Changing tranny fluid
04-04-2006, 11:22
Hi guys,
Want to get your feeling about changing the tranny fluid. My bird has 130k on it and I don't find any records of the previous 3 owners changing the fluid. Since we live in our bird fulltime and maybe take a trip once every other month for a 3 dayer, no problem. This Fri I'm going to get the oil changed (5k on engine rebuild) and change the tranny fluid. We will be traveling fulltime in 18 months and want to know if we should change to synthetics. I have notice the tranny temp gauge going up in stop and go traffic and I have read the synthetics cut down on the heat factor. Is it worth the expense ($8.00 a quart)and how long does it last before needing rechanging? Should I just stay with the conventional stuff in there now (changing it out, of course). What think you? Bob Lawrence 84 pt36 Tacky Tacoma, Wa. with 556 days till fulltiming on the road. |
04-04-2006, 13:45
Bob,
By all means, change to Synthetic. The correct and recomended fluid is Castrol Transynd. It is actually manufactured by BP(British Petroleum, the same BP stations you see all over the US). You may save yourself some money as the "Castrol" name plate is expensive. I have a 5 gallon bucket of " BP Autran Syn 295 " with a part# 709707. Paid $139.90 for it. This is the EXACT same stuff. BP makes it and Castrol markets it under their label. (I have a very good friend in the petro business who is also very well connected) Because of the trans retarder producing severe heat and the fact that the MTB654CR is rated for only 300HP and 950 Ft.Lbs. of torque, it is my opinion that you need to take EVERY precaution you can to prolong the life of your transmission. Here is an article I found... April 3, 2001 - Oklahoma City - Since Allison Transmission introduced it in June 1999, the synthetic automatic transmission fluid (ATF) TranSynd has proven itself in demanding motorhome applications. TranSynd, a co-branded ATF exclusively formulated by Castrol for use in heavy-duty Allison Automatic Transmissions, extends oil drain intervals for Allison automatic transmissions by up to 300%. A nonretarder-equipped motorhome using 100% TranSynd can enjoy Allison's recommended general duty interval at 100,000 miles between oil changes. Severe duty motorhome applications using 100% TranSynd can achieve 50,000 miles between oil changes. In either applications, operators will get the substantial benefits of fewer oil changes compared any other fluid recommended by Allison for general or severe duty. "Today's transmissions operate at higher temperatures and in far more demanding conditions than in the past," says Lynn Gibboney, manager of Tactical Marketing for Allison Transmission. "TranSynd offers as much as four times longer oil drain intervals compared with other automatic transmission fluids. In addition, the product reduces fleet costs relating to maintenance, labor, filter replacement and oil disposal." TransSynd extends oil change guidelines for Allison transmissions to 100,000 miles/48 months for general duty and 50,000 miles/24 months for severe duty. This compares to recommended changes for conventional transmission fluids of 12,000 miles/6 months for severe duty and 25,000 miles/12 months for general duty. TranSynd, which is designed for use in most medium- and heavy-duty automatic transmissions, also reduces maintenance cycles, increasing vehicle up-time and fleet revenue. Engineered for Allison Transmission by Castrol, TranSynd dramatically extends drain intervals and lowers maintenance costs. While TranSynd brings value to all motorhomes, it is especially beneficial for use in those neededing a long lasting, proven ATF solution. Because TranSynd functions within wider operating temperature ranges, it is ideal for use year-round in all climates. TranSynd also is much more resistant to thermal breakdown than other fluids. This ensures superior protection of transmission components and extended fluid and transmission life. TranSynd is not subject to the degradative properties of most conventional fluids. In fact, in fleet test studies the product has demonstrated dramatic performance over other ATFs in severe applications. Perhaps most impressively, this includes an extension of oil drain intervals by 300% and a reduction of fleet maintenance hours by 75%. Tests have shown significant operational benefits