Stepwell Cover
10-27-2005, 05:10
Stepwell Cover
Cannot extend the cover with the button. Can use the button and pull
manually. Will move out slowly. Hit button, release, pull by hand, hit button again, release, etc. etc. until it is out. Retacts beautifully, just hit button. What do I do and where do I start? Steve Gureasko 90PT40WLWB Ponchatoula, La. |
10-27-2005, 05:41
Stepwell Cover
Steve:
Sounds like you have either an air restriction or leak in the line to that cylinder. Haven't had to access it, but I would think it is under the platform that moves. Don't think you can access from above, but you can look. I assume your air pressures are up. R.e. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@e...> wrote: > > Cannot extend the cover with the button. Can use the button and pull > manually. Will move out slowly. Hit button, release, pull by hand, hit > button again, release, etc. etc. until it is out. Retacts beautifully, > just hit button. What do I do and where do I start? > Steve Gureasko > 90PT40WLWB > Ponchatoula, La. > |
10-27-2005, 05:53
Stepwell Cover
Steve,
You need to verify that your air pressure is full up before you tear into anything. Mike Bulriss 83 PT40 "Stagecoach" - For Sale 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@e...> wrote: > > Cannot extend the cover with the button. Can use the button and pull > manually. Will move out slowly. Hit button, release, pull by hand, hit > button again, release, etc. etc. until it is out. Retacts beautifully, > just hit button. What do I do and where do I start? > Steve Gureasko > 90PT40WLWB > Ponchatoula, La. > |
