Alcoa Wheels
03-23-2008, 07:19
Post: #21
Alcoa Wheels
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
wrote: > > Well I have them home. They're nice but of course not like new and not > polished the why a proud BB's owner would like them. I > started "working" on one of them and I just don't think I have it in me > to do four of them. I suppose it I have to do it myself I will but > does anyone know of a professional wheel shop or a way to have them > done professionally. A location in the Pa Maryland area would be > helpful since shipping could get pricy. I searched on the net and only > found a place in BC which out of reach. > > John Heckman > central Pa > 1973 FC > John I would use the yellow pages for truck tires and rims. We have a place over in tacoma that deals in truck tires and I noticed that they also had rims. I observered a guy in the tire bay polishing rims and so that is why I said you could contact a large tire outfit that handles truck tires in your area. Jon |
03-23-2008, 15:20
Post: #22
Alcoa Wheels
John,
I worked my fingers to the bone, wore out my 3/8 drill I have had for 40 years, and the wheels are far from done. Mine are probably like yours, lots of pits. Find a pro, that is what I will probably do after correcting the other things on my coach. See you at Maxton. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Thanks Shane, I'll check both of those out Monday. My fingers and > hands are sore from my efforts. Not a good thing for my day job. I > would have to start with something a lot more aggressive then 400 or > I would attempt it. So considering the point at which I am starting > and the results I would like to have I better get some help. Same > ole story know your limits. The wheels are decent but there are some > pits. I actually think from what I've been able to find on the web > that the professionals turn them on a lathe to start. That would be > about the only why I could see doing this from a practical stand > point. Probably only have to take a couple thousands off but that's a > lot of sanding. I tried a couple things using an drill and that was > too aggressive and too difficult to get a smooth result. Just too > much to do it by hand for me. I did start on the worst one I think > but still my best bet is to farm this one out. Thanks and I'll make > some calls Monday and let ya know. Looking forward to the run to > Maxton in a ten days. > John Heckman > central Pa > 1973 FC > > > > Hi John, > > > > There is a guy on Carlisle Pike off I-81 behind the strip club > that > > does them at odd times. If you stop by one of the garages at the > > flying hook or TA they can tell you more. I had a fun time doing > mine > > with wet sandpaper. Started at 400 or 600 grit and worked up to 1500 > > or 2000 grit and finally a buffing wheel on a mechanical buffer. > Still > > was not as good as a pro can get them with the right tools and > > attachments. They probably know where to get them done at the John > > Wayne chrome shop down at Greencastle too. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > wrote: > > > > > > Well I have them home. They're nice but of course not like new > and not > > > polished the why a proud BB's owner would like them. I > > > started "working" on one of them and I just don't think I have it > in me > > > to do four of them. I suppose it I have to do it myself I will > but > > > does anyone know of a professional wheel shop or a way to have > them > > > done professionally. A location in the Pa Maryland area would be > > > helpful since shipping could get pricy. I searched on the net > and only > > > found a place in BC which out of reach. > > > > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > |
03-23-2008, 16:27
Post: #23
Alcoa Wheels
Gardner, I found a couple sights on the web which show how it's
done. One is VIS Wheel Polishing and Refinishing. There is a neat video on their sight. Apparently there are machines which handle it easily. Some you don't even have to take the tire off the wheel. I will make some calls tomorrow and see if there is a local outfit don't it. My wheels are not that bad but it's still entirely too much to do (for me). Sounds like it will cost about $50 a wheel and that seems entirely reasonable considering how sore my fingers are from what would be just a start on one of mine. I'll see what I can come up with. This neck of the woods is just filled with truck terminals and such. Should be something around this part of Pa. Shane gave me a couple leads. I'll keep you informed. John Heckman central Pa 1973 FC > > John, > I worked my fingers to the bone, wore out my 3/8 drill I have had > for 40 years, and the wheels are far from done. Mine are probably > like yours, lots of pits. Find a pro, that is what I will probably > do after correcting the other things on my coach. See you at Maxton. > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > Thanks Shane, I'll check both of those out Monday. My fingers and > > hands are sore from my efforts. Not a good thing for my day job. I > > would have to start with something a lot more aggressive then 400 > or > > I would attempt it. So considering the point at which I am > starting > > and the results I would like to have I better get some help. Same > > ole story know your limits. The wheels are decent but there are > some > > pits. I actually think from what I've been able to find on the > web > > that the professionals turn them on a lathe to start. That would > be > > about the only why I could see doing this from a practical stand > > point. Probably only have to take a couple thousands off but > that's a > > lot of sanding. I tried a couple things using an drill and that > was > > too aggressive and too difficult to get a smooth result. Just too > > much to do it by hand for me. I did start on the worst one I > think > > but still my best bet is to farm this one out. Thanks and I'll > make > > some calls Monday and let ya know. Looking forward to the run to > > Maxton in a ten days. > > John Heckman > > central Pa > > 1973 FC > > > > > > Hi John, > > > > > > There is a guy on Carlisle Pike off I-81 behind the strip > club > > that > > > does them at odd times. If you stop by one of the garages at the > > > flying hook or TA they can tell you more. I had a fun time doing > > mine > > > with wet sandpaper. Started at 400 or 600 grit and worked up to > 1500 > > > or 2000 grit and finally a buffing wheel on a mechanical buffer. > > Still > > > was not as good as a pro can get them with the right tools and > > > attachments. They probably know where to get them done at the > John > > > Wayne chrome shop down at Greencastle too. > > > > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > > wrote: > > > > > > > > Well I have them home. They're nice but of course not like new > > and not > > > > polished the why a proud BB's owner would like them. I > > > > started "working" on one of them and I just don't think I have > it > > in me > > > > to do four of them. I suppose it I have to do it myself I > will > > but > > > > does anyone know of a professional wheel shop or a way to have > > them > > > > done professionally. A location in the Pa Maryland area would > be > > > > helpful since shipping could get pricy. I searched on the net > > and only > > > > found a place in BC which out of reach. > > > > > > > > John Heckman > > > > central Pa > > > > 1973 FC > > > > > > > > > > |
03-23-2008, 17:35
Post: #24
Alcoa Wheels
Alumniunm is shiney if it is flat. scratches interrupt reflection
and hold dirt. That is why it is best to remove pits and big scratches with wet sandpaper then remove sanding marks with finer (higher number grit) sand paper then polish the flat shine back into the metal with a wheel. If you have wax on the rim road grime will not touch the metal and the wax will protect the rim from oxidation. When the rim needs a touch up it is important to remove the wax fist with laundry soap so you wont be loading up the polish compound grit with wax. Now that my wheels are polished I wash off the wax; rub mothers brand compound in; then clean the mothers off with a onestep cleaner/wax. That keeps the mothers looking good. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > Gardner, I found a couple sights on the web which show how it's > done. One is VIS Wheel Polishing and Refinishing. There is a neat > video on their sight. Apparently there are machines which handle it > easily. Some you don't even have to take the tire off the wheel. I > will make some calls tomorrow and see if there is a local outfit > don't it. My wheels are not that bad but it's still entirely too much > to do (for me). Sounds like it will cost about $50 a wheel and that > seems entirely reasonable considering how sore my fingers are from > what would be just a start on one of mine. I'll see what I can come > up with. This neck of the woods is just filled with truck terminals > and such. Should be something around this part of Pa. Shane gave me a > couple leads. I'll keep you informed. > > John Heckman > central Pa > 1973 FC > > > > > > > > John, > > I worked my fingers to the bone, wore out my 3/8 drill I have > had > > for 40 years, and the wheels are far from done. Mine are probably > > like yours, lots of pits. Find a pro, that is what I will probably > > do after correcting the other things on my coach. See you at Maxton. > > > > Gardner > > 78FC33 > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > wrote: > > > > > > Thanks Shane, I'll check both of those out Monday. My fingers > and > > > hands are sore from my efforts. Not a good thing for my day job. > I > > > would have to start with something a lot more aggressive then 400 > > or > > > I would attempt it. So considering the point at which I am > > starting > > > and the results I would like to have I better get some help. > Same > > > ole story know your limits. The wheels are decent but there are > > some > > > pits. I actually think from what I've been able to find on the > > web > > > that the professionals turn them on a lathe to start. That would > > be > > > about the only why I could see doing this from a practical stand > > > point. Probably only have to take a couple thousands off but > > that's a > > > lot of sanding. I tried a couple things using an drill and that > > was > > > too aggressive and too difficult to get a smooth result. Just too > > > much to do it by hand for me. I did start on the worst one I > > think > > > but still my best bet is to farm this one out. Thanks and I'll > > make > > > some calls Monday and let ya know. Looking forward to the run to > > > Maxton in a ten days. > > > John Heckman > > > central Pa > > > 1973 FC > > > > > > > > Hi John, > > > > > > > > There is a guy on Carlisle Pike off I-81 behind the strip > > club > > > that > > > > does them at odd times. If you stop by one of the garages at the > > > > flying hook or TA they can tell you more. I had a fun time > doing > > > mine > > > > with wet sandpaper. Started at 400 or 600 grit and worked up to > > 1500 > > > > or 2000 grit and finally a buffing wheel on a mechanical > buffer. > > > Still > > > > was not as good as a pro can get them with the right tools and > > > > attachments. They probably know where to get them done at the > > John > > > > Wayne chrome shop down at Greencastle too. > > > > > > > > Shane Fedeli > > > > 85PT40 > > > > Hershey, PA > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > > > > wrote: > > > > > > > > > > Well I have them home. They're nice but of course not like > new > > > and not > > > > > polished the why a proud BB's owner would like them. I > > > > > started "working" on one of them and I just don't think I > have > > it > > > in me > > > > > to do four of them. I suppose it I have to do it myself I > > will > > > but > > > > > does anyone know of a professional wheel shop or a way to > have > > > them > > > > > done professionally. A location in the Pa Maryland area > would > > be > > > > > helpful since shipping could get pricy. I searched on the > net > > > and only > > > > > found a place in BC which out of reach. > > > > > > > > > > John Heckman > > > > > central Pa > > > > > 1973 FC > > > > > > > > > > > > > > > |
