Doghouse Insulation
05-03-2006, 13:44
Doghouse Insulation
Hi Group- I know there is always discussion in this topic, I have
reviewed the threads. I just reviewed the link to John Finn's 1982
doghouse insulation. I cannot seem to find a common method of
application. Do you use the spray glue? Or just apply directly. I
received the insulation from Stephen Birtles. It seems very sticky. Do
most cut a template out of paper or cardboard, and then cut out the
insulation? Or is it wise to cut the insulation to fit? The top part
of the house seems to be the most challenging, around the curved top
areas, where the 2 pieces split. Is it wise to add some fender washers
after the insulation is on to keep it there?
Thank you
Stephen
81 FC-33SB
Plant City,FL
05-03-2006, 14:42
Doghouse Insulation
I made paper patterns. You're too late. I offered them to the group
a few weeks ago but now I've thrown them away. I used the spray glue
that came with insulation I bought from JC Whitney. Took a couple of
hours once the lid was off the doghouse. I just used sheets of paper
and taped them together. Didn't need any washers.
Kerry
82 FC 35
Denver
> Thank you
> Stephen
> 81 FC-33SB
> Plant City,FL
05-04-2006, 05:34
Doghouse Insulation
I know we have used the mylar faced insulation to keep the heat out of the
coach. But is there an insulation out that will do that and also absorb the
sound? It seems that the Mylar faced will keep bouncing noise around and that it
makes its way out the radiator and any other opening in that compartment.
Ernie-83pt40 in Texas, trying to dry out from all the rain
05-04-2006, 09:16
Doghouse Insulation
I've used 3M-77 spray contact adheasive, held for the 6years I had
the coach, a couple of years since. Cleaned it with a putty-knife,
very little remaining, made the doghouse cover (top part) in one
piece so that it holds itself pretty well. The contact adheasive has
to be applied properly, and the foam soaks it up so the foam side has
to be applied liberally, if you do it wrong I'm sure it will fail.
Others have used 3M-90, a stronger version, probably a good idea.
I also applied one to a doghouse which was the pressure-sensitive
backing, stuck very well. Clean the surface first for best results.
Another FC I had I applied a lead quilted product, very expensive and
very heavy, it needed to be mechanically fastened which worked well
as the lead inner layer keeps its shape between fasteners. I drilled
the fasteners through from the carpet side before carpeting, the flat
sheet-metal plates hide well under there.
I feel that all methods work if properly prepared/used, I've had no
failures. Just like painting, prep is the most important step.
- Jeff Miller
in Holland, MI
Do
part
top
washers
> Thank you
> Stephen
> 81 FC-33SB
> Plant City,FL
05-04-2006, 13:49
Doghouse Insulation
Thank all who replied in this matter. I will give it a go this weekend, and
see how it sticks!
I will post pics in the wanderlodge forum, under photos section-
wanderlodge3208 1981 restoration pics.
Thanks again all
Stephen
81 FC-33SB
Plant City, Fl
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jeff Miller
Sent: Thursday, May 04, 2006 5:17 PM
Subject: [WanderlodgeForum] Re: Doghouse Insulation
- Jeff Miller
in Holland, MI
Do
part
top
washers
> Thank you
> Stephen
> 81 FC-33SB
> Plant City,FL
SPONSORED LINKS
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v
ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea
ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU
kCKkU7Dzhn_ObWmSYTw> vehicles
Wanderlodge
<http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2
=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use
d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP
j9U0JvqYQ>
Automotive
<http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+
vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de
aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF
4u_5wI8Pmy34cC1O9CxA> maintenance
Recreational
<http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati
onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic
le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s
ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer
Used
<http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio
nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl
e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si
g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles
Automotive
<http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve
hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal
er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV
MmISsCWgTnMq_4GlXA> radiators
_____
YAHOO! GROUPS LINKS
* Visit your group "WanderlodgeForum
<http://groups.yahoo.com/group/WanderlodgeForum> " on the web.
* To unsubscribe from this group, send an email to:
_____
05-04-2006, 20:30
Doghouse Insulation
Stephen- don't forget to get the foil tape to cover your seams. Makes the
job look great. Ernie-83pt40 in Texas
