Intertherm A/C shroud
06-13-2005, 14:00
Wow Fred I assumed you have a fiberglass shroud. If you have a plastic one
then weld it back to like new. I have a heavy duty Leister Triac S air welder that I use to shrink heavy double wall shrink tubing when I make new battery cables(I am doing it now). it can also be used to weld all kinds of plastics. I do not have the tip for welding plastic but I am sure I can get it. Its amazing how easy it is to weld plastic of almost any kind now. Somewhere I have a lot of information on exactly how to do it. Tom 1982 FC35 Vernon Center,NY At 12:31 AM 6/14/2005 +0000, you wrote: >I tried this with some Bondo Home Solutions All Purpose Fiberglass >Resin on a test area that I had scuffed well. The resin did not >adhere to the shroud. Is it possible that the resin will not adhere >to the plastic used in the shroud? > > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner > > II believe if I had a shroud that was falling apart and a >replacement was > > not available I would remove it, fiberglass the inside and then a skim > > coat to the outside and paint it. Has anyone tried it? I had the same > > problem with my chassis A/C condensor which is mounted on the roof >of older > > Bluebirds. I made a pattern from the old shroud and made it out of > > galvanized 14GA metal. Primed it with acid etching primer and >painted it. > > Cant tell the difference between the old or the new except the new >has no > > dents and bangs. > > > > tom > > 1982 FC35 > > Vernon Center,NY > > > > At 05:15 AM 6/13/2005 -0700, you wrote: > > >That's right. Hardly noticeable. I never painted the cover. If I >had one > > >would not know the difference at all. > > > > > >Curt Sprenger '87PT38, Anaheim, Calif. > > > > > > > > >randydupree wrote: > > > > > > >curt,can you even see the differance from the ground? the sheep >fence helps > > > >hide all that stuff so well.....randy > > > >----- Original Message ----- > > > >From: "Curt Sprenger" > > > >To: > > > >Sent: Monday, June 13, 2005 12:28 AM > > > >Subject: Re: [WanderlodgeForum] Intertherm A/C shroud > > > > > > > > > > > > > > > > > > > >>Fred, > > > >>I made an AC shroud for our '74 bird when one AC cover went >south. The > > > >>AC was original and worked great....I could not see replacing a good > > > >>unit. I made the cover of aluminum...it had no rounded corners >but did > > > >>have angles...and looked fine. The home made cover wasn't the >prettiest > > > >>but it was cheap...cost me about $30.00...I have the tools to >make it. I > > > >>called a tin shop and they would make a cover for around >$240.00. You > > > >>might check in your area. > > > >> > > > >>Curt Sprenger '87PT38, Anaheim, Calif. > > > >> > > > >> > > > >> > > > >>fred89sp wrote: > > > >> > > > > > > > >Yahoo! Groups Links > > > > |
06-13-2005, 14:03
Fred this might give you an idea of what you can buy:
http://www.factoryreconditionedcatalog.c...lding.html Tom 1982 FC35 Vernon Center,NY At 12:31 AM 6/14/2005 +0000, you wrote: >I tried this with some Bondo Home Solutions All Purpose Fiberglass >Resin on a test area that I had scuffed well. The resin did not >adhere to the shroud. Is it possible that the resin will not adhere >to the plastic used in the shroud? > > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner > > II believe if I had a shroud that was falling apart and a >replacement was > > not available I would remove it, fiberglass the inside and then a skim > > coat to the outside and paint it. Has anyone tried it? I had the same > > problem with my chassis A/C condensor which is mounted on the roof >of older > > Bluebirds. I made a pattern from the old shroud and made it out of > > galvanized 14GA metal. Primed it with acid etching primer and >painted it. > > Cant tell the difference between the old or the new except the new >has no > > dents and bangs. > > > > tom > > 1982 FC35 > > Vernon Center,NY > > > > At 05:15 AM 6/13/2005 -0700, you wrote: > > >That's right. Hardly noticeable. I never painted the cover. If I >had one > > >would not know the difference at all. > > > > > >Curt Sprenger '87PT38, Anaheim, Calif. > > > > > > > > >randydupree wrote: > > > > > > >curt,can you even see the differance from the ground? the sheep >fence helps > > > >hide all that stuff so well.....randy > > > >----- Original Message ----- > > > >From: "Curt Sprenger" > > > >To: > > > >Sent: Monday, June 13, 2005 12:28 AM > > > >Subject: Re: [WanderlodgeForum] Intertherm A/C shroud |
