Replace Roof AC units - 1992 WB40
06-11-2007, 14:13
Yes it is ducted. And we believe that is what we will do at some
point, but we have never had all three AC units working at the same time since we purchased the coach due to one problem or another (low freon on rear unit, busted suction line on forward, now busted high side on center). I finally had all three working this past two weeks, and then the center unit popped its cork. So I will salvage out these two as they have good compressors, electronics, thermostats, condensors, fan motors, etc. as they work, just cracked at the solder joints and I just don't want to mess with them anymore. FYI, the current Dometic AC unit in the bedroom does not bother us at night, it is quite enough and has just enough white noise to drown out other items. But those Colemans we had on our other coach, no matter what speed they ran they where too loud. Michael Brundridge 1992 WB40 Georgetown, TX (for another week, then on the road) --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > Isn't your system ducted? I run the front or center unit at night and > it keeps the bedroom reasonably cool (having cooled the bedroom down > with the rear unit first) with little noise. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > > > > On Jun 11, 2007, at 6:21 PM, mbrund wrote: > > > I would say the same thing about the Colemans. We installed the > > Coleman Mach 3PS (10AMP units) on our last coach and damn near never > > got any sleep as the unit's where so noisy. That is one reason I am > > not replacing the one in the bedroom at this time as the Dometic is > > nice and quite, especially with the 1/2" thick padded plywood cover > > that came with it from BB. > > > > Michael Brundridge > > 1992 WB40 > > Georgetown, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Dan" > >> > >> I replaced a dometic with a carrier heat pump in my 1981 FC but i > > didn't like it. the carrier moves a lot more air and seemed a lot > > noisier even on the lowest setting. i would be interested in your > > opinion on them after you get them installed. > >> Thanks > <snip> > |
06-13-2007, 03:45
Thank you for the information and the pictures, I was not going to
just pull on them but now that i see yours i am going to give it a try. |
