FUEL SOLENOID ON 8KW GENERATOR IN 87FC
09-26-2009, 08:35
DOES ANYONE KNOW WHERE TO FIND ONE ITS THE SHUTOFF ONE. MINE TAKES 40 AMPPS TO
KEEP IT ENGAGED
TKS BOB MALONEY IN KY STILL FIGHTING FOR POWER
09-26-2009, 10:25
BOB, Check the stroke of the arm. amp draw is a sign that somthing is making it
hard to open. could be other linkage issues or somthing.
I would just match it up at Napa. the newer diesels have two relays. one that
pulls the solenoid in and one holds it in. in the past when I used a newer
stype I connect both + lines to the 'hot when open + ignition line'
GREGOFTIMANDGREG
($PTCA
KEEP IT ENGAGED
09-27-2009, 04:24
Bob: You probably will have to buy the "Stopping Solenoid" from Cummins since
they own Onan.
Part number is 0307-2546. Price around $200 bucks.
Here is the link from buying the part.
https://quickserve.cummins.com/genuinepa...-2546.html
Dick Gideon
1989 FC35
Rolla, MO
KEEP IT ENGAGED
