3K trip over 2 weeks, should I do this service or wait
06-07-2007, 17:18
Mike, I dont know. The PO (Previous Owner) changed my primus to a
wabasto (diesel fired) for some reason. I dont even know if the Wabasto pushes engine passed R fluid?? GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > The Primus is not a part of the engine cooling system, at least it isn't on mine. There should be two small white plastic bottles at the rear of the bus up high that are the reservoirs. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: mbrund > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, June 07, 2007 9:48 AM > Subject: [WanderlodgeForum] Re: 3K trip over 2 weeks, should I do this service or wait > > > So in a 1992 WB40, the Primus antifreeze is also part of the cooling > system? For some reason I thought they where seperate systems and > used a heat exchanger between them. I will go out and fire up the > coach now and run all the systems so the fluid gets circulated as I > am going to town in a little bit to pickup test strips to test the > balance. > > Michael Brundridge > 1992 WB40 > Georgetown, TX > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Michael, When you check the balance, you need a homonogous mix of > all > > the fluids in the bus. there are valves that limit the path of > > coolant for summer and winter. even the hotwater heater gets passed > > with engine cooling fluid. I would ;run the bus ;run chassis heat > > and primus heat then take a test of the fluid. Then if you have > one, > > replace the coolant filter and cut open the old one. I would not > use > > the cleaner as there is no way to check the interior of the heat > > exchanger tranny cooler (looks like a big pipe under radiator) and > > the acid will pass through all the non typical appliances not > found > > in apps where that cleaner is used. > > > > If you balance a homonogous mix of existing fluids, you will know > > what you are starting with. On the road you can always replace 5 > gal > > of fluid in the event 1000 miles down the road the test strips show > a > > change in balance. > > > > GregoryO'Connor > > 94ptRomolandCa > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Al" > > > > > > Michael, > > > I look at it this way... Either you can change it now and > know > > > what you are starting with or not and chance having to have it > > > changed on the road. I can promise you, it will be cheaper now. > > > Then you and your family can enjoy your trip. > > > > > > Al, Kathy Johnson > > > '96 BMC B100 > > > Mandeville, Louisiana > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > > > > > I am about to take our WB on its first long haul trip which > will > > > > total about 3K miles in all. > > > > > > > > I am going to change the engine and transmission oil and > > assocaited > > > > filters. I am carring extra primary and secondary fuel filters > > > with > > > > me. > > > > > > > > The real question is, the prior owner admitted that in the 10 > > years > > > > he owned it that he did basic oil and trans service but never > did > > > any > > > > coolant service. So that scares me, and all though I have not > > > > checked, I can promise it is out of balance. > > > > > > > > I should note here, that I am not currently having over heating > > > > problems. Just want to get my coach caught up on service. > > > > > > > > Should I dump the coolant, flush the system (I have Permatex > > Heavy > > > > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, > > repeat, > > > > then add 12 gallons antifreeze, 12 gallons distilled water, and > 7 > > > > pints Pencool 2000? > > > > > > > > Or should I test it, get it in balance, take the trip and do > the > > > > coolant service when I return? > > > > > > > > I am a little concerned that flushing the system may cause > leaks > > to > > > > occur that are not currently known and that would either > prevent > > my > > > > trip or cause issues on the road. Looking for some advice from > > the > > > > community. > > > > > > > > Michael Brundridge > > > > 1992 WB40 > > > > Georgetown, TX > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
06-08-2007, 06:13
The primus is a totally sepreate system from the engine
The webasto may be depending on the installer If the installer used the primus ssystem it would be seperate if the webasto was a clean install and not a retrofit it should use engine coolant It waould not make sense in a retrofit to rip out the heat exchangers and reroute through the engine Too much work Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Mike, I dont know. The PO (Previous Owner) changed my primus to a > wabasto (diesel fired) for some reason. I dont even know if the > Wabasto pushes engine passed R fluid?? > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > The Primus is not a part of the engine cooling system, at least it > isn't on mine. There should be two small white plastic bottles at the > rear of the bus up high that are the reservoirs. > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > ----- Original Message ----- > > From: mbrund > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, June 07, 2007 9:48 AM > > Subject: [WanderlodgeForum] Re: 3K trip over 2 weeks, should I do > this service or wait > > > > > > So in a 1992 WB40, the Primus antifreeze is also part of the > cooling > > system? For some reason I thought they where seperate systems and > > used a heat exchanger between them. I will go out and fire up the > > coach now and run all the systems so the fluid gets circulated as > I > > am going to town in a little bit to pickup test strips to test > the > > balance. > > > > Michael Brundridge > > 1992 WB40 > > Georgetown, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > > > > Michael, When you check the balance, you need a homonogous mix > of > > all > > > the fluids in the bus. there are valves that limit the path of > > > coolant for summer and winter. even the hotwater heater gets > passed > > > with engine cooling fluid. I would ;run the bus ;run chassis > heat > > > and primus heat then take a test of the fluid. Then if you have > > one, > > > replace the coolant filter and cut open the old one. I would > not > > use > > > the cleaner as there is no way to check the interior of the > heat > > > exchanger tranny cooler (looks like a big pipe under radiator) > and > > > the acid will pass through all the non typical appliances not > > found > > > in apps where that cleaner is used. > > > > > > If you balance a homonogous mix of existing fluids, you will > know > > > what you are starting with. On the road you can always replace > 5 > > gal > > > of fluid in the event 1000 miles down the road the test strips > show > > a > > > change in balance. > > > > > > GregoryO'Connor > > > 94ptRomolandCa > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Al" > > > > > > > > Michael, > > > > I look at it this way... Either you can change it now and > > know > > > > what you are starting with or not and chance having to have > it > > > > changed on the road. I can promise you, it will be cheaper > now. > > > > Then you and your family can enjoy your trip. > > > > > > > > Al, Kathy Johnson > > > > '96 BMC B100 > > > > Mandeville, Louisiana > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> > wrote: > > > > > > > > > > I am about to take our WB on its first long haul trip which > > will > > > > > total about 3K miles in all. > > > > > > > > > > I am going to change the engine and transmission oil and > > > assocaited > > > > > filters. I am carring extra primary and secondary fuel > filters > > > > with > > > > > me. > > > > > > > > > > The real question is, the prior owner admitted that in the > 10 > > > years > > > > > he owned it that he did basic oil and trans service but > never > > did > > > > any > > > > > coolant service. So that scares me, and all though I have > not > > > > > checked, I can promise it is out of balance. > > > > > > > > > > I should note here, that I am not currently having over > heating > > > > > problems. Just want to get my coach caught up on service. > > > > > > > > > > Should I dump the coolant, flush the system (I have > Permatex > > > Heavy > > > > > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, > > > repeat, > > > > > then add 12 gallons antifreeze, 12 gallons distilled water, > and > > 7 > > > > > pints Pencool 2000? > > > > > > > > > > Or should I test it, get it in balance, take the trip and > do > > the > > > > > coolant service when I return? > > > > > > > > > > I am a little concerned that flushing the system may cause > > leaks > > > to > > > > > occur that are not currently known and that would either > > prevent > > > my > > > > > trip or cause issues on the road. Looking for some advice > from > > > the > > > > > community. > > > > > > > > > > Michael Brundridge > > > > > 1992 WB40 > > > > > Georgetown, TX > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
