insulation
05-24-2005, 05:16
insulation
We have just recieved a new shipment of composite insulation
1inch foam, vinyl blocker 1/4 inch foam,
Faced on one side with fiber reinforced mylar and hi temp pressure
sensitive adhesive on the other
Size 24x 54
Priced at 47.00 per sheet plus shipping
3 sheet bundles 40.00 per sheet plus shipping
shipping based on 34 pounds from 14305
Stephen 77fc35
02-19-2006, 19:11
insulation
We also have insulation with a high heat presure sensitve adhesive
already applied.
Have had my doghouse insulated for 2 years with no problems
Stpehen 77fc35
02-19-2006, 22:46
insulation
scott- stephen birtles sells the insulation and adhesive. ernie-83pt40 in
louisiana
02-20-2006, 03:15
insulation
Who is "we"...where do I get some of this?
> already applied.
> Stpehen 77fc35
11-25-2008, 10:00
insulation
I have just completed the insulation of Bob Lawrences generator
compartment. I had previously, many years ago, used JC Whitney's
material. Ralph has been doing that work the past few years and since
he delegated me to do this task we chose insulation from Stephen
Birtles.
I thought Whitneys insulation was the best till I worked with this. Not
only is it heavier but is thicker, also.
Thank you, Stephen, very good product.
Ernie-83PT40 in Texas
11-25-2008, 11:13
insulation
I used the same product from Birtles. Great stuff. The left overs were used for a base cushion for my antique chairs in the bus. High density foam on top of it. That is good also with new upholstery..
Leroy Eckert'
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
--- On Tue, 11/25/08, Ernest Ekberg wrote:
Subject: [WanderlodgeForum] Insulation
Date: Tuesday, November 25, 2008, 5:00 PM
Birtles.
11-27-2008, 07:12
insulation
Just like Don said, the hardest part, due to the fact that there is a steel plate suspended about 3 inches from the roof of the compartment, is scraping the old off. I have a long handled scraper with a razor blade and will try and work on Bob Lawrence's engine compartment probably after it warms up a bit tomorrow-- and after I burn off the volume of what I consumed, today.
83PT40 Wanderlodge
Weatherford, Texas
11-27-2008, 11:07
insulation
> Birtles.
Not
Could this insulation be used in the engine compartment? We have lost
chunks of insulation which drops down on the hot engine and melts.
Phew.
TIA,
Liz
11-27-2008, 11:32
insulation
Liz
I put it in my engine compartment over three years ago & it is doing great. The hardest part of it was taking the old off.
Don Spithaler
89 SP 36'
Butler, PA
On Thu, Nov 27, 2008 at 6:07 PM, Jack and Liz Pearce <"jacklizpearce@gmail.com"> wrote:
--- In "WanderlodgeForum%40yahoogroups.com", "Ernest Ekberg"
> Birtles.
Not
Phew.
TIA,
Liz
11-27-2008, 14:29
insulation
Jack an Liz
Yes you cam use in the engine compartment that is what was spec.ed for
you can also use it for ares that need sound deadening
If you have any questions please dont hesitate to call me
Use my quarter
888 668 4288
Stephen 77fc35
dupreeproducts.com
--- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce"
> > Birtles.
> Not
> Phew.
> TIA,
> Liz
