Dinghy Odometer Reading - revisit
06-08-2005, 09:05
This past week I towed our 1990 Acura Legend down to Myrtle Beach SC
and back. I left the ignition key in position I (accessory)on way down, odmeter still worked (443 miles), and position II(on)on way home which also had the odometer working (446 miles). I didn't think the Acura had a speedometer cable but maybe it does or I have to disconnect some fuse to temporarilly disable the odometer. Any more suggestions. Roy Anderson Sprinfield VA 1986 PT-40 |
06-08-2005, 09:20
Roy,
How was the secnic route going home? Mark snowbirdtogo This past week I towed our 1990 Acura Legend down to Myrtle Beach SC and back. I left the ignition key in position I (accessory)on way down, odmeter still worked (443 miles), and position II(on)on way home which also had the odometer working (446 miles). I didn't think the Acura had a speedometer cable but maybe it does or I have to disconnect some fuse to temporarilly disable the odometer. Any more suggestions. Roy Anderson Sprinfield VA 1986 PT-40 --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Discover Yahoo! Stay in touch with email, IM, photo sharing & more. Check it out! [Non-text portions of this message have been removed] |
06-08-2005, 09:32
Drove by South of the Border, what a thrill
-----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Mark Garber Sent: Wednesday, June 08, 2005 5:20 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Dinghy Odometer Reading - revisit Roy, How was the secnic route going home? Mark snowbirdtogo This past week I towed our 1990 Acura Legend down to Myrtle Beach SC and back. I left the ignition key in position I (accessory)on way down, odmeter still worked (443 miles), and position II(on)on way home which also had the odometer working (446 miles). I didn't think the Acura had a speedometer cable but maybe it does or I have to disconnect some fuse to temporarilly disable the odometer. Any more suggestions. Roy Anderson Sprinfield VA 1986 PT-40 --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Discover Yahoo! Stay in touch with email, IM, photo sharing & more. Check it out! [Non-text portions of this message have been removed] _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of <http://docs.yahoo.com/info/terms/> Service. [Non-text portions of this message have been removed] |
06-08-2005, 12:11
Hi Roy,
I'm no expert but we have a friend with an Acura toad and it seems like they had to insert the key into a slot on the shift console to disengage the speedo. Just checked with Edythe and she said that she puts the key in a slot on the console next to the shifter and moves the shifter from park to neutral; Then takes the key out and puts it in the ignition and turns it to the first click. Hers was a '92 Accord but those Hondas are all about the same. Something to check anyway.... George snowbirdtogo wrote: > This past week I towed our 1990 Acura Legend down to Myrtle Beach SC > and back. I left the ignition key in position I (accessory)on way > down, odmeter still worked (443 miles), and position II(on)on way home > which also had the odometer working (446 miles). I didn't think the > Acura had a speedometer cable but maybe it does or I have to > disconnect some fuse to temporarilly disable the odometer. Any more > suggestions. > Roy Anderson > Sprinfield VA > 1986 PT-40 > > > > > > > Yahoo! Groups Links > > > > > > > > > |
06-08-2005, 12:30
George,
Thanks for the suggestion, I will inspect console for a key slot. My wife's 1990 Acura was the last year for the first body style and they made a lot of changes in 1991, hope the key slot isn't one of them. I checked car and it does have the slot which does let me position the ignition key in lock position without locking steering wheel, but with a speedometer cable it might not matter. I suspect the 1991 on Acuras have electronic speed sensors instead of a cable. Hope springs eternal and I will give it a try when my daughter and I shove off for summer long trip. Thanks for response. Roy -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of George Lowry Sent: Wednesday, June 08, 2005 8:12 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Dinghy Odometer Reading - revisit Hi Roy, I'm no expert but we have a friend with an Acura toad and it seems like they had to insert the key into a slot on the shift console to disengage the speedo. Just checked with Edythe and she said that she puts the key in a slot on the console next to the shifter and moves the shifter from park to neutral; Then takes the key out and puts it in the ignition and turns it to the first click. Hers was a '92 Accord but those Hondas are all about the same. Something to check anyway.... George snowbirdtogo wrote: > This past week I towed our 1990 Acura Legend down to Myrtle Beach SC > and back. I left the ignition key in position I (accessory)on way > down, odmeter still worked (443 miles), and position II(on)on way home > which also had the odometer working (446 miles). I didn't think the > Acura had a speedometer cable but maybe it does or I have to > disconnect some fuse to temporarilly disable the odometer. Any more > suggestions. > Roy Anderson > Sprinfield VA > 1986 PT-40 > > > > > > > Yahoo! Groups Links > > > > > > > > > _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of <http://docs.yahoo.com/info/terms/> Service. [Non-text portions of this message have been removed] |
