My side view mirror quit working.
03-12-2008, 17:07
The main mirror on my right side view mirror has quit being able to be
adjusted electrically. I can hear the motor(s)run but the mirror does not move in response to the motor running. The mirror is not jammed/bound up. I can adjust the mirror manually. It just does not respond electrically. Does anyone have a recommendation that I can try? Is there some safety coupling that disengages? It's not clear to me how to take the mirror assembly apart. Any thought would be appreciated. Eric Perplies currently in Boulder City, NV 96' 42' WBWL |
03-13-2008, 02:33
My mirror parts are velcrowed on.(if velcrowed is considered a
participle verb) The convex mirror is easier to pull off. I leaned the convex part to view the velcrow tape on its back then worked a hard plastic butter knife between the velcrow parts. The tech support at the mfg is great I believe it is Ramco 800-321-4819?? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Eric Perplies" > > The main mirror on my right side view mirror has quit being able to be > adjusted electrically. I can hear the motor(s)run but the mirror does > not move in response to the motor running. The mirror is not > jammed/bound up. I can adjust the mirror manually. It just does not > respond electrically. > > Does anyone have a recommendation that I can try? Is there some > safety coupling that disengages? It's not clear to me how to take the > mirror assembly apart. Any thought would be appreciated. > > Eric Perplies > currently in Boulder City, NV > 96' 42' WBWL > |