of TranSynd over other products. These include: Superior wear resistance Greatly extended drain intervals Superior protection of transmission components Dramatic oxidation reduction Far less sheardown Significantly improved viscosity stability Improved shift quality Extended transmission life Considerably reduced overall transmission life cycle costs Lower fleet operating and maintenance expenses TranSynd is bringing a whole new level of functionality and performance to motorhome applications, one that is enabling motorhome automatic transmissions to operate more efficiently, productively, and for significantly less cost. TranSynd meets the Allison TES-295 Transmission Fluid Specification for Severe Duty and Extended Drain Intervals. The product is also approved to the General Motors DEXRONb IIIG Specification. For more information, sales literature and spec sheets, contact your Allison distributor, authorized dealer, visit us at http://www.allisontransmission.com, or fax your request to Allison Transmission at 1-800-252-5ATD, or write Allison Transmission, P.O. Box 894, Speed Code PF8, Indianapolis, IN 46206-0894 Allison Transmission is the world's leading designer, manufacturer and seller of medium- and heavy-duty automatic transmissions for trucks, buses, off-road and military vehicles and RVs. Welp, there you have it! Jay Darst 85PT40 6V92 and MTB654CR Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi guys, > Want to get your feeling about changing the tranny fluid. > My bird has 130k on it and I don't find any records of the previous 3 > owners changing the fluid. > Since we live in our bird fulltime and maybe take a trip once every > other month for a 3 dayer, no problem. > This Fri I'm going to get the oil changed (5k on engine rebuild) and > change the tranny fluid. > We will be traveling fulltime in 18 months and want to know if we > should change to synthetics. > I have notice the tranny temp gauge going up in stop and go traffic > and I have read the synthetics cut down on the heat factor. > Is it worth the expense ($8.00 a quart)and how long does it last > before needing rechanging? > Should I just stay with the conventional stuff in there now (changing > it out, of course). > What think you? > > Bob Lawrence > 84 pt36 > Tacky Tacoma, Wa. with 556 days till fulltiming on the road. > |
04-05-2006, 00:38
Hi Jay and welcome Bob,
Couple things we should mention "when" you change to synthetics (in both your transmission and your engine, and even if you don't). Many of the Allison transmission models have more than one filter which may require dropping the pan to locate. Additionally, to achieve the full benefits from synthetics requires purging the system of the old non-synthetics and that may take one or more cycles of somewhat shortened usage, in the absence of a complete pressure purge. Most importantly, "More potential damage can occur from an over-filled transmission, than an under-filled one" (cite: Allison engineers, FMCA & Bluebird RIV seminars, numerous years). Upon refilling the system after drain, use the minimum "cold" dipstick mark to achieve the initial oil refill before starting the engine. Warm the transmission temps to above 140 degrees in neutral at normal idle. Cycle through Drive, Neutral, Reverse, Neutral, Drive several times to purge trapped air before checking "hot" dipstick mark for final "topping off." If your transmission model is equipped with the "electronic dipstick," you can perform these checks from the driver's area. Enjoy, John Suter 2000LXi and previous PT40's --- Jay Darst > Bob, > > By all means, change to Synthetic. > > The correct and recomended fluid is Castrol > Transynd. It is actually > manufactured by BP(British Petroleum, the same BP > stations you see > all over the US). You may save yourself some money > as the "Castrol" > name plate is expensive. I have a 5 gallon bucket of > " BP Autran Syn > 295 " with a part# 709707. Paid $139.90 for it. This > is the EXACT > same stuff. BP makes it and Castrol markets it under > their label. > (I have a very good friend in the petro business who > is also very > well connected) > > Because of the trans retarder producing severe heat > and the fact > that the MTB654CR is rated for only 300HP and 950 > Ft.Lbs. of torque, > it is my opinion that you need to take EVERY > precaution you can to > prolong the life