Gray water holding tank leak
08-15-2010, 01:15
Recently I noticed that my gray water tank starts leaking when it gets about
half full. Has anyone else experienced this problem. If so what did you do to fix it? Royal Washburn 97BBWL43' Conway, AR |
08-15-2010, 02:40
Hi Royal:
Have you tried to identify where the leak is coming from? There is a good chance it is your gate valve if you have never replaced the seals. Dupree products has all the replacement seals and if you replace the gate valve paddle seal you should also replace the o-ring that seals the plastic mounting plate for the paddle where it slides into the gate valve housing. I developed a leak in my gray water tank last year and it was the o-ring so I replaced the paddle seals and o-rings in both the gray and black water tanks. Now both gate valves work much more smoothly and no more leaks. Wayne Kotila 96PT42 --- In WanderlodgeForum@yahoogroups.com, "Royal" > > Recently I noticed that my gray water tank starts leaking when it gets about half full. Has anyone else experienced this problem. If so what did you do to fix it? > > Royal Washburn > 97BBWL43' > Conway, AR > |
