back up camera solenoid or relay or ???
05-07-2006, 14:07
My back-up camera works most of the time. When it doesn't work I get
a blue vertical line on a blank screen. Most of the time, simply
turning off the TV and waiting a few minutes then back on, it works.
Occasionally it doesn't come back on. Have to turn off the ignition
switch and when itd turned back on, the backup camera works again.
My conclusion to this... the relay or solenoid that causes the TV to
show a TV show when key is off and to show the back-up camera when
the key is on,.... is bad.
I want to replace this relay or solenoid. Have looked in the over
head above the driver. I have not found the relay or solenoid yet.
Anybody KNOW where the solenoid or relay IS? If its a weird piece,
where do I get it? What part number is it?
Thanks in advance!,
Jay Darst
85PT40
Springfield, IL where I just got back from the AHDA races in
Madison, IL(St.Louis area)(AHDA = ALL Harley Drag racing
Association). The TOP FUEL bikes run the 1/4 in 5.60sec @ 215mph,
sound just like a top fuel dragster! Spent the weekend there in the
Bird. The outside stereo and TV was a hit with the bikers!
05-07-2006, 15:27
Jay:
That relay is in the chassis of the CT-911 and was part of the modification
by PMMI. There is a white plug on the back side of the chassis that has 5
wires and more than likely that is where your problem may be.
Ralph
Safe travels,
>Thanks in advance!,
>Jay Darst
>85PT40
05-07-2006, 15:54
Thanks Ralph.
The Tv screen is over head, above the windshield, the tuner and
stuff is in the overhead bin on the traffic side above the driver.
Where/what is a CT-911?
The plug itself is the problem?
Thanks again!
Jay Darst
85PT40
Spfld, IL
> Jay:
modification
that has 5
> Ralph
> Safe travels,
get
works.
ignition
to
> >Thanks in advance!,
> >Jay Darst
> >85PT40
05-07-2006, 16:09
The tuner is where the relay is located. It is a solder in added to the
chassis by PMMI. The back up monitor and tv is a Hitachi CT-911 that PMMI
modified. The plug has wires in it and check the pins in the plug. It is
where the incoming power goes through and has been a problem in the past.
The relay in question is a solid state and rarely has problems.
Ralph
At 03:54 AM 5/8/2006 +0000, you wrote:
>Thanks Ralph.
>Thanks again!
>Jay Darst
>85PT40
>Spfld, IL
> > Jay:
>modification
>that has 5
> > Ralph
> > Safe travels,
>get
>works.
>ignition
>to
> > >Thanks in advance!,
> > >Jay Darst
> > >85PT40
>Yahoo! Groups Links
Safe travels,
05-08-2006, 02:04
Ralph,
In my 86 PT40 The backup camera has a paper label on the inside casing that says
Audiotronics is this a Hitachi brand. At times it will play fine then go blank.
I can tap on the case and it will sometimes come back on other times will flash
lines across screen. I have moved wiring around running to case with no results
so I think it must be internal. Is there some place to get it repaired. Your
thoughts please.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Monday, May 08, 2006 12:09 AM
Subject: Re: [WanderlodgeForum] Re: back up camera solenoid or relay or ???
Ralph
>Thanks Ralph.
>Thanks again!
>Jay Darst
>85PT40
>Spfld, IL
> > Jay:
>modification
>that has 5
> > Ralph
> > Safe travels,
>get
>works.
>ignition
>to
> > >Thanks in advance!,
> > >Jay Darst
> > >85PT40
>Yahoo! Groups Links
Safe travels,
SPONSORED LINKS Recreational vehicles Recreational vehicle financing
Recreational vehicle repair
Recreational vehicle rental Recreational vehicle camper Recreational
vehicle rate
YAHOO! GROUPS LINKS
05-08-2006, 02:41
Howard:
This is the first I have heard of the Audiotronics being used. When Doug
Hampton, of PMMI, sent me the file on the back up camera system, I was
doing a write up on image reversing, there was only the Hitachi CT-911 in
the file.
The image reversing was done via external relays but the Color TV (when
Coach key was off) or the back up camera ( when Coach key was in the run
position) is done with an internal solid state relay.
