Squirell Cage Fan
07-29-2006, 05:52
Squirell Cage Fan
I have 2 or 3 12 volt fan motors that came out of the squirell cage fans on
the dash AC unit of my bird. I dont know if they are close to what you need
or not.
Sam Durrett
68 31 FC TN
In a message dated 7/29/2006 4:37:19 P.M. Central Standard Time,
truitt44@... writes:
--- In _WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com) , "Howard O. Truitt"
> Fellows,
> I need a squirell cage fan motor for the fan in the engine
compartment Does anyone have one they they can part with.
> Howard Truitt
> Camilla, Ga.
> 86 8V92 PT40
07-29-2006, 08:01
Squirell Cage Fan
Fellows,
I need a squirell cage fan motor for the fan in the engine compartment Does
Howard Truitt
Camilla, Ga.
86 8V92 PT40
07-29-2006, 08:01
Squirell Cage Fan
Fellows,
Howard Truitt
Camilla, Ga.
86 8V92 PT40
07-29-2006, 08:28
Squirell Cage Fan
I have often wondered why an old fresh water pump motor could not be
adapted for that fan. I have not taken a close look at it but if the shaft
is long enough,,,,,,,,, hmm
At 04:01 PM 7/29/2006 -0400, you wrote:
>Fellows,
>Howard Truitt
>Camilla, Ga.
>86 8V92 PT40
07-29-2006, 08:33
Squirell Cage Fan
Howard
would there be any numbers or makers marks on that little beauty
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Fellows,
> Howard Truitt
> Camilla, Ga.
> 86 8V92 PT40
07-29-2006, 09:36
Squirell Cage Fan
Stephen,
I will have to check on the numbers. BB parts does not have it. They reccomended
checking with Grainger.
I just thought I would ask if anyone had one.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Saturday, July 29, 2006 4:33 PM
Subject: [WanderlodgeForum] Re: Squirell Cage Fan
Howard
Stephen 77fc35
> Fellows,
> Howard Truitt
> Camilla, Ga.
> 86 8V92 PT40
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.10.4/401 - Release Date: 7/26/2006
07-29-2006, 10:30
Squirell Cage Fan
Howard,
If Grainger has your part, they have a good web site.
http://www.grainger.com
Type in centrifugal fan motors , search and you will find a
replacement. Or try to get the part number off of your motor and it
may cross to a Grainger part number. These motors are not too costly
you may want to replace the whole fan & motor.
I am not sure, if you are looking for 12V DC or 110v AC.
I used a 110V quiet AC computer fan to circulate air through the bay
that houses the Battery Charger.
Bill 88 FC Michigan Way toooooooo hot today!
> Stephen,
They reccomended checking with Grainger.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> From: Stephen Birtles
> Howard
> Stephen 77fc35
> > Fellows,
> > Howard Truitt
> > Camilla, Ga.
> > 86 8V92 PT40
7/26/2006
07-29-2006, 11:27
Squirell Cage Fan
Stephen,
I went ahead and pulled the motor and I don't see any markings. Looks like it
had a label but it's missing
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Saturday, July 29, 2006 5:36 PM
Subject: Re: [WanderlodgeForum] Re: Squirell Cage Fan
Stephen,
recomended checking with Grainger.
Howard Truitt
Camilla, Ga.
86 PT40
Howard
Stephen 77fc35
> Fellows,
> Howard Truitt
> Camilla, Ga.
> 86 8V92 PT40
07-29-2006, 12:01
Squirell Cage Fan
Bill,
This is 12vdc and sits at rear above the engine compartment and is used to cool
down engine after shutdown
Howard
Sent: Saturday, July 29, 2006 6:30 PM
Howard,
> Stephen,
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> Howard
> Stephen 77fc35
> > Fellows,
> > Howard Truitt
> > Camilla, Ga.
> > 86 8V92 PT40
7/26/2006
07-29-2006, 14:37
Squirell Cage Fan
Hi Howard,
When I had my '90PT, the blower went bad and I replaced it with a piece
of homemade duct, a couple of feet of defroster hose and a 12VDC bilge
blower. This worked great and kept the new blower a little fureher from
the engine heat. If I did this right, here is a link to a photo of the
modification.
http://i7.tinypic.com/21del2h.jpg
Rich D. '99LXi43' CT
> Fellows,
> Howard Truitt
> Camilla, Ga.
> 86 8V92 PT40
