AC power lost on one leg
07-29-2010, 11:49
While running the generator to charge batteries one of the legs quit. I was
running both front and rear air at the time. The inverter and rear air are on the same circuit. That is the circuit that quit. The over- head panel AC voltmeters both read 120v. On the monitor panel in the kitchen one meter read zero and the other read 120v. Any ideas out there? Art Weatherly Riverside Ca 85 PT36 |
07-29-2010, 12:34
Art
Check the circuit breakers at your panel and also you may have circuit brkrs at the genset.
Fred Hulse
97BB41
07-30-2010, 11:27
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse"
> > Art > Check the circuit breakers at your panel and also you may have circuit brkrs at the genset. > Fred Hulse > 97BB41 > Ckt breakers cheched OK. Today I took the cover off the AC breaker panel. I disc. the two inputs to the panel and swapped them. Started the genset and had power to both legs. I ran it for about 20 minutes. Nothing abnormal. I am curious as to why the main voltmeters both about 130v. Is that in range? Art Weatherly Riverside Ca '85 PT36 |
07-30-2010, 12:17
My generator is different than yours (a "Universal" only used in 1990, I think),
that runs at 130v no-load at 60Hz. If I set its speed down at all the voltage will drop, but so will the Hz. Under significant load it drops to around 128v. I've not experienced any problems except I had to set the max level for my inverter (ProSine 2.0) to 131 or it won't kick out of inversion mode. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 7/30/2010 at 11:27 PM artw wrote: >--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" >> >> Art >> Check the circuit breakers at your panel and also you may have circuit >brkrs at the genset. >> Fred Hulse >> 97BB41 >> >Ckt breakers cheched OK. > >Today I took the cover off the AC breaker panel. >I disc. the two inputs to the panel and swapped them. Started the genset >and had power to both legs. I ran it for about 20 minutes. Nothing >abnormal. I am curious as to why the main voltmeters both about 130v. >Is that in range? > > >Art Weatherly >Riverside Ca >'85 PT36 |
07-30-2010, 23:38
07-31-2010, 04:55
Gary, I'm reading the 130 off the digital display for the ProSine. I have tons
of expensive electronics (besides normal Blue Bird stuff) in my bus (others here can attest!) and have never had a problem. On 7/31/2010 at 4:38 AM GARY MINKER wrote: >Use a real voltmeter and do not trust the panel mount units. If you >really have 130 volts you have other issues that will cause damage to the >rest of your things. >gary 85pt40 > >--- On Fri, 7/30/10, Don Bradner > >From: Don Bradner >Subject: Re: [WanderlodgeForum] Re: AC power lost on one leg >To: WanderlodgeForum@yahoogroups.com >Date: Friday, July 30, 2010, 8:17 PM > > > > > > > >Ã > > > > > > > > > > My generator is different than yours (a "Universal" only used in >1990, I think), that runs at 130v no-load at 60Hz. If I set its speed down >at all the voltage will drop, but so will the Hz. Under significant load >it drops to around 128v. > > > >I've not experienced any problems except I had to set the max level for my >inverter (ProSine 2.0) to 131 or it won't kick out of inversion mode. > > > >Don Bradner > >90 PT40 "Blue Thunder" > >My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > > >On 7/30/2010 at 11:27 PM artw wrote: > > > >>--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > >>> > >>> Art > >>> Check the circuit breakers at your panel and also you may have circuit > >>brkrs at the genset. > >>> Fred Hulse > >>> 97BB41 > >>> > >>Ckt breakers cheched OK. > >> > >>Today I took the cover off the AC breaker panel. > >>I disc. the two inputs to the panel and swapped them. Started the genset > >>and had power to both legs. I ran it for about 20 minutes. Nothing > >>abnormal. I am curious as to why the main voltmeters both about 130v. > >>Is that in range? > >> > >> > >>Art Weatherly > >>Riverside Ca > >>'85 PT36 |
07-31-2010, 05:08
Yes I can attest to the fact that Don has "tons of expensive" stuff in his rig droooool. And yes he doesn't let the smoke get out of the box. He does however deplete my wallet on an annual basis (usually during and right after Quartzsite). His recommendations are killing me VBG
On 31 July 2010 09:55, Don Bradner <"bluethunder@arcatapet.com"> wrote:
Gary, I'm reading the 130 off the digital display for the ProSine. I have tons of expensive electronics (besides normal Blue Bird stuff) in my bus (others here can attest!) and have never had a problem. -- Rob, Sue and Joey Robinson |
07-31-2010, 06:08
Give up now! You will never catch up...
On 7/31/2010 at 10:08 AM Rob Robinson wrote: >Yes I can attest to the fact that Don has "tons of expensive" stuff in his >rig droooool. And yes he doesn't let the smoke get out of the box. He does >however deplete my wallet on an annual basis (usually during and right >after >Quartzsite). His recommendations are killing me VBG > >On 31 July 2010 09:55, Don Bradner > >> Gary, I'm reading the 130 off the digital display for the ProSine. I have >> tons of expensive electronics (besides normal Blue Bird stuff) in my bus >> (others here can attest!) and have never had a problem. |
07-31-2010, 06:41
Okay Dad, where do I send the cheque???
07-31-2010, 08:33
