Back Up Camera
08-27-2006, 09:37
Back Up Camera
Having worked over half my career at a railroad, I simply trained my
dear wife in the art of railway hand signals. It gets interesting when she gives the "kick car free" signal when unhooking the toad.... Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Aug 27, 2006, at 10:59 AM, one_dusty_hoot wrote: > Cheap walkie talkies, DON'T talk unless you KNOW I > am going to hit something. > Bob Janes > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > >> >> Rob, is it worth an upgrade from the factory B&W system? and is > there >> a way to get intercom to enhance voice contact with >> lookout 'ComeOnBack' person? >> >> When I back up my Dumptruck and trailer I get out and take a walk >> around then I place a mini cone next to landmarks. Never do I hit a >> thing, no camera, life is stressfree and easy. However backing up >> the bus is very stressful as the copilot says "I'll look" and my > walk >> around review would spark a 'you have no trust debate'. Who wants > to >> start a trip this way. >> As I back up I hear "a little to the right". My question is "my >> right or your right" Then I hear "we are facing the same way what > do >> you think". I respond "I shouldn't be thinking, you are directing >> me, just point, damit" Then I see clearly in the monitor a single >> digit reply. This is the only time I can see a command as every >> other time he is in view of a mirror or the camera and only an arm >> in one and a torso in the other. >> >> Then a new sign language, hands to the side, what's that mean? As >> he starts to push on the bumper I realize the Umpire SAFE sign L is >> equivalent to Bus driver STOP sign L. Then the walk to the drivers >> window. The pace is reminiscent of an Umpite walk to the mound, > does >> the repeated over exaggerated 'He's safe motion' evoke a Baseball >> authority ambition in someone? As he approaches I adjust my cup > and >> wait for his first pitch. The co pilot says "when I do this ( he >> motions safe)it means stop". I hold my arms out forward, thumbs > side >> by side, palms facing him and say "I thought this meant stop". He >> replies "that means, Ouh - hay - Beep -Beep, are you wearing > double >> knit polyester or something". I reply "What?, are you Donna > Sommers >> now?, this aint a Prevost, no Discoball hanging in the galley". I >> then jump out of my seat, take a walk around, place some landmark >> indicators and back the bus in safe. I often wondered if the >> nightstand placed rear and center was a selling feature in the >> classic FC's, prompted by backup /setup anxiety. >> >> GregoryO'Connor >> 94ptRomolandCA >> --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" >> >>> >>> Greg here are the specs for the particular system I bought...... >>> >>> >>> >>> *Complete Specs for 68-CHNV* >>> *Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" > CCD >> CCD >>> Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines >> Horizontal >>> Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System >> 2:1 >>> Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC > System >>> Internal Signal >>> to Noise Ratio better than 48dB Electronic Shutter >>> (NTSC)1/60-1/100,000 sec. Gamma >>> Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite > video >> at 75 >>> ohm Backlight Compensation Automatic Gain Control AGC Power > Supply >> DC 12V >>> (+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F >> Operation >>> Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° >> Ver/Hor >>> Construction Aluminum, with painted finish Dimensions 3.75"w x >> 3.20"h x 2.64 >>> "d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions >> (6.8) 6.77"W >>> x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of >> Pixels >>> 268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234 > (V) >>> System Selectable >>> NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power > Source >>> DC 12V Operation >>> Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 ° > F >> Power >>> Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video >>> >>> >>> On 