Engine won't start or Primus
02-28-2011, 11:19
Nelson,
I have Interstate batteries for the same reason as Roger, easiest thing to do and convenient to find on the road for replacements. As for the 14V reading on your dash meters, that sounds like a bogus surface charge reading if the engine cranks slowly and does not start. You will need to load test the batteries individually to see what happens to the voltage reading then. There's probably a dry cell or bad cell somewhere on one or more of the start batteries. In the meantime, if you have not already tried it, use the aux battery switch on the dash to tie the battery banks together and try to start again. If that doesn't work, I would just use battery jumper cables from a 12V neg ground toad to the jumper pins inside the rear door to get it started, until you can get the batteries checked out. Good luck. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "nelsons" > > Thanks Roger, > Let see what happens. > Have a great day. > Nelson > > --- In WanderlodgeForum@yahoogroups.com, Roger W Webb > > > > Oh no!. You have asked one of the most dreaded questions on the forum ... what battery is the best?? ... good luck, there are lots of opinions. I've got Interstate, but that is just because it was easy to do. Wait for 24 hours and I'm sure you'll have at least 6 different recommendations. > > > > > > Now I'm not making fun of anyone ... I just know batteries and tires generate lots of responses. Have fun folks. > > > > > > Roger Webb - Cedar Rapids, IA > > 91 WL - sitting in NC > > > > > > > > -----Original Message----- > > From: nelsons > > To: WanderlodgeForum > > Sent: Mon, Feb 28, 2011 8:30 am > > Subject: [WanderlodgeForum] Re: Engine won't start or Primus > > > > > > > > > > > > Thank you Roger, > > I think you are correct about the condition of the batteries. Could you recommend which ones to purchase for replacement? Could not find the Battery Heat Switch. Sure do miss Dean from Wanderlodge when you have a problem, what would all we do without this forum. > > Thanks > > Nelson Slinkman > > 1994 WB 40' > > Westminster, Md > > > > --- In WanderlodgeForum@yahoogroups.com, Roger W Webb > > > > > > IMO your engine batteries are just too weak. If charging them does get some cranking power, trying jumping them (if you are a member of Good Sam or other service, it may be worth the call). Even then, if you have one really bad battery, jumping may not help and replacing them may be your next alternative. The gages on the dash really only give you an indication of voltage at the moment and although lookin' good, may not be a good indication of cranking power. > > > > > > > > > Tying you house and engine batteries together with the switch on the dash could get you some cranking power, and heating up the batteries may help (my switch for the battery heat is under the sink in my 91WL). But even those assists may not overcome a bad or weak bank of batteries. > > > > > > > > > Roger Webb - Cedar Rapids, IA > > > 91WL (sitting in NC) > > > > > > > > > > > > > > > > > > > > > > > > -----Original Message----- > > > From: nelsons > > > To: WanderlodgeForum > > > Sent: Mon, Feb 28, 2011 7:51 am > > > Subject: [WanderlodgeForum] Re: Engine won't start or Primus > > > > > > > > > > > > > > > > > > > > > > > > Hello Mike, > > > I could not find any switch for electric heater behind the pull down > > > drawer. There was only an "start Gen" "LP on/off" and water pump switch. Yes, the switch was "on" to charge both sets of batteries. I am sure the ether tank is empty I have had this bus for 10 years and never used it. The bus only has 31000 miles on it. > > > Thanks for your help. > > > Nelson SLinkman > > > 1994 WB 40' > > > Westminster, Md > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Steve Quandt" > > > > > > > > If it is set up the same as my 1993 pull down the drawer front under the > > > > kitchen sink, there should be a switch there for the electric engine heater. > > > > For this to work you need to be plugged in or on your generator. When you > > > > were parked did you tie the engine batteries to the house so they would be > > > > charged? If not there is a switch on the dash AUX Battery, if it is off > > > > turn to on to on to charge the engine batteries. > > > > > > > > > > > > > > > > The cold start switch goes to an ether cylinder in the engine bay that is > > > > most likely empty. > > > > > > > > > > > > > > > > Steve Quandt 1993 PT40 > > > > > > > > Iron Mountain, MI > > > > > > > > Now in WARM Marble Falls TX > > > > > > > > > > > > > > > > _____ > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of nelsons > > > > Sent: Monday, February 28, 2011 11:26 AM > > > > To: WanderlodgeForum@yahoogroups.com > > > > Subject: [WanderlodgeForum] Engine won't start or Primus > > > > > > > > > > > > > > > > > > > > > > > > Hello, > > > > I have a 1994 WB with an 8v92. I have been away for 4 months and just got > > > > back