Climb every mountain, ...
11-24-2005, 08:27
Happy Thanks giving Don
Yep, you are running about the same temps as me. It looks perfectly normal to me. With you upgraded prom you will note a big difference in the hills. Just make sure you are in POWER MODE and see the tranny downshift around 2000RPM. The new prom moved the shiftpoints to a higher setting in the rpm and it prevents you from lugging. Enjoy the turkey Juergen in PA (Beaver) 1991 WLSP36 dspithaler@... wrote: My 89 SP Run about the same on level ground. It usually is around 800 on hills it goes to 900 then 1000 & I saw at 1100 on a grade on I-77 in Virginia last year. I wander if the sensor is before the turbo and not after & if it is correct. I hear so many different readings it makes you wander if yours is right & if they are installed in the right place. I hope mine shifts down sooner after I had that upgraded E-prom installed this fall. Don 89 SP 36' Butler, PA With snow on the ground This Thanksgiving Day Hi Shane Blue-Bird Book says 900F, Caterpillar says don't exceed 1300F, some consider the range between 900 and 1250 the yellow caution range, while 1300 is RED Line. I cannot even cruise slowly on level ground with only 650. My cruise on level ground and no headwind is about 700 +/- 10. Go figure... ??? Juergen in PA 1991 WLSP36 sfedeli3 <sfedeli3@...> wrote: Hi Guy & Juergen, I've climbed many of the passes out west pedal to the metal in my PT40 and never have seen my pyro over 650 in the summer. Did El Cajon, Wolf Creek and the Grapevine all in July heat. Temps were 195 Water and 230 Oil/Tranny. My turbo seems to get hotter with thicker "cold" oil and yesterday I saw 725 and got scared. What should the pyro max out at? Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "guysmalley" > > --- In WanderlodgeForum@yahoogroups.com, john duke > > > > To all BB guys > > I have a question about climbing in a Blu-Bird. I have my WLSP 36 now for 10 years > and I keep looking at mountain grades more and more. My last BIG endevour was the > Calif. Tehachapi pass from Bakersfield on up to where the windmills are. I pushed the > coach as hard as I could and saw Pyro reach 1050 at times and boost 15+. Water and Oil > temps were never over 190F Tranny was also in limits(95C). I passed almost every truck > on that climb.(Towing my jeep wrangler). Yet I keep watching the grades and reading > about them if they are listed. > > Going into Yosemite from the west, I would not take my BB up those grades, yet I saw > all kinds of busses and motorhomes going right in there. WHAT is the limit that a Blue- > Bird can do?? Am I too timid or over cautious in generalor is a 10% grade too much? I > would love to hear of some of your experiences. > > Thanks > > Juergen in PA > > 1991 WLSP36 > > > Juergen, > I worry more about the swith backs than the grade if you take your time gear it right it > would go up almost anything. I am a cyclist and riden all over the country (including the > road to Yosemite) so I am aware of grades. what I do in real steep climbs= winding roads > is to have my wife drove the tow car. less strain it is not nessasary but on hard swithbacks > it is just easyer. also I research roads before hand so not to get into a bad situation. > bottom line most roads that you would bring the BB on would be under 12% which a > pusher would do. > > guy smalley > 86 pt40 > --------------------------------- YAHOO! GROUPS LINKS [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Music Unlimited - Access over 1 million songs. Try it free. [Non-text portions of this message have been removed] |
12-07-2005, 08:49
I would not be surprised to see 1050 on my 89SP. Your boost of 15 psi
is great. --- In WanderlodgeForum@yahoogroups.com, john duke > > To all BB guys > I have a question about climbing in a Blu-Bird. I have my WLSP 36 now for 10 years and I keep looking at mountain grades more and more. My last BIG endevour was the Calif. Tehachapi pass from Bakersfield on up to where the windmills are. I pushed the coach as hard as I could and saw Pyro reach 1050 at times and boost 15+. Water and Oil temps were never over 190F Tranny was also in limits(95C). I passed almost every truck on that climb.(Towing my jeep wrangler). Yet I keep watching the grades and reading about them if they are listed. > Going into Yosemite from the west, I would not take my BB up those grades, yet I saw all kinds of busses and motorhomes going right in there. WHAT is the limit that a Blue-Bird can do?? Am I too timid or over cautious in generalor is a 10% grade too much? I would love to hear of some of your experiences. > Thanks > Juergen in PA > 1991 WLSP36 > > > > --------------------------------- > Yahoo! FareChase - Search multiple travel sites in one click. > > [Non-text portions of this message have been removed] > |
12-07-2005, 09:03
Sensor is after the turbo on my 89SP.
