Park Brake Air Valve
04-22-2009, 03:41
Ralph, have you ever known it to become plugged/obstructed?
On 4/22/2009 at 7:10 AM Ralph L. Fullenwider wrote: >Leroy/ Don: > >If you slide under the drivers side front bumper area and look up there >should be a small hose that is open ended and that will be the exhaust >from >the PP-1 valve. > >Safe travels, > >Ralph and Charolette Fullenwider >84FC35 "Ruff Diamond" >Duncan, Oklahoma > >At 03:58 AM 4/22/2009 -0700, you wrote: > > >>Don, I do not know where the exhaust exits. I have not chased mine down. >>Leroy Eckert >>1990 WB-40 Smoke N Mirrors >>Dahlonega, GA >>Royale Conversion >> >>--- On Tue, 4/21/09, Don Bradner >>> >>>From: Don Bradner >>>Subject: Re: [WanderlodgeForum] Park Brake Air Valve >>>To: WanderlodgeForum@yahoogroups.com >>>Date: Tuesday, April 21, 2009, 5:30 PM >>> >>>Mine has been problematical for some time, so I just ordered a reman >PP-1 >>>from http://www.anythingtruck. com - $31.50+11.48 shipping. >>> >>>Leroy, there is a line on the exhaust port. I have not tried to trace >>>where it goes, do you know? I assume it is to keep noise down, but >>>blockage in that line would certainly make operation problematical. >>> >>>Don Bradner >>>90 PT40 "Blue Thunder" >>>My location: http://www.bbirdmaps. com/user2. cfm?user= 1 >>> >>>On 4/21/2009 at 12:24 PM Leroy Eckert wrote: >>> >>> >Bill, on my coach the push /pull control valve assembly is a Bendix >PP-1, >>> >30PSI. >>> >Try http://www.anythingtruck. com. Remans available. My book shows BB number >for >>> >what it's worth is 0900266. I can send you a photo of the drawing if >you >>> >like.. >>> >Leroy Eckert >>> >1990 WB-40 Smoke N Mirrors >>> >Dahlonega, GA >>> >Royale Conversion >> >> |
04-22-2009, 04:17
No, I haven't, though were there enough years of constant humidity, it
could plug up with the dirt collected by oil on the exhaust side. There are o-rings in the valve, if memory serves 3, I rebuilt Dan and Sandy's valve on their old '83 long ago. Actually found a re build kit for the darn thing. It is easier to replace the valve and in todays market easier on the pocket book. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 08:41 AM 4/22/2009 -0700, you wrote: >Ralph, have you ever known it to become plugged/obstructed? > >On 4/22/2009 at 7:10 AM Ralph L. Fullenwider wrote: > > >Leroy/ Don: > > > >If you slide under the drivers side front bumper area and look up there > >should be a small hose that is open ended and that will be the exhaust > >from > >the PP-1 valve. > > > >Safe travels, > > > >Ralph and Charolette Fullenwider > >84FC35 "Ruff Diamond" > >Duncan, Oklahoma > > > >At 03:58 AM 4/22/2009 -0700, you wrote: > > > > > >>Don, I do not know where the exhaust exits. I have not chased mine down. > >>Leroy Eckert > >>1990 WB-40 Smoke N Mirrors > >>Dahlonega, GA > >>Royale Conversion > >> > >>--- On Tue, 4/21/09, Don Bradner > >>> > >>>From: Don Bradner > >>>Subject: Re: [WanderlodgeForum] Park Brake Air Valve > >>>To: WanderlodgeForum@yahoogroups.com > >>>Date: Tuesday, April 21, 2009, 5:30 PM > >>> > >>>Mine has been problematical for some time, so I just ordered a reman > >PP-1 > >>>from http://www.anythingtruck. com - $31.50+11.48 shipping. > >>> > >>>Leroy, there is a line on the exhaust port. I have not tried to trace > >>>where it goes, do you know? I assume it is to keep noise down, but > >>>blockage in that line would certainly make operation problematical. > >>> > >>>Don Bradner > >>>90 PT40 "Blue Thunder" > >>>My location: http://www.bbirdmaps. com/user2. cfm?user= 1 > >>> > >>>On 4/21/2009 at 12:24 PM Leroy Eckert wrote: > >>> > >>> >Bill, on my coach the push /pull control valve assembly is a Bendix > >PP-1, > >>> >30PSI. > >>> >Try http://www.anythingtruck. com. Remans available. My book shows BB number > >for > >>> >what it's worth is 0900266. I can send you a photo of the drawing if > >you > >>> >like.. > >>> >Leroy Eckert > >>> >1990 WB-40 Smoke N Mirrors > >>> >Dahlonega, GA > >>> >Royale Conversion > >> > >> > > > |
