Undelivered Mail Returned to Sender
06-06-2009, 13:05
This is the Postfix program at host scn.org.
I'm sorry to have to inform you that your message could not be
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The Postfix program
: Command died with status 1:
"/usr/local/FreePort/bin/m2mbox
/home/gll/mbox"
Wanderlodge Forum
Messages In This Digest (9 Messages)
1a.
Headlights out on the road! Help?
1b.
Re: Headlights out on the road! Help?
1c.
2a.
Re: kool o"matic roof fan
2b.
2c.
2d.
2e.
3.
Franconia Notch State Park NH - informal mini rally
Messages
1a.
Posted by: "Greg Young"
gregy1@...
gregy1
Fri Jun5,2009 8:28am (PDT)
[Attachment(s) from Greg Young included below]
Hi!
We are in month 2 of our 6 month tour, and lost our headlights two days ago while driving. We made it into camp at 10pm on the driving lights. It's the dashboard headlight switch - it was getting flaky and I'm pretty sure it burned up, possibly along with connectors. I researched through the forum and the only part number for the switch I could find was NAPA HL6669. The local NAPA store didn't have it so I looked it up online and the only match I could find appears to be a split toggle switch - which will definitely not fit in the dash to replace the pull up design in our 86 PT-40.
We will not be able to park long enough for me to disassemble the dash and get to the parts so I can match them up until Monday (we'll be doing only daylight driving until then). Can anyone advise a source and part numbers for the correct switch and connectors so that I can have them at hand when we park? I'm dedicating a day to the effort and am willing to pay overnight shipping so that we get the parts. I'll also be doing the headlight relay upgrade at the time...
Thanks for all your help and experience!
Greg Young
86 PT-40 "Bluefire"
Currently in Harrington ME, bound to Sheldon Spings VT and Niagara Falls NY (where the repairs will be done)
(760) 807-1727
Each time you judge yourself you break your heart.
-Kirpal Venanji
1 of 1 Photo(s)
1b.
Posted by: "pattypape"
billpatty@...
pattypape
Fri Jun5,2009 12:31pm (PDT)
Greg, that is the NAPA number for our 88 FC.
It is a GM headlight switch, a split rocker switch. Headlights and parking lights, Ihave info on a pull up switch.
Bill 88 FC Michigan
--- In "WanderlodgeForum%40yahoogroups.com", Greg Young wrote:
> Hi!
> Greg Young
> 86 PT-40 "Bluefire"
> (760) 807-1727
> -Kirpal Venanji
1c.
Posted by: "sfedeli3"
sfedeli3@...
sfedeli3
Fri Jun5,2009 5:57pm (PDT)
Hi Greg,
Just tried calling you- but voice mail was not setup on your phone yet. Had the same problem last summer and replaced the switch with a stock one from Advance Auto. I seem to recall that it fit the spec for an '84 Caprice. Just about any switch with the same threaded shaft will work- you just pull the connectors off the spades and put them on the new one. Eventually, you want to re-work the parking and tail lights as well as the headlights using Bosch relays. They will all be much brighter and it'll take the high-current out of the dash
It only takes a few minutes to pull the switch. There is a spring-loaded push-button on the bottom of the housing that you have to depress in order to release the triangular shaft & knob. Once that is done, the little chrome bezel that holds it into the dash will unscrew and release the switch assembly down into the dash cavity. Call me if you need any help at 717-645-4912.
Shane Fedeli
85PT40
Hershey, PA
> Bill 88 FC Michigan
> > Hi!
> > Greg Young
> > 86 PT-40 "Bluefire"
> > (760) 807-1727
> > -Kirpal Venanji
2a.
Posted by: "Joyce and Richard Hayden"
rhhayden@...
bluesteelll
Fri Jun5,2009 2:49pm (PDT)
I have a fan and blade with the inside grill that I removed from our WL. It was working fine when removed and I will give it to anyone who is willing to pay the shipping charges. The reason for the removal is I installed a FanTastic in it's place.
To: "WanderlodgeForum%40yahoogroups.com"
Sent: Thursday, June 04, 2009 4:31 AM
Subject: Re: [WanderlodgeForum] kool o"matic roof fan
Try http://www.kool-o-matic.com<http://www.kool-o-matic.com/>. I see the web site is still up. Use the telephone number as he is known to call back later. Perhaps he still has inventory. I purchased a motor over a year ago as a spare.
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
--- On Thu, 6/4/09, gasparillaglass <"gasparillaglass%40yahoo.com"> wrote:
From: gasparillaglass <"gasparillaglass%40yahoo.com">
Subject: [WanderlodgeForum] kool o"matic roof fan
Date: Thursday, June 4, 2009, 7:18 AM
I have a r-12 Kool O"matic roof fan that looks like it it taking its last breath
dose anyone know where to get a replacment motor ??
jamie Brandt
1990 wb-40
SW Florida
2b.
Posted by: "Ernie Ekberg"
ernietex@...
ernietex
Fri Jun5,2009 2:50pm (PDT)
Dick, which fan works the best?
83PT40
Wanderlodge
http://autos.groups.yahoo.com/group/erniesremodelingandrepair
--- On Fri, 6/5/09, Joyce and Richard Hayden <"rhhayden%40msn.com"> wrote:
From: Joyce and Richard Hayden <"rhhayden%40msn.com">
Date: Friday, June 5, 2009, 4:48 PM
Try http://www.kool-o-matic. com. I see the web site is still up. Use the telephone number as he is known to call back later. Perhaps he still has inventory. I purchased a motor over a year ago as a spare.
Leroy Eckert
Dahlonega, GA
jamie Brandt
1990 wb-40
SW Florida
2c.
rhhayden@...
bluesteelll
Fri Jun5,2009 3:13pm (PDT)
Hi Ernie,
You must be sittin right there on top of it.
We like the FanTastic because it can be closed tight where as the Kool o matic does leak some in the winter. I wondered when you were in MT in the winter if you had a problem with cold air leaking through the fan. The FanTastic will move lots of air but probably not as much as the Kool o matic does. The Kool o matic makes lots of noise to move lots of air.
Hope this helps.
Regards
Sent: Friday, June 05, 2009 2:50 PM
83PT40
Wanderlodge
http://autos.groups.yahoo.com/group/erniesremodelingandrepair<http://autos.groups.yahoo.com/group/erniesremodelingandrepair>
From: Leroy Eckert<http://us.mc812.mail.yahoo.com/mc/compose?to=jwasnewski@yahoo.com>
To: WanderlodgeForum@ yahoogroups. com<http://us.mc812.mail.yahoo.com/mc/compose?to=WanderlodgeForum@yahoogroups.com>
Try http://www.kool-o-matic. com<http://www.kool-o-matic.com/>. I see the web site is still up. Use the telephone number as he is known to call back later. Perhaps he still has inventory. I purchased a motor over a year ago as a spare.
Leroy Eckert
Dahlonega, GA
--- On Thu, 6/4/09, gasparillaglass http://us.mc812.mail.yahoo.com/mc/compose?to=gasparillaglass@yahoo.com>> wrote:
jamie Brandt
1990 wb-40
SW Florida
2d.
Posted by: "Leroy Eckert"
jwasnewski@...
jwasnewski
Fri Jun5,2009 5:06pm (PDT)
For information mine is just the opposite. My bath Fanatic fan sounds like a jet plane and would not pull you hat off. The Kool O Matic is quiet and sucks plenty of air asap. My Kool O Matic has a factory cover made of metal. It won't leak in a flood. My Fanatic fan also has one of those covers. No hatch closing required.
Leroy Eckert
Dahlonega, GA
Date: Friday, June 5, 2009, 6:12 PM
Hi Ernie,
06-06-2009, 14:20
The Postfix program
/home/gll/mbox"
Wanderlodge Forum
Messages In This Digest (4 Messages)
1a.
Re: Shutting off the heat
2a.
2b.
3.
Keyless entry pad now available
Messages
1a.
Posted by: "Truckinl"
truckinl@...
truckinl
Thu Jun4,2009 5:31am (PDT)
Hot all the time, replace the sporlan and bingo, hot only when the
switch is on for heat.
On a 87-89 FC the sporlan relay is located up behind the air filter.
David T
Northern WI.
Did have a 89 FC
2a.
Posted by: "altierb@..."
altierb@...
bryanaltier
Thu Jun4,2009 6:47am (PDT)
I took mine to a motor shop and for $35 they went through it and it's like new.
Bryan Altier
88 WLWB
Greenville, SC
Sent from my BlackBerry® smartphone with Nextel Direct Connect
-----Original Message-----
From: "gasparillaglass" <"gasparillaglass%40yahoo.com">
Date: Thu, 04 Jun 2009 11:18:26
To: <"WanderlodgeForum%40yahoogroups.com">
jamie Brandt
1990 wb-40
SW Florida
2b.
Posted by: "rogerwwebb@..."
rogerwwebb@...
rogerwwebb
Thu Jun4,2009 7:06am (PDT)
I had mine rebuilt by a motor shop for about the same amount.
Roger Webb
91 WBWL
Cedar Rapids, IA
In a message dated 6/4/2009 8:48:06 A.M. Central Daylight Time,
"altierb%40bellsouth.net" writes:
new.
Bryan Altier
88 WLWB
Greenville, SC
____________________________________
Date: Thu, 04 Jun 2009 11:18:26 -0000
To: WanderlodgeFWan>
breath
jamie Brandt
1990 wb-40
SW Florida
**************Limited Time Offers: Save big on popular laptops at Dell
(http://pr.atwola.com/promoclk/100126575x1221354145x1201369495/aol?redir=http:%2F
%2Fad.doubleclick.net%2Fclk%3B215221161%3B37268813%3By)
3.
Posted by: "Fred Hulse"
fhulse@...
flhulse
Thu Jun4,2009 7:11am (PDT)
Some of you remember I was looking for the keyless entry keypad.
I have found a very few of these and are available for the those who want to replace or have on hand for future use.
The key pad is brand new original Ford units and can be shipped right away.
Please email me off forum.
Fred & Jeanne Hulse
Morristown Arizona
1997 Wanderlodge WLWB41
Recent Activity
Yahoo! Finance
It's Now Personal
Guides, news,
advice more.
Sell Online
Start selling with
our award-winning
e-commerce tools.
Health Groups
for people over 40
Join people who are
staying in shape.
Need to Reply?
Click one of the "Reply" links to respond to a specific message in the Daily Digest.
Create New Topic
Visit Your Group on the Web
Change settings via the Web (Yahoo! ID required)
Change settings via email: "WanderlodgeForum-normal@yahoogroups.com?subject=EmailDelivery:IndiviualEmail" | "WanderlodgeForum-traditional@yahoogroups.com?subject=ChangeDeliveryFormat:Traditional"
Visit Your Group
Yahoo! Groups Terms of Use
Unsubscribe