--- In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > > My 89 SP Run about the same on level ground. It usually is around 800 on > hills it goes to 900 then 1000 & I saw at 1100 on a grade on I-77 in Virginia > last year. I wander if the sensor is before the turbo and not after & if it is > correct. I hear so many different readings it makes you wander if yours is > right & if they are installed in the right place. I hope mine shifts down > sooner after I had that upgraded E-prom installed this fall. > Don > 89 SP 36' > Butler, PA With snow on the ground This Thanksgiving Day > > Hi Shane > Blue-Bird Book says 900F, Caterpillar says don't exceed 1300F, some > consider the range between 900 and 1250 the yellow caution range, while 1300 is RED > Line. > I cannot even cruise slowly on level ground with only 650. My cruise on > level ground and no headwind is about 700 +/- 10. > Go figure... ??? > Juergen in PA > 1991 WLSP36 > > sfedeli3 <sfedeli3@c...> wrote: Hi Guy & Juergen, > I've climbed many of the passes out west pedal to the metal in my > PT40 and never have seen my pyro over 650 in the summer. Did El > Cajon, Wolf Creek and the Grapevine all in July heat. Temps were 195 > Water and 230 Oil/Tranny. My turbo seems to get hotter with > thicker "cold" oil and yesterday I saw 725 and got scared. What > should the pyro max out at? > Shane Fedeli > 85PT40 > Hershey, PA > > > --- In WanderlodgeForum@yahoogroups.com, "guysmalley" > > > > > --- In WanderlodgeForum@yahoogroups.com, john duke > > > > > > > To all BB guys > > > I have a question about climbing in a Blu-Bird. I have my WLSP > 36 now for 10 years > > and I keep looking at mountain grades more and more. My last BIG > endevour was the > > Calif. Tehachapi pass from Bakersfield on up to where the > windmills are. I pushed the > > coach as hard as I could and saw Pyro reach 1050 at times and > boost 15+. Water and Oil > > temps were never over 190F Tranny was also in limits(95C). I > passed almost every truck > > on that climb.(Towing my jeep wrangler). Yet I keep watching the > grades and reading > > about them if they are listed. > > > Going into Yosemite from the west, I would not take my BB up > those grades, yet I saw > > all kinds of busses and motorhomes going right in there. WHAT is > the limit that a Blue- > > Bird can do?? Am I too timid or over cautious in generalor is a > 10% grade too much? I > > would love to hear of some of your experiences. > > > Thanks > > > Juergen in PA > > > 1991 WLSP36 > > > > > Juergen, > > I worry more about the swith backs than the grade if you take your > time gear it right it > > would go up almost anything. I am a cyclist and riden all over the > country (including the > > road to Yosemite) so I am aware of grades. what I do in real steep > climbs= winding roads > > is to have my wife drove the tow car. less strain it is not > nessasary but on hard swithbacks > > it is just easyer. also I research roads before hand so not to get > into a bad situation. > > bottom line most roads that you would bring the BB on would be > under 12% which a > > pusher would do. > > > > guy smalley > > 86 pt40 > > > > > > > > > --------------------------------- > YAHOO! GROUPS LINKS > > > > > > > > [Non-text portions of this message have been removed] > |
