Facet Fan Teardown.
05-16-2006, 16:47
Facet Fan Teardown.
I am getting ready to dissassemble the Facet fan and pulley hub on my
Bird in order to replace all of the bearings. I am doing this as preventive maint.as I understand these fans are made out of unobtainimum. I don't want to damage any of the parts so would like to know the proper order of teardown. Also are the bearings in the hub packed like a wheel bearing or is there oil in the hub. Jim Matus 1984 FC35SB Rescue CA |
05-17-2006, 01:56
Facet Fan Teardown.
I got a couple of Horton air clutch situations if you run into big problems.
The pulley hub has facing tapered bearings like a front wheel spindle. I takes about 4 oz. of oil to fill the cavity when reassembling. Use 80/90. End play for the pulley hub is .001 to .010, torque the nut to 110 ft. lbs. If the bearing races are in good shape, I would not bother changing the bearing assemblies but DO change the seal. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: jim matus To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 16, 2006 11:47 PM Subject: [WanderlodgeForum] Facet Fan Teardown. I am getting ready to dissassemble the Facet fan and pulley hub on my Bird in order to replace all of the bearings. I am doing this as preventive maint.as I understand these fans are made out of unobtainimum. I don't want to damage any of the parts so would like to know the proper order of teardown. Also are the bearings in the hub packed like a wheel bearing or is there oil in the hub. Jim Matus 1984 FC35SB Rescue CA ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-17-2006, 15:50
Facet Fan Teardown.
I dont have finess and confidence to do a rebuild. I just removed a
air fan clutch on my 94 Aeromax N14 and sent it out for a rebuild. $180.00. The turn around time was two days GregO'Connor 94pt40 Romoland Ca --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > I got a couple of Horton air clutch situations if you run into big problems. The pulley hub has facing tapered bearings like a front wheel spindle. I takes about 4 oz. of oil to fill the cavity when reassembling. Use 80/90. End play for the pulley hub is .001 to .010, torque the nut to 110 ft. lbs. If the bearing races are in good shape, I would not bother changing the bearing assemblies but DO change the seal. > Mike Hohnstein > Germantown, WI > 83FC35 > ----- Original Message ----- > From: jim matus > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 16, 2006 11:47 PM > Subject: [WanderlodgeForum] Facet Fan Teardown. > > > I am getting ready to dissassemble the Facet fan and pulley hub on my > Bird in order to replace all of the bearings. I am doing this as > preventive maint.as I understand these fans are made out of > unobtainimum. I don't want to damage any of the parts so would like to > know the proper order of teardown. Also are the bearings in the hub > packed like a wheel bearing or is there oil in the hub. > Jim Matus 1984 FC35SB Rescue CA > > > > > > > -------------------------------------------------------------------- ---------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > -------------------------------------------------------------------- ---------- > > > > [Non-text portions of this message have been removed] > |
