Camera
02-11-2007, 11:46
Camera
Hi Leroy: Check the back side of the monitor, there you should find a white connector with several wires on it. It plugs onto the mother board. Those wires a fragile and are notorious for breaking, there by being intermittent. Solder each one after removing from the plug and re insert the pins then re install to the mother board. Something to try before trashing the system. Ralph Safe travels, Ralph and Charolette Fullenwider (in SPI with a bad ride height valve and water leak) '84 FC35 Duncan, Oklahoma Ralph's RV Solutions > > > > My camera is intermittant. When it works it has a shape picture. > I > > believe the potentiometer is going in the tank. I have contacted > Tim > > at RVcams and am awaiting a response. > > > > Info: > > > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > > Tube is Clinton Tiawan Corp > > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > > guitar parts house to see if it is the problem- I'm told they are > > unavailable. I'm about to give up and retrofit. > > > > I saw a post where someone retrofitted a system without rewiring > the > > bus. Any info would help. Good or Bad. Thanks. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > > > |
02-11-2007, 15:29
Camera
Thanks Greg: I'll print that off and put it in my file so I do not forget
anything. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Sunday, February 11, 2007 5:41 PM Subject: [WanderlodgeForum] Re: Camera Leroy, I dont know what part in the Backup camera does the image reversing but that is important to match if your replacement part holds that obligation. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Thanks for the info. I'm about ready to junk the old one and update. By the time I fix the old one I still have an old one. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > ----- Original Message ----- > From: Rob Robinson > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, February 11, 2007 2:19 PM > Subject: Re: [WanderlodgeForum] Camera > > > Hi Leroy, Like Curt I also revamped my back-up camera system. I bought from > Tim at http://www.rvcams.com . I used existing coax cable with a radio shack S to > Coax cable conversion. Sorry can't remember the part number. > > On 11/02/07, jwasnewski > > > > My camera is intermittant. When it works it has a shape picture. I > > believe the potentiometer is going in the tank. I have contacted Tim > > at RVcams and am awaiting a response. > > > > Info: > > > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > > Tube is Clinton Tiawan Corp > > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > > guitar parts house to see if it is the problem- I'm told they are > > unavailable. I'm about to give up and retrofit. > > > > I saw a post where someone retrofitted a system without rewiring the > > bus. Any info would help. Good or Bad. Thanks. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
02-11-2007, 15:31
Camera
Thanks, I'll look at that possibility. Have a great time in SPI and don't
forget to visit Dirty Al's. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Sunday, February 11, 2007 5:46 PM Subject: Re: [WanderlodgeForum] Re: Camera > Hi Leroy: Check the back side of the monitor, there you should find a white connector with several wires on it. It plugs onto the mother board. Those wires a fragile and are notorious for breaking, there by being intermittent. Solder each one after removing from the plug and re insert the pins then re install to the mother board. Something to try before trashing the system. Ralph Safe travels, Ralph and Charolette Fullenwider (in SPI with a bad ride height valve and water leak) '84 FC35 Duncan, Oklahoma Ralph's RV Solutions > > > > My camera is intermittant. When it works it has a shape picture. > I > > believe the potentiometer is going in the tank. I have contacted > Tim > > at RVcams and am awaiting a response. > > > > Info: > > > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > > Tube is Clinton Tiawan Corp > > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > > guitar parts house to see if it is the problem- I'm told they are > > unavailable. I'm about to give up and retrofit. > > > > I saw a post where someone retrofitted a system without rewiring > the > > bus. Any info would help. Good or Bad. Thanks. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > > > [Non-text portions of this message have been removed] |
02-12-2007, 07:08
Camera
I am going to check the wires to the monitor tomorrow. I hope. Question? Does
it have a transformer that I should pay attention to so I do not get Zapped? Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Sunday, February 11, 2007 5:46 PM Subject: Re: [WanderlodgeForum] Re: Camera > Hi Leroy: Check the back side of the monitor, there you should find a white connector with several wires on it. It plugs onto the mother board. Those wires a fragile and are notorious for breaking, there by being intermittent. Solder each one after removing from the plug and re insert the pins then re install to the mother board. Something to try before trashing the system. Ralph Safe travels, Ralph and Charolette Fullenwider (in SPI with a bad ride height valve and water leak) '84 FC35 Duncan, Oklahoma Ralph's RV Solutions > > > > My camera is intermittant. When it works it has a shape picture. > I > > believe the potentiometer is going in the tank. I have contacted > Tim > > at RVcams and am awaiting a response. > > > > Info: > > > > Camera is Sanyo CCD Computar Wide Attack, Model VDC 3800 > > Tube is Clinton Tiawan Corp > > Potentiometer is A-B Mod Pot PN 26M955. Cannot locate one even at a > > guitar parts house to see if it is the problem- I'm told they are > > unavailable. I'm about to give up and retrofit. > > > > I saw a post where someone retrofitted a system without rewiring > the > > bus. Any info would help. Good or Bad. Thanks. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > > > [Non-text portions of this message have been removed] |
