light bulb part no.
03-26-2008, 04:09
light bulb part no.
Go to home depot in low voltage lighting section you will able to
obtain them there
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, David Brady wrote:
> Folks,
> Anyone have the part number for the 12V light bulb that
> inserts into the flush mounted ceiling lamps? It's a small
> glass bulb, no base, with two conductors coming out
> the bottom.
> Thanks,
> David Brady
> '02 LXi, NC
03-26-2008, 04:11
light bulb part no.
BB Parts here part number is 4558011 and we have them in stock give us a call at 478-825-0330
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of David Brady
Sent: Wednesday, March 26, 2008 8:32 AM
Subject: [WanderlodgeForum] light bulb part no.
Folks,
the bottom.
Thanks,
David Brady
'02 LXi, NC
03-26-2008, 04:25
light bulb part no.
Sounds like an MR 16 Halogen. They are available at most hardware
stores, Home Depot and Lowes.
> Folks,
> the bottom.
> Thanks,
> David Brady
> '02 LXi, NC
03-26-2008, 04:31
light bulb part no.
Folks,
the bottom.
Thanks,
David Brady
'02 LXi, NC
03-26-2008, 04:45
light bulb part no.
David, If you're talking about the Halogen bulbs, they're also available at lighting stores...and you might check the filaments. Sometimes..you can thump the bulbs with your fingers and get them to work again. I had to replace mine with rubber gloves to get more traction.
Date: Wed, 26 Mar 2008 11:41:08 -0500
Subject: Re: [WanderlodgeForum] light bulb part no.
Thanks for the help everyone.
David
'02 LXi, NC
From: WanderlodgeForum@yahoogroups.com ["Wanderlodge"Forum@yahoogroups.com] On Behalf Of David Brady
Folks,
the bottom.
Thanks,
David Brady
'02 LXi, NC
Checked by AVG. Version: 7.5.519 / Virus Database: 269.22.0/1343 - Release Date: 3/25/2008 7:17 PM
How well do you know your celebrity gossip? Talk celebrity smackdowns here.
03-26-2008, 05:41
light bulb part no.
David
'02 LXi, NC
Folks,
the bottom.
Thanks,
David Brady
'02 LXi, NC
03-26-2008, 06:33
light bulb part no.
If the bulb is like what's in my coach, they're from "under cabinet lights" sold in home centers. They are a low voltage halogen bulb. Check out your hardware store or a larger home center (Home Depot or Lowes).
Hint. Clean the bulb carefully, and handle with a cloth or rubber gloves. Skin oil (fingerprints) can cause the bulb to heat unevenly (they get _very_ hot) and will cause them to fail prematurely.
Pete Masterson
El Sobrante CA
"aeonix1@mac.com"
On Mar 26, 2008, at 8:31 AM, David Brady wrote:
Folks,
the bottom.