04-22-2009, 04:42
I've already ordered a replacement valve, but my concern was that my
problematical valve issue could be plugging of the exhaust downstream rather than in the valve itself. "Problematical" in this case refers to two times when it would not activate. The "rush" of air to the exhaust was weak-sounding, and the brakes did not take hold. Repeated on/off action eventually produced proper braking. The two incidents were almost two years apart, so when I put the new valve in and everything works fine I still won't be sure that the problem isn't down in the exhaust line somewhere! Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 4/22/2009 at 11:17 AM Ralph L. Fullenwider wrote: >No, I haven't, though were there enough years of constant humidity, it >could plug up with the dirt collected by oil on the exhaust side. There >are >o-rings in the valve, if memory serves 3, I rebuilt Dan and Sandy's valve >on their old '83 long ago. Actually found a re build kit for the darn >thing. It is easier to replace the valve and in todays market easier on >the >pocket book. > >Safe travels, > >Ralph and Charolette Fullenwider >84FC35 "Ruff Diamond" >Duncan, Oklahoma > >At 08:41 AM 4/22/2009 -0700, you wrote: >>Ralph, have you ever known it to become plugged/obstructed? >> >>On 4/22/2009 at 7:10 AM Ralph L. Fullenwider wrote: >> >> >Leroy/ Don: >> > >> >If you slide under the drivers side front bumper area and look up there >> >should be a small hose that is open ended and that will be the exhaust >> >from >> >the PP-1 valve. >> > >> >Safe travels, >> > >> >Ralph and Charolette Fullenwider >> >84FC35 "Ruff Diamond" >> >Duncan, Oklahoma >> > >> >At 03:58 AM 4/22/2009 -0700, you wrote: >> > >> > >> >>Don, I do not know where the exhaust exits. I have not chased mine >down. >> >>Leroy Eckert >> >>1990 WB-40 Smoke N Mirrors >> >>Dahlonega, GA >> >>Royale Conversion >> >> >> >>--- On Tue, 4/21/09, Don Bradner >> >>> >> >>>From: Don Bradner >> >>>Subject: Re: [WanderlodgeForum] Park Brake Air Valve >> >>>To: WanderlodgeForum@yahoogroups.com >> >>>Date: Tuesday, April 21, 2009, 5:30 PM >> >>> >> >>>Mine has been problematical for some time, so I just ordered a reman >> >PP-1 >> >>>from http://www.anythingtruck. com - $31.50+11.48 shipping. >> >>> >> >>>Leroy, there is a line on the exhaust port. I have not tried to trace >> >>>where it goes, do you know? I assume it is to keep noise down, but >> >>>blockage in that line would certainly make operation problematical. >> >>> >> >>>Don Bradner >> >>>90 PT40 "Blue Thunder" >> >>>My location: http://www.bbirdmaps. com/user2. cfm?user= 1 >> >>> >> >>>On 4/21/2009 at 12:24 PM Leroy Eckert wrote: >> >>> >> >>> >Bill, on my coach the push /pull control valve assembly is a Bendix >> >PP-1, >> >>> >30PSI. >> >>> >Try http://www.anythingtruck. com. Remans available. My book shows BB >number >> >for >> >>> >what it's worth is 0900266. I can send you a photo of the drawing if >> >you >> >>> >like.. >> >>> >Leroy Eckert >> >>> >1990 WB-40 Smoke N Mirrors >> >>> >Dahlonega, GA >> >>> >Royale Conversion >> >> >> >> >> >> >> > > > >------------------------------------ > >Yahoo! Groups Links > > > |
