Gas springs for compartment doors
11-30-2009, 17:02
I'm having some issues trying to find the correct replacements for the cargo bay
and interior gas springs. I have the numbers FMR115 and FBN12C off the existing ones, but they don't cross reference anywhere I know that the H9412 is a replacement for the interior ... but what about the exterior one ? What kind of thrust lbs should I use ? It's an '86 PT40 ... THANKS !! |
11-30-2009, 23:27
Orr and Orr is the place to got for these...
http://www.orrorr.com/ Give them a call. I replaced pretty much all of them on my '87 PT40 with springs from them. HTH, Joe On Mon, Nov 30, 2009 at 9:02 PM, zboy59 <"martys@title-check.com"> wrote:
12-01-2009, 01:54
Greetings:
Look for the force numbers on yours in the middle of the sequence of digits near the "F" number: on my exterior Stabilus units a typical example is "1657EE 0500N 307/09 A 5" which is a 500 Newton (metric unit of force) or about 110 lbs unit. The interior springs on my '87 were replaced by a previous owner with Supra 9" 35lb units. I recently replaced the exterior springs with FBN12K 500 Newton (~110 lb) Stabilus units from Orr and Orr. M.R.Kane 1987 PT40 currently Terrell, TX --- In WanderlodgeForum@yahoogroups.com, "zboy59" > > I'm having some issues trying to find the correct replacements for the cargo bay and interior gas springs. > > I have the numbers FMR115 and FBN12C off the existing ones, but they don't cross reference anywhere > > I know that the H9412 is a replacement for the interior ... but what about the exterior one ? What kind of thrust lbs should I use ? > > It's an '86 PT40 ... > > THANKS !! > |
