valve lash on 3208
01-18-2006, 09:12
valve lash on 3208
When I had my injectors replaced 2 years ago at about 100,000 miles, because
they already had all the 'tough stuff' off the top of the engine, I asked them to replace valve cover gaskets and adjust the valves. Only two valves were barely out of adjustment. Have a "good" 3208 mechanic listen to your engine and I will bet he can tell you if there is any adjustment needed. Tom Meservey USN (Ret) '81FC33' Charleston AFB [Non-text portions of this message have been removed] |