this past weekend. I wanted to start the engine so I tried starting the > > > > Primus in order to pre-warm the engine due to the cold temperature we've had > > > > for a few months. The Primus would not start. I checked the Propane switch, > > > > and it was on, the stove was working and so was the refrigerator. I tried to > > > > turn it on a few times incase there was and air in the line, but it never > > > > started. It there another safety switch for the Primus? I started the engine > > > > and the primus before I left and all worked properly. > > > > When I try to start the engine it turns very slowly and does not turn fast > > > > enough to start. > > > > The only thing that I noticed was the "Neutral" light on the transmission > > > > panel is on. > > > > Does the 1994 Bird have an electric heated for the engine? I saw a switch > > > > that is on the right side of the consul that says cold start. > > > > Any help would be appreciated. > > > > Thanks > > > > Nelson Slinkman > > > > 1994 WB > > > > Westminster, Md > > > > > > > > > > |
02-28-2011, 12:02
02-28-2011, 17:00
Oh Yes, Trojans are great batteries. I have also learned on this forum that oil is also a thing to discuss, and subject to differences of opinion. I think that Shawn from Pa. got me to looking at batteries, {Pls. don't shoot me in case I mis-spelled your name Shawn}, and this I have learned. Sams Club sells a excellent 6 volt golf cart battery, if you use that type, but if not here is the good news Their batteries are mfg. by Johnson Controls. This company has a excellent reputation, and they manufacture these batteries; Interstate, Sears Diehard, as well as the Sams Club Golf cart Batteries, as well as others. I have Interstate batteries at present, and have got great service from them. I will buy the Sams Club batts next time, because when I checked the price early last year, they were approx. $74.00 ea., vs. the Interstate, which were around $105. Good Luck, George Burke 1977 FC31SB Charlotte  P.S. The batts that Wal-Mart sells are not the same, they are mfg. by Excide, and are not the same quality.
On Mon, Feb 28, 2011 at 7:02 PM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
03-01-2011, 07:38
Thank you all for the information.
FOLLOW UP ON ENGINE WON'T START After turning on the Primus for 2 hours the engine started right up. Not bad for setting for 4 months. The only problem I see is the Level warning light is on even thought they are completely up. Thanks Nelson Slinkman 1994 WB 40' Westminster, Md --- In WanderlodgeForum@yahoogroups.com, George Burke > > Oh Yes, Trojans are great batteries. I have also learned on this forum that > oil is also a thing to discuss, and subject to differences of opinion. I > think that Shawn from Pa. got me to looking at batteries, {Pls. don't shoot > me in case I mis-spelled your name Shawn}, and this I have learned. Sams > Club sells a excellent 6 volt golf cart battery, if you use that type, but > if not here is the good news Their batteries are mfg. by Johnson Controls. > This company has a excellent reputation, and they manufacture these > batteries; Interstate, Sears Diehard, as well as the Sams Club Golf cart > Batteries, as well as others. I have Interstate batteries at present, and > have got great service from them. I will buy the Sams Club batts next time, > because when I checked the price early last year, they were approx. $74.00 > ea., vs. the Interstate, which were around $105. Good Luck, George Burke > 1977 FC31SB Charlotte P.S. The batts that Wal-Mart sells are not the same, > they are mfg. by Excide, and are not the same quality. > > On Mon, Feb 28, 2011 at 7:02 PM, Ernie Ekberg > > > > > > > When I was in Ft Worth, I bought T105 Trojans. They lasted quite a few > > years. When I was in Austintown, Ohio last year, batteries died. All that > > was available was Crown batteries. Put them on the coach and off and > > running. Any battery new is a lot better then any real old ones > > > > *Ernie Ekberg* > > *83 PT40* > > *Weatherford, Tx 76086* > > *817-475-3991* > > *http://www.ernieekbergflooring.net* > > > > > > --- On *Mon, 2/28/11, Roger W Webb > > > > > > From: Roger W Webb > > Subject: Re: [WanderlodgeForum] Re: Engine won't start or Primus > > To: WanderlodgeForum@yahoogroups.com > > Date: Monday, February 28, 2011, 1:43 PM > > > > > > > > Oh no!. You have asked one of the most dreaded questions on the forum ... > > what battery is the best?? ... good luck, there are lots of opinions. I've > > got Interstate, but that is just because it was easy to do. Wait for 24 > > hours and I'm sure you'll have at least 6 different recommendations. > > > > Now I'm not making fun of anyone ... I just know batteries and tires > > generate lots of responses. Have fun folks. > > > > Roger Webb - Cedar Rapids, IA > > 91 WL - sitting in NC > > > > > > -----Original Message----- > > From: nelsons > > To: WanderlodgeForum > > Sent: Mon, Feb 28, 2011 8:30 