no fuel
09-30-2007, 04:04
no fuel
The fuel shutoff solenoid is located just above the injection pump which is
in the forward end of the V-8 s valley. It requires 12 volts to operate, (open to allow fuel). Absence of the 12 volts will not allow fuel to the injection pump hence no start. Assuming that you have fuel in the filter you haven't just changed the filter have you? Then, the solenoid is where I would start. Steve Anderson 79 FC 35 Poulsbo, Wa. In a message dated 9/30/2007 11:30:47 AM Pacific Daylight Time, drdigger@... writes: I am still trying to get my 83 to start. Engine spins and will start with a shot of wd40, but am getting no fuel from to the injectors to the cylinders. Where would the pump be, or the device , solenoid or whatever makes the pump run? Is there a separate fused circuit between the ignition switch and the pump? Any other ideas? DrDigger 83 FC35 Kansas City, mo [Non-text portions of this message have been removed] ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-30-2007, 06:28
no fuel
of wd40, but am getting no fuel from to the injectors to the cylinders. Where would the pump be, or the device , solenoid or whatever makes the pump run? Is there a separate fused circuit between the ignition switch and the pump? Any other ideas? DrDigger 83 FC35 Kansas City, mo [Non-text portions of this message have been removed] |
10-01-2007, 11:56
no fuel
Are we talking about a 3208? if so make sure the fuel shut off solenoid is
working, it should click when you turn on the key. if it diesn't you can remove the solenoid and pull up on the fuel rack with your finger she should start right now. to stop push down. to stop. I am assumimg youdo have fuel and the service assembly doesn't need to be bleed. f so let me know. A 3208 usually starts in just a few turns if she's going to run. -------------- Original message from "g" -------------- I am still trying to get my 83 to start. Engine spins and will start with a shot of wd40, but am getting no fuel from to the injectors to the cylinders. Where would the pump be, or the device , solenoid or whatever makes the pump run? Is there a separate fused circuit between the ignition switch and the pump? Any other ideas? DrDigger 83 FC35 Kansas City, mo [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
10-01-2007, 11:58
no fuel
Me again: if its a 3208 what is your telephone number?
re -------------- Original message from "g" -------------- I am still trying to get my 83 to start. Engine spins and will start with a shot of wd40, but am getting no fuel from to the injectors to the cylinders. Where would the pump be, or the device , solenoid or whatever makes the pump run? Is there a separate fused circuit between the ignition switch and the pump? Any other ideas? DrDigger 83 FC35 Kansas City, mo [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
10-01-2007, 13:37
no fuel
It is a 3208 and one of the problems has been finding the actual locations of
the fuel pump and the solenoid. Mike, Randy and the guys have given me some direction there, so with my trusty meter and a set of spare hands( my pal doesn't know I'planning to use his hands) I can ring that circuit out and hopefully get this PROPERLY repaired and a test button installed. My # is 8166786227 Glenn ----- Original Message ----- From: putneyflash@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, October 01, 2007 6:58 PM Subject: Re: [WanderlodgeForum] no fuel Me again: if its a 3208 what is your telephone number? re -------------- Original message from "g" -------------- I am still trying to get my 83 to start. Engine spins and will start with a shot of wd40, but am getting no fuel from to the injectors to the cylinders. Where would the pump be, or the device , solenoid or whatever makes the pump run? Is there a separate fused circuit between the ignition switch and the pump? Any other ideas? DrDigger 83 FC35 Kansas City, mo [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
10-02-2007, 14:05
no fuel
When you open the cover the service assembly sits in the vee of the engine
should be a solenoid standing stright up forward of the air cleaner. it should click when the key is turned on.the fuel lines run from the assembly to the injectors.there is usually a bleed screw or pitcock on top of the pump. if you pump with the hand primeing pump you should get fuel out the bleed screw -------------- Original message from "g" -------------- It is a 3208 and one of the problems has been finding the actual locations of the fuel pump and the solenoid. Mike, Randy and the guys have given me some direction there, so with my trusty meter and a set of spare hands( my pal doesn't know I'planning to use his hands) I can ring that circuit out and hopefully get this PROPERLY repaired and a test button installed. My # is 8166786227 Glenn ----- Original Message ----- From: putneyflash@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, October 01, 2007 6:58 PM Subject: Re: [WanderlodgeForum] no fuel Me again: if its a 3208 what is your telephone number? re -------------- Original message from "g" -------------- I am still trying to get my 83 to start. Engine spins and will start with a shot of wd40, but am getting no fuel from to the injectors to the cylinders. Where would the pump be, or the device , solenoid or whatever makes the pump run? Is there a separate fused circuit between the ignition switch and the pump? Any other ideas? DrDigger 83 FC35 Kansas City, mo [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
10-25-2007, 13:44
no fuel
I had a similar problem recently; turned out to be a poor connection
at ignition switch which in turn prevented fuel pump (above front of fuel tank) from working. Vibration over time had caused loose connection to scorch a bit. It would start if voltage was in the 14V range but not below. Installed new wire and connections to ignition switch solving problem. There is another solenoid on frame behind curbside battery slide you might also check, which connects to main starter solenoid. John Barry 88FC Song Bird Carlsbad, NM--- In WanderlodgeForum@yahoogroups.com, putneyflash@... wrote: > > When you open the cover the service assembly sits in the vee of the engine should be a solenoid standing stright up forward of the air cleaner. it should click when the key is turned on.the fuel lines run from the assembly to the injectors.there is usually a bleed screw or pitcock on top of the pump. if you pump with the hand primeing pump you should get fuel out the bleed screw > > -------------- Original message from "g" --- > > > > It is a 3208 and one of the problems has been finding the actual locations of the fuel pump and the solenoid. Mike, Randy and the guys have given me some > direction there, so with my trusty meter and a set of spare hands( my pal doesn't know I'planning to use his hands) I can ring that circuit out and hopefully get this PROPERLY repaired and a test button installed. My # is 8166786227 > Glenn > ----- Original Message ----- > From: putneyflash@... > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, October 01, 2007 6:58 PM > Subject: Re: [WanderlodgeForum] no fuel > > Me again: if its a 3208 what is your telephone number? > re > > -------------- Original message from "g" --- > > I am still trying to get my 83 to start. Engine spins and will start with a shot of wd40, but am getting no fuel from to the injectors to the cylinders. Where would the pump be, or the device , solenoid or whatever makes the pump run? Is there a separate fused circuit between the ignition switch and the pump? Any other ideas? > > DrDigger > 83 FC35 > Kansas City, mo > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > > > > [Non-text portions of this message have been removed] > |
