Lean fixed- That was EASY!!!
03-14-2009, 09:45
LARGE MARGE, my 1980 FC33 has been leaning to the right ever since I got her. I
had asked my mechanic to look at it along with some other stuff and it kind of
got overlooked, so I've been trying to ignore it expecting a big expense.
Finally, I did my homework by searching here, then slithered under the rear. I
adjusted the height valve in about 5 minutes. Surprisingly, the nut was not
frozen. Now I'm inspired. Everything else will be that easy and gratifying
also right?
03-14-2009, 09:46
I had asked my mechanic to look at it along with some other stuff and it kind of
also right?
Forgot to say who I am
John Churchill
Sanibel, FL
1980 FC33 "LARGE MARGE"
03-14-2009, 11:02
" LARGE MARGE"-- classic!!!
83PT40
Wanderlodge
--- On Sat, 3/14/09, Robin wrote:
Subject: [WanderlodgeForum] Re: Lean fixed- That was EASY!!!
Date: Saturday, March 14, 2009, 3:46 PM
--- In "WanderlodgeForum%40yahoogroups.com", "Robin" wrote:
> LARGE MARGE, my 1980 FC33 has been leaning to the right ever since I got her. I had asked my mechanic to look at it along with some other stuff and it kind of got overlooked, so I've been trying to ignore it expecting a big expense. Finally, I did my homework by searching here, then slithered under the rear. I adjusted the height valve in about 5 minutes. Surprisingly, the nut was not frozen. Now I'm inspired. Everything else will be that easy and gratifying also right?
John Churchill
Sanibel, FL
03-14-2009, 12:22
> Ernie Ekberg
> 83PT40
> Wanderlodge
> Weatherford, Tx
> http://autos.groups.yahoo.com/group/erni...gandrepair
She's named after the queen of our pack of chow dogs, Maggie, who is a full
figure gal. I just put some pictures up of her lounging at the beach.
http://groups.yahoo.com/group/Wanderlodg...8/pic/list
JAC
> From: Robin
also right?
> John Churchill
> Sanibel, FL
03-14-2009, 13:37
Which side does it lean too? I might suggest you either loose some weight or balance it out on the other side! I had that problem so I just left the wife home.İmage
Jipjob
Rebel Bird
Bremerton
