microwave 110 v works Invertor not
09-14-2015, 09:32
well after needing the genny 24/7, we are finally able to turn her off and open the windows . But , it turns out that on the invertor the micro and 2 other outlets are not working ? . so with the genny running they work , with Invertor they do not ? any thoughts GuRu s
![]() al perna 2000 LXI ormond beach fla |
09-14-2015, 09:47
RE: microwave 110 v works Invertor not
Was it wired OEM, or by the PO, so that the inverter would not power those units to save battery power? If so, one would need to move wires so that they WERE hooked to inverter power.
09-14-2015, 10:14
on the LXI it is powered thru the Inverter Ned
09-14-2015, 10:26
Hey Al, go into the inverter RC7 panels and disable auto-sensing. See if that helps.
09-14-2015, 12:09
relay switch under the bed , larger silver boxes, one will be tripped the other way. ??
09-14-2015, 19:25
(This post was last modified: 09-14-2015 19:27 by al perna.)
and may I ask how that is done
![]() Greg, we do not have a box under the bed that I know of . If there is one it is covered in carpet, I will look ? al perna 2000 LXI ormond beach fla |
