Kohler/Perkins Generator Expert
04-07-2006, 14:30
Who is the Kohler Generator expert?
While at the Maxton Rally, Scott heard a rattle noise in my generator over and above the Perkins. He had problems with his generator where the support bearing(at the opposite end of the rotor from the Perkins) had wallowed out the bearing holder thingy. Anyway he replaced his generator. I'd like for mine to die so it make sense to move up to a 15kw PowerTech. I have heard that the Perkins/Kohler's have seen 30,000 hours of use. So, with proper maintenance, the dam thing is going to outlive me. Would like someone to suggest what this rattle might be. Have ordered the replacement bearing and support parts. And get installed see if thats it. Any suggestions? Thanks Jay Darst 85PT40 Spfld, IL |
04-08-2006, 04:20
Jay,
Not suggesting such bad for your generator, but last year the bracket that holds the brushes in the generator broke on mine, and the loose part and brush spun with the armature damaging it to the extent of needing replacement. About a $1,000 deal. Obviously, we had no charging ability at the time of occurrence. And, thanks for your great dissertation on the inverter install. I remember we appreciated your helping us when we installed ours. Ron â No. California 85PT36 --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > Would like someone to suggest what this rattle might be. Have > ordered the replacement bearing and support parts. And get installed > see if thats it. > > Any suggestions? > > Thanks > Jay Darst > 85PT40 > Spfld, IL > |
04-09-2006, 01:19
Jay, ours has what sounds like a rattle also. Found a crack in the
muffler last fall after it was getting louder, we can only hear it on the driver side of the bus so thought that must be it. Well after removing the exaust over the winter a fixing the muffler, much to our surprise when we put it back together last weekend it still makes that noise. Now 2 different deisel michanics think it could be the exaust is to restricded(?) causing the motor to make this noise. We had it all apart last spring and the end bearing seamed fine, it also ran all last summer like that with no problems. Hey are you and your brother coming to RA again this year? Could hear they had some big cars running yesterday Jeff and Michelle August 1980FC35RB Plymouth Wi. --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > Who is the Kohler Generator expert? > > While at the Maxton Rally, Scott heard a rattle noise in my > generator over and above the Perkins. > > He had problems with his generator where the support bearing(at the > opposite end of the rotor from the Perkins) had wallowed out the > bearing holder thingy. Anyway he replaced his generator. > > I'd like for mine to die so it make sense to move up to a 15kw > PowerTech. > > I have heard that the Perkins/Kohler's have seen 30,000 hours of > use. So, with proper maintenance, the dam thing is going to outlive > me. > > Would like someone to suggest what this rattle might be. Have > ordered the replacement bearing and support parts. And get installed > see if thats it. > > Any suggestions? > > Thanks > Jay Darst > 85PT40 > Spfld, IL > |
04-09-2006, 03:16
Jay, maybe the noise is the muffler, it may have internal rust and
lose baffles??? I have newage /Kubota gensets (Coleman)on light towers with 15,000 hours but the demand-load is high and constant, I hear that gensets spin apart due to low use and light load. I would like to find a small 2K diesel to use as a light load- low consumption generator. Greg O'Connor 94pt Romoland California --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > Who is the Kohler Generator expert? > > While at the Maxton Rally, Scott heard a rattle noise in my > generator over and above the Perkins. > > He had problems with his generator where the support bearing(at the > opposite end of the rotor from the Perkins) had wallowed out the > bearing holder thingy. Anyway he replaced his generator. > > I'd like for mine to die so it make sense to move up to a 15kw > PowerTech. > > I have heard that the Perkins/Kohler's have seen 30,000 hours of > use. So, with proper maintenance, the dam thing is going to outlive > me. > > Would like someone to suggest what this rattle might be. Have > ordered the replacement bearing and support parts. And get installed > see if thats it. > > Any suggestions? > > Thanks > Jay Darst > 85PT40 > Spfld, IL > |
04-09-2006, 10:14
Jeff,
Thanks for the info on the exhaust noise possibility... My exhaust system has larger pipe than most I have noticed. Dan will be at Road America the weekend of 04/28-29-30. I'll be in St.Louis at the Ram Tough 200. Liked the RA weekend last year. What a great facility! Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Jeff August" > > Jay, ours has what sounds like a rattle also. Found a crack in the > muffler last fall after it was getting louder, we can only hear it on > the driver side of the bus so thought that must be it. Well after > removing the exaust over the winter a fixing the muffler, much to our > surprise when we put it back together last weekend it still makes > that noise. Now 2 different deisel michanics think it could be the > exaust is to restricded(?) causing the motor to make this noise. We > had it all apart last spring and the end bearing seamed fine, it also > ran all last summer like that with no problems. > Hey are you and your brother coming to RA again this year? Could hear > they had some big cars running yesterday > Jeff and Michelle August > 1980FC35RB > Plymouth Wi. > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > wrote: > > > > Who is the Kohler Generator expert? > > > > While at the Maxton Rally, Scott heard a rattle noise in my > > generator over and above the Perkins. > > > > He had problems with his generator where the support bearing(at the > > opposite end of the rotor from the Perkins) had wallowed out the > > bearing holder thingy. Anyway he replaced his generator. > > > > I'd like for mine to die so it make sense to move up to a 15kw > > PowerTech. > > > > I have heard that the Perkins/Kohler's have seen 30,000 hours of > > use. So, with proper maintenance, the dam thing is going to outlive > > me. > > > > Would like someone to suggest what this rattle might be. Have > > ordered the replacement bearing and support parts. And get installed > > see if thats it. > > > > Any suggestions? > > > > Thanks > > Jay Darst > > 85PT40 > > Spfld, IL > > > |
04-09-2006, 10:20
Greg,
That could be! Exhaust is looking a little shabby on the Perkins... Jeff August suggested that there may be something in the exhaust system causing the rattle. Certainly will look into that! Thanks Jay Darst 85PT40 Springdield, IL where I just got done installing a new Leece NeVille 320 amp alternator and replaced the wire with 1/0, new conduit, cleaned things up a bit. Runs front a/c off the inverter at 13Volts all the time- ;~} ye-a baby! --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Jay, maybe the noise is the muffler, it may have internal rust and > lose baffles??? I have newage /Kubota gensets (Coleman)on light > towers with 15,000 hours but the demand-load is high and constant, I > hear that gensets spin apart due to low use and light load. I would > like to find a small 2K diesel to use as a light load- low > consumption generator. > Greg O'Connor > 94pt Romoland California > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > Who is the Kohler Generator expert? > > > > While at the Maxton Rally, Scott heard a rattle noise in my > > generator over and above the Perkins. > > > > He had problems with his generator where the support bearing(at the > > opposite end of the rotor from the Perkins) had wallowed out the > > bearing holder thingy. Anyway he replaced his generator. > > > > I'd like for mine to die so it make sense to move up to a 15kw > > PowerTech. > > > > I have heard that the Perkins/Kohler's have seen 30,000 hours of > > use. So, with proper maintenance, the dam thing is going to outlive > > me. > > > > Would like someone to suggest what this rattle might be. Have > > ordered the replacement bearing and support parts. And get installed > > see if thats it. > > > > Any suggestions? > > > > Thanks > > Jay Darst > > 85PT40 > > Spfld, IL > > > |
04-09-2006, 11:44
One thing to look for if your exhaust has a heat/sound blanket
installed. The tight fitting jacket can hide an exhaust that is rusting out. When I rebuilt mine, the pipe literally feel into three pieces when I removed it. Could be just pieces of pipe rattling around. Blair in Oregon At 03:20 PM 4/9/2006, you wrote: >Greg, > >That could be! Exhaust is looking a little shabby on the Perkins... > > >Jeff August suggested that there may be something in the exhaust >system causing the rattle. > > >Certainly will look into that! > >Thanks >Jay Darst >85PT40 >Springdield, IL where I just got done installing a new Leece NeVille >320 amp alternator and replaced the wire with 1/0, new conduit, >cleaned things up a bit. Runs front a/c off the inverter at 13Volts >all the time- ;~} ye-a baby! > > >--- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Jay, maybe the noise is the muffler, it may have internal rust and > > lose baffles??? I have newage /Kubota gensets (Coleman)on light > > towers with 15,000 hours but the demand-load is high and constant, >I > > hear that gensets spin apart due to low use and light load. I >would > > like to find a small 2K diesel to use as a light load- low > > consumption generator. > > Greg O'Connor > > 94pt Romoland California > > > > --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > > > > > > > Who is the Kohler Generator expert? > > > > > > While at the Maxton Rally, Scott heard a rattle noise in my > > > generator over and above the Perkins. > > > > > > He had problems with his generator where the support bearing(at >the > > > opposite end of the rotor from the Perkins) had wallowed out the > > > bearing holder thingy. Anyway he replaced his generator. > > > > > > I'd like for mine to die so it make sense to move up to a 15kw > > > PowerTech. > > > > > > I have heard that the Perkins/Kohler's have seen 30,000 hours of > > > use. So, with proper maintenance, the dam thing is going to >outlive > > > me. > > > > > > Would like someone to suggest what this rattle might be. Have > > > ordered the replacement bearing and support parts. And get >installed > > > see if thats it. > > > > > > Any suggestions? > > > > > > Thanks > > > Jay Darst > > > 85PT40 > > > Spfld, IL > > > > > > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- [Non-text portions of this message have been removed] |