26/08/06, Gregory OConnor >>>> >>>> Rob,COLOUR monitor are they 50 Hertz? >>>> GregoryO'Connor >>>> 94pt >>>> NotFromNiceville >>>> >>>> --- In WanderlodgeForum@yahoogroups.com >>>> "Rob Robinson" >>>> >>>> >>>>> >>>>> I concur with the recommendation of http://www.rvcams.com Tim helped > me >>>> immensely. >>>>> For around $400 I put in a colour flat panel monitor and new >> rear >>>> camera. I >>>>> used existing coaxial cable with a Radio Shack S/Coax > adapter. I >>>> have >>>>> pictures of dash install and rear camera install if > interested. >>>>> >>>>> On 25/08/06, Randy Merrill >>>>>> >>>>>> Hi, >>>>>> >>>>>> I need to replace my Sanyo VDC 2512 black/white back up >> camera. I >>>> have >>>>>> done a web search and can't find that exact model number. > Can >>>> anyone >>>>>> tell me where I can find a Sanyo replacement or recommend >> another >>>>>> comparable camera? I don't have time to be modifying the box >>>> where the >>>>>> camera sits, so I need something that will mount like the >> Sanyo. >>>>>> >>>>>> Any help will be greatly appreciated. >>>>>> >>>>>> Randy Merrill >>>>>> 1993 WLWB >>>>>> Ocala, Florida >>>>>> >>>>>> >>>>>> >>>>> >>>>> >>>>> >>>>> -- >>>>> Rob, Sue & Merlin Robinson >>>>> 94 WLWB >>>>> >>>>> >>>>> [Non-text portions of this message have been removed] >>>>> >>>> >>>> >>>> >>> >>> >>> >>> -- >>> Rob, Sue & Merlin Robinson >>> 94 WLWB >>> >>> >>> [Non-text portions of this message have been removed] >>> >> > > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] |
08-27-2006, 13:04
Back Up Camera
Pete,
What is the railroad signal for âa little to the leftâ? Gardner 78FC33 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Pete Masterson Sent: Sunday, August 27, 2006 5:37 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Back Up Camera Having worked over half my career at a railroad, I simply trained my dear wife in the art of railway hand signals. It gets interesting when she gives the "kick car free" signal when unhooking the toad.... Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Aug 27, 2006, at 10:59 AM, one_dusty_hoot wrote: > Cheap walkie talkies, DON'T talk unless you KNOW I > am going to hit something. > Bob Janes > > --- In WanderlodgeForum@yahoogroups.com > >> >> Rob, is it worth an upgrade from the factory B&W system? and is > there >> a way to get intercom to enhance voice contact with >> lookout 'ComeOnBack' person? >> >> When I back up my Dumptruck and trailer I get out and take a walk >> around then I place a mini cone next to landmarks. Never do I hit a >> thing, no camera, life is stressfree and easy. However backing up >> the bus is very stressful as the copilot says "I'll look" and my > walk >> around review would spark a 'you have no trust debate'. Who wants > to >> start a trip this way. >> As I back up I hear "a little to the right". My question is "my >> right or your right" Then I hear "we are facing the same way what > do >> you think". I respond "I shouldn't be thinking, you are directing >> me, just point, damit" Then I see clearly in the monitor a single >> digit reply. This is the only time I can see a command as every >> other time he is in view of a mirror or the camera and only an arm >> in one and a torso in the other. >> >> Then a new sign language, hands to the side, what's that mean? As >> he starts to push on the bumper I realize the Umpire SAFE sign L is >> equivalent to Bus driver STOP sign L. Then the walk to the drivers >> window. The pace is reminiscent of an Umpite walk to the mound, > does >> the repeated over exaggerated 'He's safe motion' evoke a Baseball >> authority ambition in someone? As he approaches I adjust my cup > and >> wait for his first pitch. The co pilot says "when I do this ( he >> motions safe)it means stop". I hold my arms out forward, thumbs > side >> by side, palms facing him and say "I thought this meant stop". He >> replies "that means, Ouh - hay - Beep -Beep, are you wearing > double >> knit polyester or something". I reply "What?, are you Donna > Sommers >> now?, this aint a Prevost, no Discoball hanging in the galley". I >> then jump