Engine Alternator overcharging
07-16-2007, 17:42
Yes I think I have gotten to them all since I bought it but every
once in awhile I find another connection. I know a bad ground was causing problems with my retarder until I found that one. Jim Matus 84FC35 Rescue CA - -- In WanderlodgeForum@yahoogroups.com, "ac7880" wrote: > > Have you checked all grounds on the coach (battery, frame, etc?) > > Insecure grounds can do strange things to apparently unrelated > components. > Dan > 94 BMC 37' > --- In WanderlodgeForum@yahoogroups.com, "jim matus" > wrote: > > > > I did that and it charged ok but after I hooked it up with the > sense > > wire it started overcharging and now it overcharges no matter how > you > > connect it so I guess the regulator blew again. Jim Matus 84FC35 > > Rescue > CA -- > > - In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > > > > > Try jumping the alternator's sense wire to the battery positive > > terminal. > > > Your sense wire might be disconnected or degraded resulting in > high > > > resistance. > > > > > > David Brady > > > '02 LXi, Smokey > > > NC > > > > > > jim matus wrote: > > > > > > > > I am having a problem with my Leece-Neville alternator > > overcharging. I > > > > had it rebuilt as preventive maint.,it woked ok for about 800- > 1000 > > > > miles then it started over charging 15-15.5 volts & 80- 100amps. > I > > took > > > > it back to the rebuilder and they said the regulator was bad so > > they > > > > replaced it. They told me to check the voltage to the small + > post > > > > under the regulator. I was getting about .75 of a volt less than > > > > battery voltage as measured at the big + post. I could not find > > where > > > > the volt drop was so I ran a new wire from the ignition operated > > > > solinoid above the throttle pedal. The alternator is still > > > > overcharging. We are supposed to leave on Friday for a 4000 > mile > > trip > > > > so this is a big problem. Did Bluebird use a special regulator > > since > > > > they have Batt. power to the alternator all of the time? The > > rebuilder > > > > may have installed the wrong regulator. Thanks Jim Matus 84FC35 > > Rescue > > > > CA > > > > > > > > > > > > -------------------------------------------------------------- -- > -- > > ------ > > > > > > > > No virus found in this incoming message. > > > > Checked by AVG Free Edition. > > > > Version: 7.5.476 / Virus Database: 269.10.6/900 - Release Date: > > 7/14/2007 3:36 PM > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > |
