Rear Cruise Aire, Thanks to Ralph and Jeff
08-16-2005, 04:43
Rear cruiseaire is working. Thanks for all your help. Jeff Miller
suggested that I check the overhead switch at the drivers seat. It was on however for some reason the toggle switch was bad. Thanks Bill Garlen 84PT40 Jesup, GA "Wink and a Smile" |
08-16-2005, 05:48
That is good news Bill. That is where I was taking you as well after we
found out about the power going to the terminal strip not being present. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:43 PM 8/16/2005 +0000, you wrote: >Rear cruiseaire is working. Thanks for all your help. Jeff Miller >suggested that I check the overhead switch at the drivers seat. It was >on however for some reason the toggle switch was bad. > > >Thanks >Bill Garlen >84PT40 >Jesup, GA >"Wink and a Smile" > > > |