out of my seat, take a walk around, place some landmark >> indicators and back the bus in safe. I often wondered if the >> nightstand placed rear and center was a selling feature in the >> classic FC's, prompted by backup /setup anxiety. >> >> GregoryO'Connor >> 94ptRomolandCA >> --- In WanderlodgeForum@yahoogroups.com >> >>> >>> Greg here are the specs for the particular system I bought...... >>> >>> >>> >>> *Complete Specs for 68-CHNV* >>> *Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" > CCD >> CCD >>> Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines >> Horizontal >>> Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System >> 2:1 >>> Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC > System >>> Internal Signal >>> to Noise Ratio better than 48dB Electronic Shutter >>> (NTSC)1/60-1/100,000 sec. Gamma >>> Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite > video >> at 75 >>> ohm Backlight Compensation Automatic Gain Control AGC Power > Supply >> DC 12V >>> (+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F >> Operation >>> Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° >> Ver/Hor >>> Construction Aluminum, with painted finish Dimensions 3.75"w x >> 3.20"h x 2.64 >>> "d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions >> (6.8) 6.77"W >>> x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of >> Pixels >>> 268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234 > (V) >>> System Selectable >>> NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power > Source >>> DC 12V Operation >>> Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 ° > F >> Power >>> Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video >>> >>> >>> On 26/08/06, Gregory OConnor >>>> >>>> Rob,COLOUR monitor are they 50 Hertz? >>>> GregoryO'Connor >>>> 94pt >>>> NotFromNiceville >>>> >>>> --- In WanderlodgeForum@yahoogroups.com >>>> "Rob Robinson" >>>> >>>> >>>>> >>>>> I concur with the recommendation of http://www.rvcams.com Tim helped > me >>>> immensely. >>>>> For around $400 I put in a colour flat panel monitor and new >> rear >>>> camera. I >>>>> used existing coaxial cable with a Radio Shack S/Coax > adapter. I >>>> have >>>>> pictures of dash install and rear camera install if > interested. >>>>> >>>>> On 25/08/06, Randy Merrill >>>>>> >>>>>> Hi, >>>>>> >>>>>> I need to replace my Sanyo VDC 2512 black/white back up >> camera. I >>>> have >>>>>> done a web search and can't find that exact model number. > Can >>>> anyone >>>>>> tell me where I can find a Sanyo replacement or recommend >> another >>>>>> comparable camera? I don't have time to be modifying the box >>>> where the >>>>>> camera sits, so I need something that will mount like the >> Sanyo. >>>>>> >>>>>> Any help will be greatly appreciated. >>>>>> >>>>>> Randy Merrill >>>>>> 1993 WLWB >>>>>> Ocala, Florida >>>>>> >>>>>> >>>>>> >>>>> >>>>> >>>>> >>>>> -- >>>>> Rob, Sue & Merlin Robinson >>>>> 94 WLWB >>>>> >>>>> >>>>> [Non-text portions of this message have been removed] >>>>> >>>> >>>> >>>> >>> >>> >>> >>> -- >>> Rob, Sue & Merlin Robinson >>> 94 WLWB >>> >>> >>> [Non-text portions of this message have been removed] >>> >> > > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-27-2006, 13:46
Back Up Camera
On the railroad, we just set the switch.... with the bird, my wife
points in the direction to go. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Aug 27, 2006, at 6:04 PM, Gardner Yeaw wrote: > Pete, > What is the railroad signal for âa little to the leftâ? > > Gardner > 78FC33 > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Pete Masterson > Sent: Sunday, August 27, 2006 5:37 PM > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Re: Back Up Camera > > Having worked over half my career at a railroad, I simply trained my > dear wife in the art of railway hand signals. It gets interesting > when she gives the "kick car free" signal when unhooking the toad.... > > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 4203 > El Sobrante, CA > > On Aug 27, 2006, at 10:59 AM, one_dusty_hoot wrote: > >> Cheap walkie talkies, DON'T talk