works because my battries > stay charged up.I would like to have them working. Any thoughts?? > re brake 1983 FC-35 SB > > [Non-text portions of this message have been removed] |