Your problem sounds more like a cold solder joint or bad variable resistor
(pot) on the chassis part of the system.
As to service, I honestly do not know. PMMI did change some of the
circuitry by adding the solid state relay and there were a couple of board
traces cut and re directed in the gain control section. The P to P and
voltages remained the same though. So a competent TV repair should be able
to help you.
Safe travels,
At 10:04 AM 5/8/2006 -0400, you wrote:
>Ralph,
>that says Audiotronics is this a Hitachi brand. At times it will play
>fine then go blank. I can tap on the case and it will sometimes come back
>on other times will flash lines across screen. I have moved wiring around
>running to case with no results so I think it must be internal. Is there
>some place to get it repaired. Your thoughts please.
>Howard Truitt
>Camilla, Ga.
>86 PT40
> From: Ralph L. Fullenwider
> Ralph
05-08-2006, 08:04
i just changed mine to colour have a good camara fifity bucks call me david 386
804 5619 mine is an 86 pt40 also
"Howard O. Truitt" wrote: Ralph,
thoughts please.
Howard Truitt
Camilla, Ga.
86 PT40
Ralph
>Thanks Ralph.
>Thanks again!
>Jay Darst
>85PT40
>Spfld, IL
> > Jay:
>modification
>that has 5
> > Ralph
> > Safe travels,
>get
>works.
>ignition
>to
> > >Thanks in advance!,
> > >Jay Darst
> > >85PT40
>Yahoo! Groups Links
Safe travels,
vehicle rate
YAHOO! GROUPS LINKS
SPONSORED LINKS
Recreational vehicles Recreational vehicle financing Recreational
vehicle repair Recreational vehicle rental Recreational vehicle camper
Recreational vehicle rate
YAHOO! GROUPS LINKS
Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
05-08-2006, 08:38
This is the '86-up monitor, I believe they later became Dotronix.
Your problem is a common one. If you remove the monitor (fairly simple
in your coach with the overhead mount), it can be repaired. I have
found that the daughter-board has an edge connector which is prone to
solder-joints failing, probably from vibration. Re-soldering the
connector on the daughter-board and mother-board should (and has always
for me) fix the problem. Supporting the board so that it can't as
easily vibrate/move should also prevent the problem in the future.
That is also a great time to reverse the image so that you can install
a new camera. The red and blue wires on the two-pin connector on the
mother-board need to be cut and reversed (red to blue, blue to red),
then a new BNC-type camera can be used. I've been very happy with ultra-
low-light .003 lux B&W cameras from Supercircuits.com, much cheaper
cameras are available from them and others also. The Dotronix monitor
is B&W.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Ralph,
casing that says Audiotronics is this a Hitachi brand. At times it
will play fine then go blank. I can tap on the case and it will
sometimes come back on other times will flash lines across screen. I
have moved wiring around running to case with no results so I think it
must be internal. Is there some place to get it repaired. Your thoughts
please.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
05-08-2006, 15:44
ALl RIGHT! Thanks Ralph, thats a big help!
I'll look into it.
Thanks
Jay Darst
85PT40
Spfld, IL
to the
that PMMI
It is
the past.
> Ralph
> >Thanks Ralph.
> >Thanks again!
> >Jay Darst
> >85PT40
> >Spfld, IL
> > wrote:
> > > Jay:
> >modification
> >that has 5
> > > Ralph
> > > Safe travels,
work I
> >get
simply
> >works.
> >ignition
again.
the TV
> >to
when
over
yet.
piece,
> > > >Thanks in advance!,
> > > >Jay Darst
> > > >85PT40
> >Yahoo! Groups Links
> Safe travels,
05-09-2006, 02:24
Jeff,
Do you or anyone else have a mother board schematic for the Audiotronic back up
monitor that you could send me.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Monday, May 08, 2006 4:38 PM
Subject: [WanderlodgeForum] Re: back up camera solenoid or relay or ???
is B&W.
- Jeff Miller
in Holland, MI
> Ralph,
please.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
vehicle rate
YAHOO! GROUPS LINKS
