89SP air brake wont release, all pressure gauges normal(115) front +rear
10-08-2008, 04:31
> Thanks to those who chimed in with ideas. Im going back to storage today and try these suggestions. It's finnaly a little cooler here in Texas for crawling under my rig. I also searched the archives and printed a few things. Thanks Ed Gardels 89sp Arlington Texas > you dont need the service brake (foot pedal) on to release the > spring brake. I park on a slight incline with the tow hooked and > release the spring/parking brake, let it roll to about 2 mph then > pull the park/spring brake lever to a stop, never touching the > pedal. the parking brake is refered to as the spring brake because > there is a spring that is always trying to apply the brake. when you > release the brake the valve fills a chamber behind the spring and > compresses it in. the drive axle has a brake chamber with twin > pumkin looking things. one pumkin is for the service brake and one > holds the spring. There is a long bolt on each twin pumkin that is > a tool to manualy release the brake for towing or emergancies. > > I wonder if the brake camed over??? that is if the shoes are so > worn the lever that pushes the shoe to the drum went past center????? > > it could also be modulator valve hung up or the 2 way valve. . I > would try dumping the air by shutting the bus of and pumping the > service brake untill it exhaust then try once again but wait untill > the tanks are full to max before you try and release the parking > spring brake. > > if its a valve problem, chock the tires and dont leave air in the > tanks while parked. > Greg94ptCa > |