03-24-2008, 01:27
Post: #25
Alcoa Wheels
I found a place in Carlisle Pa which does the VIS process. Let you
know how it works out for me. The video looks inpressive. John Heckman central Pa 1973 FC > > Alumniunm is shiney if it is flat. scratches interrupt reflection > and hold dirt. That is why it is best to remove pits and big > scratches with wet sandpaper then remove sanding marks with finer > (higher number grit) sand paper then polish the flat shine back into > the metal with a wheel. If you have wax on the rim road grime will > not touch the metal and the wax will protect the rim from > oxidation. When the rim needs a touch up it is important to remove > the wax fist with laundry soap so you wont be loading up the polish > compound grit with wax. > > Now that my wheels are polished I wash off the wax; rub mothers > brand compound in; then clean the mothers off with a onestep > cleaner/wax. That keeps the mothers looking good. > > GregoryO'Connor > 94ptRomolandCa > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > Gardner, I found a couple sights on the web which show how it's > > done. One is VIS Wheel Polishing and Refinishing. There is a neat > > video on their sight. Apparently there are machines which handle > it > > easily. Some you don't even have to take the tire off the wheel. > I > > will make some calls tomorrow and see if there is a local outfit > > don't it. My wheels are not that bad but it's still entirely too > much > > to do (for me). Sounds like it will cost about $50 a wheel and > that > > seems entirely reasonable considering how sore my fingers are from > > what would be just a start on one of mine. I'll see what I can > come > > up with. This neck of the woods is just filled with truck > terminals > > and such. Should be something around this part of Pa. Shane gave > me a > > couple leads. I'll keep you informed. > > > > John Heckman > > central Pa > > 1973 FC > > > > > > > > > > > > > > John, > > > I worked my fingers to the bone, wore out my 3/8 drill I have > > had > > > for 40 years, and the wheels are far from done. Mine are > probably > > > like yours, lots of pits. Find a pro, that is what I will > probably > > > do after correcting the other things on my coach. See you at > Maxton. > > > > > > Gardner > > > 78FC33 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > > > wrote: > > > > > > > > Thanks Shane, I'll check both of those out Monday. My fingers > > and > > > > hands are sore from my efforts. Not a good thing for my day > job. > > I > > > > would have to start with something a lot more aggressive then > 400 > > > or > > > > I would attempt it. So considering the point at which I am > > > starting > > > > and the results I would like to have I better get some help. > > Same > > > > ole story know your limits. The wheels are decent but there > are > > > some > > > > pits. I actually think from what I've been able to find on > the > > > web > > > > that the professionals turn them on a lathe to start. That > would > > > be > > > > about the only why I could see doing this from a practical > stand > > > > point. Probably only have to take a couple thousands off but > > > that's a > > > > lot of sanding. I tried a couple things using an drill and > that > > > was > > > > too aggressive and too difficult to get a smooth result. Just > too > > > > much to do it by hand for me. I did start on the worst one I > > > think > > > > but still my best bet is to farm this one out. Thanks and > I'll > > > make > > > > some calls Monday and let ya know. Looking forward to the run > to > > > > Maxton in a ten days. > > > > John Heckman > > > > central Pa > > > > 1973 FC > > > > > > > > > > Hi John, > > > > > > > > > > There is a guy on Carlisle Pike off I-81 behind the strip > > > club > > > > that > > > > > does them at odd times. If you stop by one of the garages at > the > > > > > flying hook or TA they can tell you more. I had a fun time > > doing > > > > mine > > > > > with wet sandpaper. Started at 400 or 600 grit and worked up > to > > > 1500 > > > > > or 2000 grit and finally a buffing wheel on a mechanical > > buffer. > > > > Still > > > > > was not as good as a pro can get them with the right tools > and > > > > > attachments. They probably know where to get them done at > the > > > John > > > > > Wayne chrome shop down at Greencastle too. > > > > > > > > > > Shane Fedeli > > > > > 85PT40 > > > > > Hershey, PA > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > > > > > > wrote: > > > > > > > > > > > > Well I have them home. They're nice but of course not like > > new > > > > and not > > > > > > polished the why a proud BB's owner would like them. I > > > > > > started "working" on one of them and I just don't think I > > have > > > it > > > > in me > > > > > > to do four of them. I suppose it I have to do it myself I > > > will > > > > but > > > > > > does anyone know of a professional wheel shop or a way to > > have > > > > them > > > > > > done professionally. A location in the Pa Maryland area > > would > > > be > > > > > > helpful since shipping could get pricy. I searched on the > > net > > > > and only > > > > > > found a place in BC which out of reach. > > > > > > > > > > > > John Heckman > > > > > > central Pa > > > > > > 1973 FC > > > > > > > > > > > > > > > > > > > > > |
