Flying J
09-18-2006, 09:28
Flying J
There is a gentleman who is listed in the forum who makes a brass insert
for the fuel port that mostly prevents splashback. I say mostly because it is
not a complete solution since it will blow back some if you are running full
bore on high speed pump.
I like the terrycloth rag idea and it seems safe and practical.
Pete Masterson wrote:
Is there any reasonable solution to the BB's tendency to "gush" fuel
just before the tank is full? I try to estimate the amount of fuel to
take on ... but the fuel gauge is hardly precise enough to get within
20-30 gallons. I wear vinyl gloves when fueling, but when a gallon or
so splashes out, it tends to cover everything - gloves or not. (I've
learned to stand back!)
Pete Masterson
aeonix1@...
'95 Bluebird Wanderlodge WBDA 42'
El Sobrante, CA
On Sep 17, 2006, at 6:35 PM, Jay Darst wrote:
> Have
> had some diesel puddles to wade thru,
Yahoo! Groups Links
Wallace Craig
95 WLWB 42
Azle, Texas
09-18-2006, 10:26
Flying J
He is good friends with John Benham, Skydreamer, and Tony Holterman. Check
the contact list for Ton'y's phone number. Also, Steve Gureasko is in Coere d
Leane, Id on the way to Washington to see you.
83 PT40
Livingston, Montana
09-18-2006, 10:53
Flying J
I remember reading about that one ... but I can't find the email in
the archive...
I'll probably do the rag thing for now. The pressure equalization
tube as described by Jeff Miller is probably the "real" fix -- but is
a lot more work to install. (Rags, I have. Access to the top of the
fuel tank isn't easy.)
Pete Masterson
aeonix1@...
El Sobrante, CA
> brass insert for the fuel port that mostly prevents splashback. I
> say mostly because it is not a complete solution since it will blow
> back some if you are running full bore on high speed pump.
09-18-2006, 10:53
Flying J
Billy's unit works fine as long as you are not on the highest output
of the nozzle. I run mine at high till I know that I am within 50
gallons of the top and then I cut it back to prevent the blow back.
> Billy Dawson, did a modification for the fuel blow back. I think he
has an ad
> on Vintage Birds.
> Ernie Ekberg
> 83 PT40
> Livingston, Montana
09-18-2006, 10:54
Flying J
There you go... I found the ad!
Thanks.
Pete Masterson
aeonix1@...
El Sobrante, CA
> has an ad
> on Vintage Birds.
> Ernie Ekberg
> 83 PT40
> Livingston, Montana
> Yahoo! Groups Links
09-18-2006, 12:12
Flying J
I emailed the guy who's name was in the archives...never heard back
from him.
Bob Lawrence
84 PT36
Tacoma, Wa.
> Somewhere in the archives or files on either this site or the FC
forum is a solution
> designed by someone that I believe uses PVC pipe to solve the
problem.
> Kerry
> 82 Fc 35--Gusher
09-18-2006, 14:13
Flying J
He's the one I had sent an email to a while back..no reply.
Sent another one tonight, says email invalid.
Bob Lawrence
84 PT36
Tacoma, Wa.
has an ad
> on Vintage Birds.
> Ernie Ekberg
> 83 PT40
> Livingston, Montana
09-18-2006, 17:01
Flying J
No Ralph, that's the second thing to go. I can't remember what the first was.
Sent: Monday, September 18, 2006 9:40 AM
Subject: Re: [WanderlodgeForum] Flying J
Pete:
Check the archives for "fuel splash back" I remember someone having a
solution to this problem, just not who. Well, they do say that the "memory"
is first to go, right?
Safe travels,
http://home.swbell.net/rlf47/index.htm<http://home.swbell.net/rlf47/indexhtm>
>Pete Masterson
>aeonix1@...
>El Sobrante, CA
> > <snip>
> > Have
> > had some diesel puddles to wade thru, <snip>
09-19-2006, 04:08
Flying J
BIlly Dawson's email is now sherryandbilly@..., phone
830-305-7496. The address, 4570 Barbarosa Road, Sequin, TX 78155 is
still correct.
I spoke with him this morning, and it is important to know what year/
model BB you have as newer ones have a smaller fuel pipe and 87-89
(if I got that right) have a half-moon shaped ledge (to help hold the
nozzle) that would have to be removed to allow the baffle to fit.
Pete Masterson
aeonix1@...
El Sobrante, CA
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
> has an ad
>> on Vintage Birds.
>> Ernie Ekberg
>> 83 PT40
>> Livingston, Montana
User(s) browsing this thread: 13 Guest(s)
