E-Bay Wanderlodge
08-22-2006, 06:57
E-Bay Wanderlodge
Chris,
It is my understanding that it is not the same thing at all. In fact I'm sure it is not. It is to control odors by passing a 12 volts charge through one of two pairs of stainless steel electrodes within the holding tank. It oxidizes the organics thus eliminating odors. When turned on it cycles on and off by itself. Our bird has the same thing. But, I don't know if it works. I don't know how you would tell. I usually don't have odors in the coach and don't use that feature. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Chris Reed To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 22, 2006 11:10 AM Subject: Re: [WanderlodgeForum] Re: E-Bay Wanderlodge On my control panel in the kitchen on my 83FC35 it has a switch for "Waste Odor Control".. Any idea what that does? Is that the same thing? Richard Hayden My '81 FC didn't have one but it was listed as an option. I've never talked to anyone who had one. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 22, 2006 6:14 AM Subject: [WanderlodgeForum] Re: E-Bay Wanderlodge Never heard of this on a WL...I assume this was a "customer modification" rather than something from the factory??? Scott --- In WanderlodgeForum@yahoogroups.com "Stephen Birtles" > > its called an incinolet one of the worst ever waste disposal systems > installed in any mobile application > we had them on Railway Engines and one of the neat things about it was > to start it after it was partially full and then leave the cab of the > engine. the resultant stench would just about kill the poor engineer > Stephen 77fc35 never ever push the button while moving > > --- In WanderlodgeForum@yahoogroups.com "Scott Forman" <sforman@> > wrote: > > > > From the description: > > > > "and the prize above all motor homes is the revolutionary method of > > incinerating sewer waste & converting one weeks waste into a small > > cup of ash dust that can be safety deposited in any garbage can." > > > > Have I missed something? > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com "Chris" > > wrote: > > > > > > Came across this Wanderlodge on E-Bay.. > > > > > > Item number 120023609811 > > > > > > looks to have rolled over.... > > > > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-22-2006, 07:03
E-Bay Wanderlodge
Hi Chris,
The Waste Odor Control on your coach is nothing like the "Incinolet". Your system (I had that on my '90) sends a minute electric current through the waste tank to supposedly neutralize odors. It does not eliminate waste. I believe that your owners manual states that the Waste Odor Control works better if you add a little table salt to the waste tank to make the contents more conductive. The Incinolet actually burns the waste in a gas fired incinerator. Another type of waste disposal (I can't remember the name) actually macerated the waste and pumped it into the hot exhaust of the vehicle. I haven't seen one of those in years but the Incinolet is still used in camps, cabins, etc. where there is no septic system. IMO, it is several steps better than the old outhouse, specially in winter! Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, Chris Reed > > On my control panel in the kitchen on my 83FC35 it has a switch for "Waste Odor Control".. > Any idea what that does? > Is that the same thing? > > |
08-22-2006, 07:13
E-Bay Wanderlodge
It was lateral G's attempting to close the door, or,
"how fast can I take this off ramp", or, proof that Blue Birds don't slide on dry pavement. Bob --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > that s not neagive Gs its lateral G's come on get it right > > Have a great Day > Stephen 77fc35 whatever g's you measure > > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Chris, DavidB did that while showing JeffM frame effects of negitive > > G's. > > GregoryO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com, "Chris" > > wrote: > > > > > > Came across this Wanderlodge on E-Bay.. > > > > > > Item number 120023609811 > > > > > > looks to have rolled over.... > > > > > > |
08-22-2006, 08:41
E-Bay Wanderlodge
I had one of these in a mid 70s Sportscoach. They were real proud of