of your transmission. > > Here is an article I found... > > April 3, 2001 - Oklahoma City - Since Allison > Transmission > introduced it in June 1999, the synthetic automatic > transmission > fluid (ATF) TranSynd has proven itself in demanding > motorhome > applications. > > TranSynd, a co-branded ATF exclusively formulated > by Castrol for > use in heavy-duty Allison Automatic Transmissions, > extends oil drain > intervals for Allison automatic transmissions by up > to 300%. > > A nonretarder-equipped motorhome using 100% > TranSynd can enjoy > Allison's recommended general duty interval at > 100,000 miles between > oil changes. Severe duty motorhome applications > using 100% TranSynd > can achieve 50,000 miles between oil changes. In > either > applications, operators will get the substantial > benefits of fewer > oil changes compared any other fluid recommended by > Allison for > general or severe duty. > > "Today's transmissions operate at higher > temperatures and in far > more demanding conditions than in the past," says > Lynn Gibboney, > manager of Tactical Marketing for Allison > Transmission. "TranSynd > offers as much as four times longer oil drain > intervals compared > with other automatic transmission fluids. In > addition, the product > reduces fleet costs relating to maintenance, labor, > filter > replacement and oil disposal." > > TransSynd extends oil change guidelines for Allison > transmissions > to 100,000 miles/48 months for general duty and > 50,000 miles/24 > months for severe duty. This compares to recommended > changes for > conventional transmission fluids of 12,000 miles/6 > months for severe > duty and 25,000 miles/12 months for general duty. > TranSynd, which > is designed for use in most medium- and heavy-duty > automatic > transmissions, also reduces maintenance cycles, > increasing vehicle > up-time and fleet revenue. > > Engineered for Allison Transmission by Castrol, > TranSynd > dramatically extends drain intervals and lowers > maintenance costs. > While TranSynd brings value to all motorhomes, it > is especially > beneficial for use in those neededing a long > lasting, proven ATF > solution. > > Because TranSynd functions within wider operating > temperature > ranges, it is ideal for use year-round in all > climates. TranSynd > also is much more resistant to thermal breakdown > than other fluids. > This ensures superior protection of transmission > components and > extended fluid and transmission life. > > TranSynd is not subject to the degradative > properties of most > conventional fluids. In fact, in fleet test studies > the product has > demonstrated dramatic performance over other ATFs in > severe > applications. Perhaps most impressively, this > includes an extension > of oil drain intervals by 300% and a reduction of > fleet maintenance > hours by 75%. > > Tests have shown significant operational benefits of > TranSynd over > other products. These include: > > Superior wear resistance > > > Greatly extended drain intervals > > Superior protection of transmission components > > Dramatic oxidation reduction > > Far less sheardown > > Significantly improved viscosity stability > > Improved shift quality > > Extended transmission life > > Considerably reduced overall transmission life > cycle costs > > Lower fleet operating and maintenance expenses > > TranSynd is bringing a whole new level of > functionality and > performance to motorhome applications, one that is > enabling > motorhome automatic transmissions to operate more > efficiently, > productively, and for significantly less cost. > > TranSynd meets the Allison TES-295 Transmission > Fluid Specification > for Severe Duty and Extended Drain Intervals. The > product is also > approved to the General Motors DEXRONb IIIG > Specification. > > For more information, sales literature and spec > sheets, contact your > Allison distributor, authorized dealer, visit us at > http://www.allisontransmission.com, or fax your request to > Allison > Transmission at 1-800-252-5ATD, or write Allison > Transmission, P.O. > Box 894, Speed Code PF8, Indianapolis, IN 46206-0894 > > Allison Transmission is the world's leading > designer, manufacturer > and seller of medium- and heavy-duty automatic > transmissions for > trucks, buses, off-road and military vehicles and > RVs. > > Welp, there you have it! > Jay Darst > 85PT40 6V92 