Front heat shutoff
07-20-2009, 05:27
Front heat shutoff
The cockpit in our bird is roasting unless I shut off heater
water flow at the engine. There is a solenoid valve in line near the front center of the coach which I disassembled and cleaned. I ordered 2 Sporlan valve repair kits but this valve has a piston at least twice the size of the Sporlan. I would have assumed that this valve was energized to operate (normally closed) and I can't get access to the leads going into the solenoid. What are my options? Chuck Harrison Akron, Ohio 90 SP36 |