am > > Subject: [WanderlodgeForum] Re: Engine won't start or Primus > > > > > > Thank you Roger, > > I think you are correct about the condition of the batteries. Could you > > recommend which ones to purchase for replacement? Could not find the Battery > > Heat Switch. Sure do miss Dean from Wanderlodge when you have a problem, > > what would all we do without this forum. > > Thanks > > Nelson Slinkman > > 1994 WB 40' > > Westminster, Md > > > > --- In WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compose?to=Wa\ nderlodgeForum%40yahoogroups.com>, > > Roger W Webb > > > > > > IMO your engine batteries are just too weak. If charging them does get > > some cranking power, trying jumping them (if you are a member of Good Sam or > > other service, it may be worth the call). Even then, if you have one really > > bad battery, jumping may not help and replacing them may be your next > > alternative. The gages on the dash really only give you an indication of > > voltage at the moment and although lookin' good, may not be a good > > indication of cranking power. > > > > > > > > > Tying you house and engine batteries together with the switch on the dash > > could get you some cranking power, and heating up the batteries may help (my > > switch for the battery heat is under the sink in my 91WL). But even those > > assists may not overcome a bad or weak bank of batteries. > > > > > > > > > Roger Webb - Cedar Rapids, IA > > > 91WL (sitting in NC) > > > > > > > > > > > > > > > > > > > > > > > > -----Original Message----- > > > From: nelsons > > > To: WanderlodgeForum anderlodgeForum%40yahoogroups.com> > > > > > > Sent: Mon, Feb 28, 2011 7:51 am > > > Subject: [WanderlodgeForum] Re: Engine won't start or Primus > > > > > > > > > > > > > > > > > > > > > > > > Hello Mike, > > > I could not find any switch for electric heater behind the pull down > > > drawer. There was only an "start Gen" "LP on/off" and water pump switch. > > Yes, the switch was "on" to charge both sets of batteries. I am sure the > > ether tank is empty I have had this bus for 10 years and never used it. The > > bus only has 31000 miles on it. > > > Thanks for your help. > > > Nelson SLinkman > > > 1994 WB 40' > > > Westminster, Md > > > > > > --- In WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compose?to=Wa\ nderlodgeForum%40yahoogroups.com>, > > "Steve Quandt" > > > > > > > > If it is set up the same as my 1993 pull down the drawer front under > > the > > > > kitchen sink, there should be a switch there for the electric engine > > heater. > > > > For this to work you need to be plugged in or on your generator. When > > you > > > > were parked did you tie the engine batteries to the house so they would > > be > > > > charged? If not there is a switch on the dash AUX Battery, if it is off > > > > turn to on to on to charge the engine batteries. > > > > > > > > > > > > > > > > The cold start switch goes to an ether cylinder in the engine bay that > > is > > > > most likely empty. > > > > > > > > > > > > > > > > Steve Quandt 1993 PT40 > > > > > > > > Iron Mountain, MI > > > > > > > > Now in WARM Marble Falls TX > > > > > > > > > > > > > > > > _____ > > > > > > > > From: WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compose?to=Wa\ nderlodgeForum%40yahoogroups.com> > > > > [mailto:WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compo\ se?to=WanderlodgeForum%40yahoogroups.com>] > > On Behalf Of nelsons > > > > Sent: Monday, February 28, 2011 11:26 AM > > > > To: WanderlodgeForum@yahoogroups.com<http://us.mc812.mail.yahoo.com/mc/compose?to=Wa\ nderlodgeForum%40yahoogroups.com> > > > > Subject: [WanderlodgeForum] Engine won't start or Primus > > > > > > > > > > > > > > > > > > > > > > > > Hello, > > > > I have a 1994 WB with an 8v92. I have been away for 4 months and just > > got > > > > back this past weekend. I wanted to start the engine so I tried > > starting the > > > > Primus in order to pre-warm the engine due to the cold temperature > > we've had > > > > for a few months. The Primus would not start. I checked the Propane > > switch, > > > > and it was on, the stove was working and so was the refrigerator. I > > tried to > > > > turn it on a few times incase there was and air in the line, but it > > never > > > > started. It there another safety switch for the Primus? I started the > > engine > > > > and the primus before I left and all worked properly. > > > > When I try to start the engine it turns very slowly and does not turn > > fast > > > > enough to start. > > > > The only thing that I noticed was the "Neutral" light on the > > transmission > > > > panel is on. > > > > Does the 1994 Bird have an electric heated for the engine? I saw a > > switch > > > > that is on the right side of the consul that says cold start. > > > > Any help would be appreciated. > > > > Thanks > > > > Nelson Slinkman > > > > 1994 WB > > > > Westminster, Md > > > > > > > > > > > > > > |
03-01-2011, 12:19
