Things that go bump in the night...
06-18-2007, 06:06
Several nights now, I have heard a loud thump in my coach in the
middle of the night. The first couple of nights it was loud enough and
startled me out of my sleep such that I flipped the security lights on
and went out hunting bad guys with a tactical light and a 9mm (bus is
parked on my private property behind a fence with a locked gate, so
anyone lurking in the shadows by my coach is fair game). Fortunately I
haven't found anyone and the noise happened again last night, so I'm
fairly sure at this point it's something on the bus itself.
Basically, it's a "boom" type of echoing noise. It's loud, at least
when you're sleeping in the back. Sounds like someone smacking a big,
empty aluminum tank with a baseball bat. I can't help but wonder if
it's coming from the plumbing system? Maybe a loud burp of a tank of
some sort? Perhaps a side wall on the hot water heater flexing? I
don't know, I'm just guessing here.
Has anyone else experienced this? I'm not running A/C or heaters, so
probably not related to those. No engine or generator running, either.
Plugged into 50 amp shore power, running fridge, water pump, hot water
heater, battery chargers and lights. That's about it. No incoming
water connection (I prefer to use the on-board water and just fill it
up every few weeks to minimize the damage in the event of a leak).
Thanks for any advice.
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
06-18-2007, 06:57
Any bears nearby?
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com
Sent: Monday, June 18, 2007 1:06 PM
Subject: [WanderlodgeForum] Things that go bump in the night...
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
06-18-2007, 07:13
Leroy,
On 6/18/07, Leroy Eckert wrote:
> Any bears nearby?
Nope. Bears don't live in the desert and I'm right smack in the middle
of one. For that matter, no big game anywhere really to speak of.
There are some elk outside the city and the occasional wild horses,
but I've never seen 'em in the city or anywhere near my neighborhood.
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
06-18-2007, 07:18
I am not sure if it is correct or not but I had a similar sound on my
1984 - I concluded it was the parking brake releasing a bit and
grabbing. Are you on any kind of front to back slope?
Wayne Chappuis
on
is
Fortunately I
big,
either.
water
it
> -Ryan
> '86 PT-40 8V92
> Tri-Cities, WA
06-18-2007, 07:40
That takes care of that idea.
Leroy Eckert
Niceville, Fl
Sent: Monday, June 18, 2007 1:57 PM
Subject: Re: [WanderlodgeForum] Things that go bump in the night...
Any bears nearby?
Leroy Eckert
Niceville, FL
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
06-18-2007, 07:57
1St guess: Its a body panel springing from the change in
temperature day to night. 2nd guess: The bus is haunted :-)
John Heckman
Hopeful owner FC by 4/7
Shippensburg Pa
my
> Wayne Chappuis
enough
> and
lights
> on
(bus
> is
so
> Fortunately I
I'm
least
> big,
if
of
so
> either.
> water
fill
> it
> > -Ryan
> > '86 PT-40 8V92
> > Tri-Cities, WA
06-18-2007, 08:30
No front to back slope that I can tell - also, I'm up on leveling jacks.
Curt Sprenger on the "wanderlodge" group mentioned a similar noise
with his leveling jacks, so I'm going to try topping off the fluid &
cycling them as he did. Might just solve it.
Thanks for the ideas!
-Ryan
06-18-2007, 09:40
Air bag or jacks leaking down and causing a chassis, rear brake or
suspention noise.
Bill's Guess, 88 FC Michigan
on
is
Fortunately I
big,
either.
water
it
> -Ryan
> '86 PT-40 8V92
> Tri-Cities, WA
06-18-2007, 10:21
In a message dated 6/18/2007 6:51:14 P.M. Mountain Standard Time,
gcyeaw@... writes:
Are you sure Ernie Ekberg isn't parked nearby tossing empty wine
boxes in your direction?
He's on the opposite side of the Continental Divide. ~
83PT40
Livingston, Mt
06-18-2007, 13:48
Gardner
78FC33
lights on
is
Fortunately I
I'm
big,
of
so
either.
water
it
> -Ryan
> '86 PT-40 8V92
> Tri-Cities, WA
