ZF Transmission filters
03-06-2008, 11:54
I want to change the tranny oil and the filter in our 88 FC ( ZF
transmission. I have 2 questions.: I think the filter is a ZF 4139298038. Where can I obtain one?? How much ATF will I need? My Blue Box says the capacity is 47 quarts but obviously you cannot drain much of the oil. I seem to recall a post some time ago where it was listed as 5 gallons. Any help appreciated. Bruce 1988 FC |
03-06-2008, 13:32
Bruce,
I just had my ZF filter changed yesterday at our local Peterbilt dealer, I know they used a 5 gallon pail of Dextron but I don't have the filter number with me it is on the bus in storage. If we don't get the 9" snow storm tonight I'll ride by the bus tomorrow and check my receipt for the filter number. John - 88FC35 - Louisville, KY |
03-06-2008, 13:51
Bruce
You are right on the ZF # & the 5 gal is right to. I get mine from Precision Transmission in Colmar, PA Phone 215- 822-8300 I have also got them from Harbor Diesel and Equipment in Long Beach, CA Phone 562-591-5665 The only way you can get more fluid out is by draining the cooler. Don Spithaler 89 Sp 36' Butler. PA In Zephyrhills, FL On Thu, Mar 6, 2008 at 6:54 PM, birdshill123 > > > > > > > I want to change the tranny oil and the filter in our 88 FC ( ZF > transmission. I have 2 questions.: I think the filter his a > 4139298038. Where can I obtain one?? How much ATF will I need? My Blue > Box says the capacity is 47 quarts but obviously you cannot drain much > of the oil. I seem to recall a post some time ago where it was listed > as 5 gallons. Any help appreciated. > > Bruce > > 1988 FC > > |
03-06-2008, 14:54
Thank you John.
Bruce 1988FC |
03-06-2008, 14:56
I found that filter online made by Fleetguard ( Cummins) for around
$28.00. Someone told me it sells for over $50.00 Youch!! Is that correct?? Thanks Bruce 1988 FC35 |
03-06-2008, 14:59
I almost forgot: Where did you get the pan gasket? Or did you reuse
the old one? Bruce 1988 FC35 |
03-06-2008, 15:46
No need to remove the pan , just a plug and the filter, I used the
real German filter, about $35/40. filter gasket included. It is a mesh screen some just wash it out with fuel. Service centers locations at http://www.zf.com. Or try this cut and paste. http://www.zf.com/content/en/import/zf_k...ice/firmen verzeichnis/servicenetzwerk/ServiceNetzwerk_Ergebnis.jsp? lookup=2260&lookupLeg=8757 Drains just under 5 gallons, Holds a total of about 8 gallons This is the only instance, that I have ever used synthetic, Castrol, Transydn. about $35/gallon. Hopeing this handles the heat better. Wait two years and changed it again, now mostly Synthetic. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I almost forgot: Where did you get the pan gasket? Or did you reuse > the old one? > > Bruce > 1988 FC35 > |
03-07-2008, 02:03
THanks Bill.
Bruce |