unless you KNOW I >> am going to hit something. >> Bob Janes >> >> --- In WanderlodgeForum@yahoogroups.com > >> >>> >>> Rob, is it worth an upgrade from the factory B&W system? and is >> there >>> a way to get intercom to enhance voice contact with >>> lookout 'ComeOnBack' person? >>> >>> When I back up my Dumptruck and trailer I get out and take a walk >>> around then I place a mini cone next to landmarks. Never do I hit a >>> thing, no camera, life is stressfree and easy. However backing up >>> the bus is very stressful as the copilot says "I'll look" and my >> walk >>> around review would spark a 'you have no trust debate'. Who wants >> to >>> start a trip this way. >>> As I back up I hear "a little to the right". My question is "my >>> right or your right" Then I hear "we are facing the same way what >> do >>> you think". I respond "I shouldn't be thinking, you are directing >>> me, just point, damit" Then I see clearly in the monitor a single >>> digit reply. This is the only time I can see a command as every >>> other time he is in view of a mirror or the camera and only an arm >>> in one and a torso in the other. >>> >>> Then a new sign language, hands to the side, what's that mean? As >>> he starts to push on the bumper I realize the Umpire SAFE sign L is >>> equivalent to Bus driver STOP sign L. Then the walk to the drivers >>> window. The pace is reminiscent of an Umpite walk to the mound, >> does >>> the repeated over exaggerated 'He's safe motion' evoke a Baseball >>> authority ambition in someone? As he approaches I adjust my cup >> and >>> wait for his first pitch. The co pilot says "when I do this ( he >>> motions safe)it means stop". I hold my arms out forward, thumbs >> side >>> by side, palms facing him and say "I thought this meant stop". He >>> replies "that means, Ouh - hay - Beep -Beep, are you wearing >> double >>> knit polyester or something". I reply "What?, are you Donna >> Sommers >>> now?, this aint a Prevost, no Discoball hanging in the galley". I >>> then jump out of my seat, take a walk around, place some landmark >>> indicators and back the bus in safe. I often wondered if the >>> nightstand placed rear and center was a selling feature in the >>> classic FC's, prompted by backup /setup anxiety. >>> >>> GregoryO'Connor >>> 94ptRomolandCA >>> --- In WanderlodgeForum@yahoogroups.com > >>> >>>> >>>> Greg here are the specs for the particular system I bought...... >>>> >>>> >>>> >>>> *Complete Specs for 68-CHNV* >>>> *Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" >> CCD >>> CCD >>>> Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines >>> Horizontal >>>> Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System >>> 2:1 >>>> Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC >> System >>>> Internal Signal >>>> to Noise Ratio better than 48dB Electronic Shutter >>>> (NTSC)1/60-1/100,000 sec. Gamma >>>> Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite >> video >>> at 75 >>>> ohm Backlight Compensation Automatic Gain Control AGC Power >> Supply >>> DC 12V >>>> (+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F >>> Operation >>>> Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° >>> Ver/Hor >>>> Construction Aluminum, with painted finish Dimensions 3.75"w x >>> 3.20"h x 2.64 >>>> "d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions >>> (6.8) 6.77"W >>>> x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of >>> Pixels >>>> 268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234 >> (V) >>>> System Selectable >>>> NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power >> Source >>>> DC 12V Operation >>>> Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 ° >> F >>> Power >>>> Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video >>>> >>>> >>>> On 26/08/06, Gregory OConnor >>>>> >>>>> Rob,COLOUR monitor are they 50 Hertz? >>>>> GregoryO'Connor >>>>> 94pt >>>>> NotFromNiceville >>>>> >>>>> --- In WanderlodgeForum@yahoogroups.com > >>>>> "Rob Robinson" >>>>> >>>>> >>>>>> >>>>>> I concur with the recommendation of http://www.rvcams.com Tim helped >> me >>>>> immensely. >>>>>> For around $400 I put in a colour flat panel monitor and new >>> rear >>>>> camera. I >>>>>> used existing coaxial cable with a Radio Shack S/Coax >> adapter. I >>>>> have >>>>>> pictures of dash install and rear camera install if >> interested. >>>>>> >>>>>> On 25/08/06, Randy Merrill >>>>>>> >>>>>>> Hi, >>>>>>> >>>>>>> I need to replace my Sanyo VDC 2512 black/white back up >>> camera. I >>>>> have >>>>>>> done a web search and can't find that exact model number. >> Can >>>>> anyone >>>>>>> tell me where I can find a Sanyo replacement or recommend >>> another >>>>>>> comparable camera? I don't have time to be modifying the box >>>>> where the >>>>>>> camera sits, so I need something that will mount like the >>> Sanyo. >>>>>>> >>>>>>> Any help will be greatly appreciated. >>>>>>> >>>>>>> Randy Merrill >>>>>>> 1993 WLWB >>>>>>> Ocala, Florida >>>>>>> >>>>>>> >>>>>>> >>>>>> >>>>>> >>>>>> >>>>>> -- >>>>>> Rob, Sue & Merlin Robinson >>>>>> 94 WLWB >>>>>> >>>>>> >>>>>> [Non-text portions of this message have been removed] >>>>>> >>>>> >>>>> >>>>> >>>> >>>> >>>> >>>> -- >>>> Rob, Sue & Merlin Robinson >>>> 94 WLWB >>>> >>>> >>>> [Non-text portions of this message have been removed] >>>> >>> >> >> >> >> >> >> >> >> Yahoo! Groups Links >> >> >> >> >> >> >> > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] |
08-27-2006, 14:39
Back Up Camera
Just tell the teddy bear to ride the brake and tell her to tie it
down when it goes on the clear. just make sure no other tracks are foul you wouldn't want a sideswipe Stephen 77fc35 first up and available yuck --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Having worked over half my career at a railroad, I simply trained my > dear wife in the art of railway hand signals. It gets interesting > when she gives the "kick car free" signal when unhooking the toad.... > > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 4203 > El Sobrante, CA > > > > > On Aug 27, 2006, at 10:59 AM, one_dusty_hoot wrote: > > > Cheap walkie talkies, DON'T talk unless you KNOW I > > am going to hit something. > > Bob Janes > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > >> > >> Rob, is it worth an upgrade from the factory B&W system? and is > > there > >> a way to get intercom to enhance voice contact with > >> lookout 'ComeOnBack' person? > >> > >> When I back up my Dumptruck and trailer I get out and take a walk > >> around then I place a mini cone next to landmarks. Never do I hit a > >> thing, no camera, life is stressfree and easy. However backing up > >> the bus is very stressful as the copilot says "I'll look" and my > > walk > >> around review would spark a 'you have no trust debate'. Who wants > > to > >> start a trip this way. > >> As I back up I hear "a little to the right". My question is "my > >> right or your right" Then I hear "we are facing the same way what > > do > >> you think". I respond "I shouldn't be thinking, you are directing > >> me, just point, damit" Then I see clearly in the monitor a single > >> digit reply. This is the only time I can see a command as every > >> other time he is in view of a mirror or the camera and only an arm > >> in one and a torso in the other. > >> > >> Then a new sign language, hands to the side, what's that mean? As > >> he starts to push on the bumper I realize the Umpire SAFE sign L is > >> equivalent to Bus driver STOP sign L. Then the walk to the drivers > >> window. The pace is reminiscent of an Umpite walk to the mound, > > does > >> the repeated over exaggerated 'He's safe motion' evoke a Baseball > >> authority ambition in someone? As he approaches I adjust my cup > > and > >> wait for his first pitch. The co pilot says "when I do this ( he > >> motions safe)it means stop". I hold my arms out forward, thumbs > > side > >> by side, palms facing him and say "I thought this meant stop". He > >> replies "that means, Ouh - hay - Beep -Beep, are you wearing > > double > >> knit polyester or something". I reply "What?, are you Donna > > Sommers > >> now?, this aint a Prevost, no Discoball hanging in the galley". I > >> then jump out of my