and MTB654CR > Springfield, IL > > --- In WanderlodgeForum@yahoogroups.com, "Bob > Lawrence" > > > > > Hi guys, > > Want to get your feeling about changing the tranny > fluid. > > My bird has 130k on it and I don't find any > records of the > previous 3 > > owners changing the fluid. > > Since we live in our bird fulltime and maybe take > a trip once > every > > other month for a 3 dayer, no problem. > > This Fri I'm going to get the oil changed (5k on > engine rebuild) > and > > change the tranny fluid. > > We will be traveling fulltime in 18 months and > want to know if we > > should change to synthetics. > > I have notice the tranny temp gauge going up in > stop and go > traffic > > and I have read the synthetics cut down on the > heat factor. > > Is it worth the expense ($8.00 a quart)and how > long does it last > > before needing rechanging? > > Should I just stay with the conventional stuff in > there now > (changing > > it out, of course). > > What think you? > > > > Bob Lawrence > > 84 pt36 > > Tacky Tacoma, Wa. with 556 days till fulltiming on > the road. > > > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
04-05-2006, 04:22
Bob, I just had a trans service at the Allison dealer it was less
than $180.00 for that part of the service. I opted to use the oil- oil because it would be more affordable to drop the pan and change every 20 thousand miles or with every other engine oil change. I like the idea of looking at the filter and pan every 20. The second reason I did not take the synthetic oil was I think it will take 3 or 4 changes to evacuate the trans of oil-oil ( t-converter, valve bodies). Third reason is I tend to be cheap (actually no. 1). Reason four is I dont have a need to push the bus past the limits of oil-oil temp stress warnings (if stress causes heat in oil-oil and less heat in syn-oil, how will I know to back off the stress). Gregory O'Connor cheap and trying to avoid stress --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi guys, > Want to get your feeling about changing the tranny fluid. > My bird has 130k on it and I don't find any records of the previous 3 > owners changing the fluid. > Since we live in our bird fulltime and maybe take a trip once every > other month for a 3 dayer, no problem. > This Fri I'm going to get the oil changed (5k on engine rebuild) and > change the tranny fluid. > We will be traveling fulltime in 18 months and want to know if we > should change to synthetics. > I have notice the tranny temp gauge going up in stop and go traffic > and I have read the synthetics cut down on the heat factor. > Is it worth the expense ($8.00 a quart)and how long does it last > before needing rechanging? > Should I just stay with the conventional stuff in there now (changing > it out, of course). > What think you? > > Bob Lawrence > 84 pt36 > Tacky Tacoma, Wa. with 556 days till fulltiming on the road. > |
04-05-2006, 11:51
Hi John,
When you say a shorter usage, what do you recommend when to redue. Sounds like synthetic is the way to go for me. Bob 84 PT36 Tacoma, Wa. (Where we finally have sun for a couple of days) --- In WanderlodgeForum@yahoogroups.com, John Suter wrote: > Additionally, to achieve the full benefits from > synthetics requires purging the system of the old > non-synthetics and that may take one or more cycles of > somewhat shortened usage, in the absence of a complete > pressure purge. |
04-05-2006, 12:10
Thanks Greg for your info...seems like the way to go..gotta thunk
about it...thanks again. Bob > Bob, I just had a trans service at the Allison dealer it was less > than $180.00 for that part of the service. I opted to use the oil- > oil because it would be more affordable to drop the pan and change > every 20 thousand miles or with every other engine oil change. I > like the idea of looking at the filter and pan every 20. The second > reason I did not take the synthetic oil was I think it will take 3 or > 4 changes to evacuate the trans of oil-oil ( t-converter, valve > bodies). Third reason is I tend to be cheap (actually no. 1). Reason > four is I dont have a need to push the bus past the limits of oil- oil > temp stress warnings (if stress causes heat in oil-oil and less heat > in syn-oil, how will I know to back off the stress). > > Gregory O'Connor > cheap and trying to avoid stress > |
04-05-2006, 12:12
Thanks Jay, for the article.
