Ceiling panel question
09-18-2006, 01:40
One my ceiling panels must have been cut a little short at the factory. There
is a section of
about 18 inches that is not captured by the plastic trim strip that goes
betweeen panels.
Various fixes had been tried by previous owners including construction adhesive
under th
panel and caulk on top of it. The ideal solution would be wider trim strip.
Does anyone
know if a wider strip is available. If not, anyone have any suggestions for
stopping it from
drooping down in that one section?
Kerry
82 FC 35
Denver
09-18-2006, 07:45
Kerry- in the flooring business we use a metal track and a snap in vinyl
insert. You can get some Chem-rex adhesive and glue the track in place. Wait a
day
and cut the vinyl insert and snap it in with a hammer. You can find this
stuff at a floor covering supply house.
83 PT40
Livingston, Montana
09-18-2006, 17:05
Trim strips are available from BB. Call Earl Davis at BB Parts. As I recall
they are in 90" lengths and cost about $6 each.
Sent: Monday, September 18, 2006 6:40 AM
Subject: [WanderlodgeForum] Ceiling panel question
is a section of
betweeen panels.
adhesive under th
Does anyone
stopping it from
Kerry
82 FC 35
Denver