seat, take a walk around, place some landmark > >> indicators and back the bus in safe. I often wondered if the > >> nightstand placed rear and center was a selling feature in the > >> classic FC's, prompted by backup /setup anxiety. > >> > >> GregoryO'Connor > >> 94ptRomolandCA > >> --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > >> > >>> > >>> Greg here are the specs for the particular system I bought...... > >>> > >>> > >>> > >>> *Complete Specs for 68-CHNV* > >>> *Camera Specs:* TV System NTSC Image Sensor Panasonic 1/4" > > CCD > >> CCD > >>> Effective Pixels (NTSC)510(H) x 492(V) Resolution 380 TV lines > >> Horizontal > >>> Sync Frequency EIA: 15.750 khz -- CCIR:15.625 khz Scanning System > >> 2:1 > >>> Interlace Sensitivity 0 lux (IR On), with >30' IR Range SYNC > > System > >>> Internal Signal > >>> to Noise Ratio better than 48dB Electronic Shutter > >>> (NTSC)1/60-1/100,000 sec. Gamma > >>> Correction 0.45 Lens f 2.5 mm Video Output 1.0 Vp-p composite > > video > >> at 75 > >>> ohm Backlight Compensation Automatic Gain Control AGC Power > > Supply > >> DC 12V > >>> (+/-10%), 125 ma Weight 480 gr Storage Temperature -22°F to 140°F > >> Operation > >>> Temperature 32°F to 122°F View Angle 130° diagonally -- 78°/104° > >> Ver/Hor > >>> Construction Aluminum, with painted finish Dimensions 3.75"w x > >> 3.20"h x 2.64 > >>> "d *Monitor Specs:* Display TFT Color LCD Exterior Dimensions > >> (6.8) 6.77"W > >>> x 5.6"H x 1.25"D Display Dimensions 5-7/16" W x 4-1/8"H Number of > >> Pixels > >>> 268,568 Screen Size 6.8" Diagonally LCD Display Dots 1152(H)x234 > > (V) > >>> System Selectable > >>> NTSC or PAL Input Signal 1.0 V p-p Composite at 75 ohms Power > > Source > >>> DC 12V Operation > >>> Temperature 23 °F to 122 °F Storage Temperature -13 °F to 158 ° > > F > >> Power > >>> Consumption 6 watts max Weight 1.05 lbs Inputs 2 audio/video > >>> > >>> > >>> On 26/08/06, Gregory OConnor > >>>> > >>>> Rob,COLOUR monitor are they 50 Hertz? > >>>> GregoryO'Connor > >>>> 94pt > >>>> NotFromNiceville > >>>> > >>>> --- In WanderlodgeForum@yahoogroups.com > >>>> "Rob Robinson" > >>>> > >>>> > >>>>> > >>>>> I concur with the recommendation of http://www.rvcams.com Tim helped > > me > >>>> immensely. > >>>>> For around $400 I put in a colour flat panel monitor and new > >> rear > >>>> camera. I > >>>>> used existing coaxial cable with a Radio Shack S/Coax > > adapter. I > >>>> have > >>>>> pictures of dash install and rear camera install if > > interested. > >>>>> > >>>>> On 25/08/06, Randy Merrill > >>>>>> > >>>>>> Hi, > >>>>>> > >>>>>> I need to replace my Sanyo VDC 2512 black/white back up > >> camera. I > >>>> have > >>>>>> done a web search and can't find that exact model number. > > Can > >>>> anyone > >>>>>> tell me where I can find a Sanyo replacement or recommend > >> another > >>>>>> comparable camera? I don't have time to be modifying the box > >>>> where the > >>>>>> camera sits, so I need something that will mount like the > >> Sanyo. > >>>>>> > >>>>>> Any help will be greatly appreciated. > >>>>>> > >>>>>> Randy Merrill > >>>>>> 1993 WLWB > >>>>>> Ocala, Florida > >>>>>> > >>>>>> > >>>>>> > >>>>> > >>>>> > >>>>> > >>>>> -- > >>>>> Rob, Sue & Merlin Robinson > >>>>> 94 WLWB > >>>>> > >>>>> > >>>>> [Non-text portions of this message have been removed] > >>>>> > >>>> > >>>> > >>>> > >>> > >>> > >>> > >>> -- > >>> Rob, Sue & Merlin Robinson > >>> 94 WLWB > >>> > >>> > >>> [Non-text portions of this message have been removed] > >>> > >> > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
08-27-2006, 14:39
Back Up Camera
08-31-2006, 02:00
Back Up Camera
> > I concur with the recommendation of http://www.rvcams.com Tim helped me immensely. > For around $400 I put in a colour flat panel monitor and new rear camera. I > used existing coaxial cable with a Radio Shack S/Coax adapter. I have > pictures of dash install and rear camera install if interested. > > On 25/08/06, Randy Merrill Howdy, Randy. I would really like to see those pictures, please. Thanks, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40, in Fort Worth, TX |