it, as I recall that it was around a $2,500 option back then. Worked ok I guess but did leave you thinking about what was happening all the time it was running. Odor was always an issue too. You definitely only wanted to turn it on while "underway". Pity the poor folks behind you. Terry Neal Bozeman, MT 82PT40 74FC34 Richard Hayden wrote: > My '81 FC didn't have one but it was listed as an option. I've never > talked to anyone who had one. > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > > > Sent: Tuesday, August 22, 2006 6:14 AM > Subject: [WanderlodgeForum] Re: E-Bay Wanderlodge > > Never heard of this on a WL...I assume this was a "customer > modification" rather than something from the factory??? > > Scott > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > its called an incinolet one of the worst ever waste disposal systems > > installed in any mobile application > > we had them on Railway Engines and one of the neat things about it > was > > to start it after it was partially full and then leave the cab of > the > > engine. the resultant stench would just about kill the poor > engineer > > Stephen 77fc35 never ever push the button while moving > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > From the description: > > > > > > "and the prize above all motor homes is the revolutionary method > of > > > incinerating sewer waste & converting one weeks waste into a > small > > > cup of ash dust that can be safety deposited in any garbage can." > > > > > > Have I missed something? > > > > > > Scott Forman > > > 82 FC35RB > > > Memphis > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > wrote: > > > > > > > > Came across this Wanderlodge on E-Bay.. > > > > > > > > Item number 120023609811 > > > > > > > > looks to have rolled over.... > > > > > > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
08-22-2006, 13:32
E-Bay Wanderlodge
I have a Waste Odor Switch also but have never used it. Truthfully, I've never
had a backflow odor problem since owning the bus(2+ years). I do not use odor control additives or salt. My monitors work perfectly. I think I have figured it out. The wife uses the washer so often that the black tank is as clean inside as the outside of the bus. I know this sounds like BS , but it's not a joke. If it isn't broke, don't fix it. Leroy Eckert 1990 WB40 Niceville, FL ----- Original Message ----- From: Chris Reed To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 22, 2006 1:10 PM Subject: Re: [WanderlodgeForum] Re: E-Bay Wanderlodge On my control panel in the kitchen on my 83FC35 it has a switch for "Waste Odor Control".. Any idea what that does? Is that the same thing? Richard Hayden My '81 FC didn't have one but it was listed as an option. I've never talked to anyone who had one. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, August 22, 2006 6:14 AM Subject: [WanderlodgeForum] Re: E-Bay Wanderlodge Never heard of this on a WL...I assume this was a "customer modification" rather than something from the factory??? Scott --- In WanderlodgeForum@yahoogroups.com "Stephen Birtles" > > its called an incinolet one of the worst ever waste disposal systems > installed in any mobile application > we had them on Railway Engines and one of the neat things about it was > to start it after it was partially full and then leave the cab of the > engine. the resultant stench would just about kill the poor engineer > Stephen 77fc35 never ever push the button while moving > > --- In WanderlodgeForum@yahoogroups.com "Scott Forman" <sforman@> > wrote: > > > > From the description: > > > > "and the prize above all motor homes is the revolutionary method of > > incinerating sewer waste & converting one weeks waste into a small > > cup of ash dust that can be safety deposited in any garbage can." > > > > Have I missed something? > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > --- In WanderlodgeForum@yahoogroups.com "Chris" > > wrote: > > > > > > Came across this Wanderlodge on E-Bay.. > > > > > > Item number 120023609811 > > > > > > looks to have rolled over.... > > > > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-22-2006, 13:54
E-Bay Wanderlodge
Rich
the incinolet is an electric barbque incinerator have not seen a gas one yet but they maybe out there Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "g_man1146" > > Hi Chris, > > The Waste Odor Control on your coach is nothing like the "Incinolet". > Your system (I had that on my '90) sends a minute electric current > through the waste tank to supposedly neutralize odors. It does not > eliminate waste. I believe that your owners manual states that the > Waste Odor Control works better if you add a little table salt to > the waste tank to make the contents more conductive. > The Incinolet actually burns the waste in a gas fired incinerator. > Another type of waste disposal (I can't remember the name) actually > macerated the waste and pumped it into the hot exhaust of the > vehicle. I haven't seen one of those in years but the Incinolet is > still used in camps, cabins, etc. where there is no septic system. > IMO, it is several steps better than the old outhouse, specially in > winter! > Rich D. '99LXi43' CT > > > --- In WanderlodgeForum@yahoogroups.com, Chris Reed > > > > > On my control panel in the kitchen on my 83FC35 it has a switch > for "Waste Odor Control".. > > Any idea what that does? > > Is that the same thing? > > > > > |