Will make a decision on Fri when it gets done...thanks again. Bob > > By all means, change to Synthetic. > > Welp, there you have it! > Jay Darst > 85PT40 6V92 and MTB654CR > Springfield, IL |
04-05-2006, 12:45
Actually in my opinion changing to synthetic in a transmission or a
diesel engine that is not being used in what is called "severe service" is penny wise and pound foolish. Its kind of like putting a full race 427 Corvette engine in a minicooper. A bluebird has a transmission and engine oil temperature gauge. If you are consistently running in the safe range for both and they are not overheating then there is absolutely no reason to use synthetic oil. Dextron 3 will work just fine and for longer then you and I together hope to live. Most owners are only putting a few thousand miles a year on their coaches. Its easy and quick to drain the fluid out of the transmission pan, change the external filter and refill with Dextron 3. Most transmission problems are caused by not properly servicing and using it and not due to the kind of fluid used. Watch the temperature gauges and be nice to the transmission and it will be nice to you. Tom Warner Vernon Center,NY 1982 FC35 (for sale soon) 1985 PT40 At 07:51 PM 4/5/2006, you wrote: >Hi John, >When you say a shorter usage, what do you recommend when to redue. >Sounds like synthetic is the way to go for me. >Bob >84 PT36 >Tacoma, Wa. (Where we finally have sun for a couple of days) > >--- In WanderlodgeForum@yahoogroups.com, John Suter >wrote: > > Additionally, to achieve the full benefits from > > synthetics requires purging the system of the old > > non-synthetics and that may take one or more cycles of > > somewhat shortened usage, in the absence of a complete > > pressure purge. > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
04-05-2006, 12:51
Hi Bob,
I try to avoid speculation in favor of facts whenever possible so the best answer I can offer is the objective: to purge the system of the residual non-synthetics, and achieve a true 100% synthetics as soon as possible. When I began the switch to synthetics (engine and transmission; coach and cars), I asked that the systems be "pressure purged" (blown out) and during the first year I observed the same fluid and filter schedule as prior to switching. Others may argue that is super-cautious. My feeble response would be, "I can more easily afford a bit on the extra fluid and filters rather than on any catastrophic costly failure." My only caveat is to be your own judge, but try to avoid the "penny wise and pound foolish" syndrome. Another thing I learned along the way is to watch for misleading terms such as products and services labeled "blended synthetics" which are not true 100% synthetics. This term, and others like it found in small print, are especially common in the automobile field. John --- Bob Lawrence > Hi John, > When you say a shorter usage, what do you recommend > when to redue. > Sounds like synthetic is the way to go for me. > Bob > 84 PT36 > Tacoma, Wa. (Where we finally have sun for a couple > of days) > > --- In WanderlodgeForum@yahoogroups.com, John Suter > > wrote: > > Additionally, to achieve the full benefits from > > synthetics requires purging the system of the old > > non-synthetics and that may take one or more > cycles of > > somewhat shortened usage, in the absence of a > complete > > pressure purge. > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
04-05-2006, 16:12
John I am not a fan of purging a tranny. In fact my SOB tranny came with a
warning from Ford not to hook up to any system that forced the fluid out. I've just switched the Bird over to Transynd and after the recommended mileage I'll dump the stuff and refill with Transynd again for what Allison recognizes as 100% synthetic. Of course it won't be exactly 100% but it is close enough for Allison so I'll except their recommended change intervals for synthetic from then on. Rob, Sue & Merlin 94 WLWB Quoting John Suter > > > > Hi Bob, > > > > Â I try to avoid speculation in favor of facts > > whenever possible so the best answer I can offer is > > the objective: to purge the system of the residual > > non-synthetics, and achieve a true 100% synthetics as > > soon as possible. > > > > Â When I began the switch to synthetics (engine and > > transmission; coach and cars), I asked that the > > systems be "pressure purged" (blown out) and during > > the first year I observed the same fluid and filter > > schedule as prior to switching. Others may argue that > > is super-cautious. My feeble response would be, "I > > can more easily afford a bit on the extra fluid and > > filters rather than on any catastrophic costly > > failure." My only caveat is to be your own judge, but > > try to avoid the "penny wise and pound foolish" > > syndrome. > > > > Â Another thing I learned along the way is to watch > > for misleading terms such as products and services > > labeled "blended synthetics" which are not true 100% > > synthetics. This term, and others like it found in > > small print, are especially common in the automobile > > field. > > > > John > > > > > > --- Bob Lawrence > > > > > Hi John, > > > When you say a shorter usage, what do you recommend > > > when to redue. > > > Sounds like synthetic is the way to go for me. > > > Bob > > > 84 PT36 > > > Tacoma, Wa. (Where we finally have sun for a couple > > > of days) > > > > > > --- In WanderlodgeForum@yahoogroups.com, John Suter > > > > > > wrote: > > > > Â Additionally, to achieve the full benefits from > > > > synthetics requires purging the system of the old > > > > non-synthetics and that may take one or more > > > cycles of > > > > somewhat shortened usage, in the absence of a > > > complete > > > > pressure purge. > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail.yahoo.com > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > > |
